I've just discovered that Ricoh's built in software only works if your SMTP server sends out without picking up password or authentication. Having same issue and it worked fine when it was behind corporate firewall with the same connection settings (IP address) as the SMTP server. Once I changed web hosting - it won't recognize the SMTP server or any authentication methods. According to IKON (Ricoh support for the USA) - your SMTP server has to have "relay exception"
I'n not quite sure what part you mean, as there is no picture included. If it is the one, connected to the "door" you open in front of the machine, the part number is G166 3923 Exit Guide Plate - Middle.
The part I'm thinking of is marked as number 8.
Press the red CLEAR/STOP key till you hear the little beep.
Press 1 0 7
Press the green COLOR START key.
The display changes into MAINTENANCE MODE
Use arrow keys to go to ENGINE MAINTENANCE and hit Ok
Use the arrow keys and select FUSER SC RESET and hit Ok
Hit OK again at the Execute prompt.
Once it is done executing the reset, power the unit off and on.
If the error comes back again, it is likely a real hardware problem and you may need to replace some components.
I have aficio spc 232, when powering on, it stays displaying initialization message and never comes redy.
Please any one can help me to solve this problem.
u got to unscrew the scanner a bit and arange the adf left or right depending your line position. the adf is not positioned perfect on the machine , and at the end it scan the adf back , thath is the line come from on your scanned document
