20 Most Recent
Brother MFC-7820N All-In-One Laser Printer Questions & Answers
Brother MFC 7820N Smudging Concern
If smudged stains appear at the top center of the printed page:
- Make sure the paper is not too thick or curled.
Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
- Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
- Make sure the printer platen is not dirty with ink.
How to clean the machine's printer platen
- Unplug the machine from the AC power outlet.
- Lift the scanner cover until it locks securely in the open position.
- Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
- Close the scanner cover.
- Make sure you are using Genuine Brother Innobellaâ„¢ Ink.
> Brother Genuine Supplies information
- Make sure you are using the paper support flap.
To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
9/14/2017 6:26:49 PM •
Brother...
Answered
on Sep 14, 2017
I have a 7820N. I put in a new drum in January
Hi There,
When you installed your new drum did you reset the drum by.
1 - Opening the front cover.
2 - Press the options button up on the panel.
3 - Press 1 to reset
4 - Close the front cover done.
If the issue persists after resetting your drum contact brother technical support you may have a defective drum unit.
Thanks,
Viper1969
10/19/2015 4:25:09 PM •
Brother...
Answered
on Oct 19, 2015
Brother MFC 7820N, I am getting "Toner End Life"
I fail to see why you are covering up the toner sensor led's when you have a new cartridge fitted?
Also if you are using a recycled toner from a very well known uk shop that refills toners and ink then you may well have broken the drive gear that stirs the toner. i have seen this six times and their toners do this.
It could well be one of the pitfuls of recycled toners.
7/24/2011 6:15:07 PM •
Brother...
Answered
on Jul 24, 2011
Pulling multy sheets of paper
Try fanning the paper before putting it in the printer. Try a paper from fresh (new) **** of paper. Try a different brand of paper.
7/18/2011 4:27:16 PM •
Brother...
Answered
on Jul 18, 2011
I have a Brother MFC-7820N.
Replacing the unit might not still solve the problem, because sooner or later, you will still face this same problem again, i will advice if you can discard or sell the stock on the unit you still have at hand and adhere or go for a better option that will be cheaper in maintenance, this will save you alot of stress and money by so doing, but replacing the unit might still bring you back to square one again.
And on the MFC 7840W, you are still required to adhere to their maintenance instruction, otherwise, you will face same problem.
Take care.
10/9/2010 4:12:29 PM •
Brother...
Answered
on Oct 09, 2010
My printer is stuck on phone it is a brother 7820N
Normally it says telephone if you are on the telephone letting you know that the line is in use.
If your not on the phone and says telephone, push the hook button, it should go back to normal screen
9/28/2010 4:12:02 PM •
Brother...
Answered
on Sep 28, 2010
How to email scaned documents via MS Outlook 2007,
You need to open up Control Control Center.
CLick on start, all
programs, brother, and then control center 3. Once the program has
openned, click on configuration and chose scan then email, you can
change the email application from here with the drop down list and can actually make any other
change you wish. Make the same changes in the device button tab.
4/21/2010 1:29:12 AM •
Brother...
Answered
on Apr 21, 2010
How do I increase the number of rings on my
Setting the Ring Delay
The Ring Delay sets the number of times the
MFC rings before it answers in Fax Only or
Fax/Tel mode. If you have extension
phones on the same line as the MFC or
subscribe to the telephone company’s
Distinctive Ring service, keep the Ring Delay
setting of 4.
(See Operation from extension telephones on
page A-4 and Easy Receive on page 4-3.)
1 If it is not illuminated in green, press
(Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many times
the line rings before the MFC answers
(00 - 04).
Press Menu/Set.
(If you select 00, the line won’t ring at
all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
4/2/2010 7:42:50 PM •
Brother...
Answered
on Apr 02, 2010
Brother MFC 7820N Printed paper has toner ink
you can remove the toner and drum from the machine, slide the tab back and forth about 20 times then blow in the slot. when you put it back in the machine if the problem keeps happening it would be a problem with the toner cartridge and it would need to be replaced
the reason this happens to toner cartridges is because the rubber roller tarts to wear out.
3/31/2010 5:10:29 PM •
Brother...
Answered
on Mar 31, 2010
MFC 7820n 'close back door error'
Hello Daysinn,
The "back cover open" message is usually caused by a paper jam inside the printer.
Follow these steps to rectify the problem.
1. Unplug the power to the printer.
2. Open the back and front cover.
3. Remove the drum and toner, this may be difficult because it may be stuck; don't be afraid to pull hard, you wont break anything.
4. Check for any foreign objects, most likely a peice of paper.
5. Reinstall the drum and toner.
6. Make sure to close the front and back covers.
7. Turn the power back on.
If the message stays after all this, there may be a sensor not working.
Thanks,
Pat
3/25/2010 10:17:41 PM •
Brother...
Answered
on Mar 25, 2010
Will not print from the computer brother MFC 782on
Hi there
It may be the driver software try add and remove it and reinstall it again leave the USB lead out in till it ask you to put in when installing the driver.
I have put a PDF files on my website for you to download just incise you need one.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Brother-DCP-7010L-DCP-7025-MFC-7225N-MFC-7420-MFC-7820N-Manual.pdf
You will need an adobe reader to see this file if you not got a Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best
: Pineworks
All files on my website are only there for a limited time.
3/13/2010 11:56:42 AM •
Brother...
Answered
on Mar 13, 2010
