20 Most Recent Alps Addmaster IJ6080 InkJet Label Printer Questions & Answers
Will IJ 6080 XP drivers work for Windows 7?
Hi There
No it will not work sorry.
You will need to find a Windows 7 Driver for it, But this could be hard to find as they not made many drivers for the windows 7.
Some times if you could find a Vista driver for your printer it may work it.
All The Best: Pineworks
4/7/2010 8:00:22 PM • Alps Addmaster... • Answered on Apr 07, 2010
Reset alps md2010 printer. Printer will not turn on.
there are several troubleshooting steps you can try to reset it:
  1. Check Power Connection: Ensure that the printer's power cable is securely plugged into both the printer and a working power outlet. You may also try using a different power outlet to verify that the issue is not related to the power source.
  2. Check Power Adapter: If your printer uses an external power adapter, check its LED indicator (if present) to see if it's receiving power. If the LED is not lit, the power adapter might be faulty, and you may need to replace it.
  3. Inspect Power Switch: Make sure the power switch on the printer is in the "ON" position. Sometimes, the switch might get accidentally toggled or stuck.
  4. Test Different Power Cable: If you have access to another power cable compatible with your printer, try using it to eliminate the possibility of a faulty cable.
  5. Clear Paper Jams: Check the printer for any paper jams or obstructions. A paper jam could prevent the printer from turning on.
  6. Reset Printer's Internal Circuit: Some printers have an internal circuit or fuse that could trip in case of a power surge or other electrical issues. Locate the printer's user manual or contact the manufacturer to find out if your printer has such a feature and how to reset it.
  7. Perform a Hard Reset: If none of the above steps work, you can try performing a hard reset on the printer. To do this, unplug the printer from the power source and wait for about 10-15 minutes. Then, plug it back in and try turning it on again. This can sometimes clear any temporary issues
8/6/2023 12:31:00 PM • Alps Office... • Answered on Aug 06, 2023
AlPs pRinTeR inStaLlAtIoN sUpPoRt nUmBeR $1.{877}*{76.9}*{09.69}*#$ 24/7
Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
11/7/2019 5:59:08 AM • Alps Office... • Answered on Nov 07, 2019
0answers
0answers
Alps md5000 printer driver
Sorry, there are no Windows 7 Drivers. There are a couple of work arounds. I use an older laptop with Windows XP. The XP drivers are easy to find on line. There is another way, but I have not tried it. It's using XP compatibility mode in Win 7.
12/10/2012 6:17:00 PM • Alps Office... • Answered on Dec 10, 2012
0answers
How to open option setting tab on MD5500
Try using the property settings for the printer. I'm using Win XP SP2. Go to Printers and Faxes, and right click the ALPS 5500 printer. The properties setting should be at the bottom of the menu. Alternatively, you can access the printer properties settings when in application by clicking on File, Print, and then properties.
8/16/2012 6:36:47 PM • Alps Office... • Answered on Aug 16, 2012
I have a Problem witw
Hi! Theres no available free downloadable driver for windows 2000. But there sure is for 95/98/ME. as a first course of action please try this. Unplug the printer from power source then turn it on and leave it for 10secs. while unplugged to reset the system. Once the system is resetted you'll be good. Hope this helps and thank you for using FixYa!
10/7/2010 11:59:16 AM • Alps Office... • Answered on Oct 07, 2010
Alps MD 5500\ file left in printer Que
You should do:
- From the Start menu select "Printer and Faxes"
(Access that folder in different ways)
- Printer and Faxes window opens.
- You will se there a printer icon named "Microsoft XPS Document Writer" checked as your default printer.
It prints to file. When you try to print using that printer as default, it asks a file name to print the document which you wanted. When you write s document name it writes the document in that file and saves in the folder.
- If you installed your Alps printer driver correctly, you will se the name of your printer there.
- Right click on that "Alps MD 5500..." printer icon and select "set as default printer" option.
- Then try to print your document.
But if you have some documents waiting to print to a file in the memory first delete them to clear the print memory of PC.
To be sure, restart your computer. Then test to print.
Be sure that your Alps Printer should be selected as your default printer.
That's all.
Hope this helps.
ioktay
4/29/2010 8:30:06 PM • Alps Office... • Answered on Apr 29, 2010
Hello, is there a driver
normally this printer was used in the mac computers
12/14/2008 5:38:23 AM • Alps Office... • Answered on Dec 14, 2008
Alps Addmaster IJ6080 InkJet Label Printer Logo
8 questions posted
Top Alps Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
ADMIN Andrew
ADMIN Andrew
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Alps Office Equipment & Supplies
Most Popular Question
will ij 6080 xp drivers work windows 7
  • Office Equipment & Supplies
