What happens when you tried to plug-in SD card to the computer?
Have you made any recent changes to the computer prior to the issue?
To make the SDHC be recognized by the computer, we need to ensure that the card reader works in Windows 7 first. Please check if the card reader is recognized properly by the computer and you have installed the driver for it.
Meanwhile, you can plug some other storage cards to the card reader and see how it works.
I would suggest you to refer the link belowA Secure Digital (SD) card may not be recognized on a Windows 7 based computer.http://support.microsoft.com/kb/981642
Uninstall all the Generic USB drivers and reinstall.
1. Open Device Manager.2. In "Disk Drives" dropdown, uninstall the "Generic SD/MMC USB device" drive.3. Restart computer.4. Insert SDHC card.
Hope this helps.
Test all power and data leads that attach to your hard drive IDE,SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty or just replace them they could be faulty motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs
power and data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
you might not have enough computer ram
not having enough computer ram will run your computer over its limits putting to much strain on the CPU central processing unit and can cause memory dumps
you might have to many programs trying to or accessing the internet at the same time scroll to bottom toolbar (bottom of screen) right click select task manager applications you will see whats running if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be jamming up your computer also under processes see what is ticking over in the background again if you see something you dont need to be and users you will see who is using your computer you might need to add more computer ram if you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
11 questions posted
52 Questions
44 Questions
42 Questions
29 Questions
