20 Most Recent eMachines W3115 PC Desktop Questions & Answers
Turn off computer. Turn on computer and tap the F5 key once every second. A login in screen should pop up. Select safe mode with networking.
This should boot computer into safe mode. Run anti-virus software from there.
Hope this helps
eMachines W3115 ... | Answered on Mar 07, 2018
Free antivirus is only available with microsoft security essential
you can download from microsofts official website
eMachines W3115 ... | Answered on May 28, 2014
ANSWERD.
eMachines W3115 ... | Answered on Dec 07, 2013
There's no reason to flash your BIOS they rarely add enhancements to BIOS's usually just bug fixes. Plus it's dangerous to flash it unless you know exactly what you are doing if you half flash something then it's toast flash is either all or nothing.
Have you installed the Audio, Chipset, VGA, drivers ????
eMachines W3115 ... | Answered on Apr 14, 2013
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm Testing & replacing the PC's power supply http://www.youtube.com/watch?v=hbNxhvm0czs One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ http://www.youtube.com/watch?v=du0Qd_3wFWM There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty although very rare for sata lead to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
eMachines W3115 ... | Answered on Mar 11, 2013
Contact emachines
eMachines W3115 ... | Answered on Jan 11, 2013
The beeps are possibly post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in. Open computer and reseat memory Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer. Swap memory location If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory. Try another computers memory Test all power and data leads that attach from motherboard to your hard drive IDE SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty If its a flat 40 pin ide it will be the first to fail. Check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it Restart your computer the found new hardware wizard should activate a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function Make sure all leads that are attached to your drives dvd\cd and floppy drive have secure make sure the connections and are not faulty or just replace them they could be faulty Computers need all Power and Data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error also check the keyboard for secure dust free connection ps2 and or usb
eMachines W3115 ... | Answered on Jan 05, 2013
defrag periodically, and dump your temp internet files on a regular basis.
eMachines W3115 ... | Answered on Feb 23, 2012
Try replacing the motherboard's battery, it might be dead.
eMachines W3115 ... | Answered on Feb 20, 2012
sounds like a bad power supply... get one from newegg.com they are easy to replace, it will only plug in to the place it is supposed to.... check wattage out put and get same or higher
eMachines W3115 ... | Answered on Oct 14, 2011
You are having what is called a BSOD(Blue Screen Of Death). Usually it is software related but in your case if it's not booting up then you have a hardware malfunction. Check your motherboard for any missing cables. Chances are you will have to get a replacement for your motherboard.
Have fun :)
eMachines W3115 ... | Answered on Aug 14, 2011
Press CTRL + ALT + DEL - the Task Manager should appear. If it does then click File, New Task (Run) and type explorer then hit enter, it should return to normal.
If the Task Manager doesn't appears or Explorer doesn't starts then the system is severely corrupted, you will have to reinstall Windows using the recovery cd.
eMachines W3115 ... | Answered on Jul 27, 2011
try hooking it up to an external monitor through your vga jack and see if the sceen appears on the external monitor first. if so then its most likely a bad back light on your laptop screen or inverter
eMachines W3115 ... | Answered on Jun 23, 2011
Have you checked your display settings in the control panel. Check the device manager also to see if any of the drivers are incorrect, but it sounds like the screensaver is starting up and it's a blank screen or something like that. What O/S are you running? WIndows and what version?
eMachines W3115 ... | Answered on Jun 13, 2011
If you still have the original eMachine software as your desktop, go to Start > system Recovery > Create my Drivers and Application CD disk.
This will create a CD that will contaon all the drivers for your eMachine.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
eMachines W3115 ... | Answered on May 25, 2011
should be easy to pop it out unless it is soldered in, usesualy they are the cr2032 type button batteries, open case and look on the mobo . push back the little metal tab and it will pop up
eMachines W3115 ... | Answered on May 20, 2011
1) Computer off, and unplugged from power. (Unplug from the surge protector FIRST, then unplug the power cable out of the power supply)
2) Work on a table where you have plenty of room.
Open the computer case.
(Rear of computer, there is a thumbscrew midway up on the right side, or two thumbscrews. Loosen it/them all the way. {Turn to the left)
Pull the side cover towards the back of the computer about an inch, then it tilts out at the top. Remove the cover, lay it aside.
NOTE*
BEFORE you reach inside your computer you need to relieve your body of Static electricity.
Static will fry out, (Short circuit), the delicate computer hardware components inside your computer.
All you have to do is Touch the metal frame of the computer case.
Power unplugged from the computer, you are safe.
TOUCH the metal frame of the open computer case, your computer is safe. (Not shouting)
3) It looks as though the motherboard may not have to be removed, in this instance, to view the Electrolytic Capacitors I have in mind.
Not trying to insult your intelligence in any way. I may explain in some pretty simple terms.
Looking at a side view of your computer with the side cover removed from the case, rear of the computer to the left, view the Black processor fan.
The specific capacitors I would like you to scrutinize closely are the tall ones to the left of the Processor fan. (Heatsink is under the fan, and sits on the Processor, which is hidden from view)
There are 7 in a row going vertically.
What you are looking for.
(Edit: My apologizes. I meant to include a link for, Visual Signs of Capacitor Failure with my previous Clarification post. I see that I failed to do so.
Will not fail this time)
Construction of Electrolytic Capacitors:
Electrolytic Capacitors are constructed with three layers rolled up tightly, and inserted into a thin, small aluminum 'Can'.
Each layer is a thin strip.
1) Thin strip of metal which is a Conducting strip.
2) Thin strip of metal with a non-conductive medium applied to it, which is a Non-conducting strip.
3) Thin strip of paper which is soaked with an Electrolytic paste.
The thin strip of paper is laid in-between the two metal strips, and the entire affair is rolled up tightly.
The Conducting strip, and the Non-conducting strip have metal terminals attached to them.
These terminals protrude out of the bottom of the 'Can'.
The Can is open on the bottom, and has a seal.
The seal is composed of a rubber like material, and is a flat, round, shaped disk.
The terminals protrude through this seal.
The top of the Can is flat, and has a slot shape etched partially into it.
The slot shape is generally a lK or an X.
[The particular style of construction stated above for Electrolytic Capacitors, is used for computer motherboards, and power supply's. They are used elsewhere in the electronics industry, but our scope will only deal with computer motherboards, at this time)
When the Electrolytic paste breaks down, it develops a gas. Hydrogen gas. This gas expands, and pushes against the seal at the bottom of the capacitor, and the etching at the top.
When too much pressure is developed, the paste is pushed out, in a slow ooze.
The seal at the bottom of the capacitor can be compromised, as well as the etching at the top will split open.
When the seal is compromised, one edge of it is usually pushed down, and out. This has a tendency to make the capacitor lean to the opposite side. Also you may view paste oozing out.
The paste is usually a brown, to brownish yellow in color.
When the etching at the top splits open, the paste also oozes out.
Before this state is reached, the top of the capacitor may simply just bulge up, as well as the sides.
This is Visual Signs of Capacitor Failure,
http://www.capacitorlab.com/visible-failures/index.htm
The motherboard is made by FIC. (Federal International Computer)
Model K8MC51G
http://www.fic.com.tw/product/motherboard/AMD/K8MC51G.aspx
Gives you a better view of those Cap's without any hardware in place.
The capacitors should be above 1100mfd. (Microfarad)
Probably around 1600mfd.
Voltage? 16 volts.
As you can see I don't know for sure.
Electrolytic Capacitors can also have the Electrolytic paste dry up inside. There is no obvious signs of visual failure for this.
Check them out with a digital multimeter? They have to be removed to obtain a true reading.
Replace them?
Sure it's possible. Do you have good soldering/de-soldering skills? Proper equipment?
Parts availability? They are out there.
Not advertising for Radio Shack, but you may want to check with them, for one.
Would the best logical move, be to replace the motherboard due to possible Processor failure?
Not IMHO.
The Electrolytic Capacitors that surround the Processor are Voltage Regulators.
If they start going bad, or fail, the Processor won't receive the DC voltage it needs, and BIOS will turn the processor off.
A Processor must receive a steady, 'Clean', supply of DC voltage. It has to be within a very tight tolerance range.
The Processor should be good.
If the computer has been dirty inside, (As well as the Power Supply), then this means the Processor fan, and Heatsink has also.
If a Processor becomes too hot, (Goes past it's thermal limit), BIOS turns it off.
This is a Fail safe feature that is built-in.
If this happens too many times will it hurt the Processor?
I can't actually answer that.
It is a logical assumption that it would.
To come back to your statement, to me IMHO, the logical move would be to use that motherboard for a Frisbee.
(LOOK OUT!
Whoa, did you see the air I got with that mobo?)
Aftermarket AMD motherboard/Processor combos are Cheap! (Price wise, not quality)
Should explain a little. The AMD Sempron has been affectionately termed 'Sempy'.
Your eMachines W3115 Desktop PC has an AMD Sempron 3100+. Operates at a 1.8GHz maximum frequency rate, and has an 800MegaHertz Front Side Bus. {800MHz FSB}
This part isn't so bad.
The 512KiloByte cache - IS! {512KB}
Much better motherboards, and processors out there available as a combo.
It's a Micro-ATX form factor motherboard. Has a Socket 754 processor socket.
(A Micro-ATX motherboard is 9.6 inches by 9.6 inches in size.
Roughly 9 - 9/16ths inches by 9 - 9/16ths inches, or
244mm by 244mm)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5567180&CatId=2417
Just an example, not an advertisement for said website.
You will need different ram memory, however.
As for doing a diskcheck, I'll let the person who brought it up give the full solution to that.
eMachines W3115 ... | Answered on Apr 18, 2011
crazystevens
To clarify with you did you actually do the system restore of the system back to the factory image or just to a restore point.
Also what games are you trying to play. If they are online games you may need to have your Active X settings adjusted for the game and installed the versions of JAVA that the game requires.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
eMachines W3115 ... | Answered on Jan 13, 2011
eMachines W3115  PC Desktop Logo
Popular Tags
40 questions posted
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
W eMachines
  • W eMachines
Most Popular Question
need drivers emachines w3115 pci simple
  • Computers & Internet
