20 Most Recent eMachines T5224 PC Desktop Questions & Answers
Download link http://filesmy.com/2o95a4 for SpeedyPC Pro License Key.
eMachines T5224... | Answered on Apr 05, 2014
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentials
once you have your computer running or you could do this in safe mode
press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might still have a virus
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatability before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU
try uninstalling a few unnecessary programs
this should speed up your computer
hope it helps
eMachines T5224... | Answered on Oct 07, 2012
Beeping vary with each manufacturer, but verify if your wires are firmly connected (keyboard, mouse, video, etc.) If problem cotinues, then verify computer memory, you need to open it, and unplug/plug each memory card, sometimes just one are damaged, so... try each one alone.
eMachines T5224... | Answered on Sep 27, 2012
sound software error re install sound driver
eMachines T5224... | Answered on Aug 02, 2012
make sure the boot order is starting from your hard drive the directions on how to change your boot order usually vary depending on what version of bios you have but they are usually self explanatory.
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
this changes the boot order and see if that solves your problem if not you will need to replace your modem I do hear that a modem can also cause this.
hope this helps
eMachines T5224... | Answered on Jul 23, 2012
For an eMachines T5224 Desktop PC?
The eMachines T5224 Desktop PC uses an Intel 945GCL motherboard,
http://www.ebay.com/itm/Intel-D945GCL-AA-D67193-203-Socket-775-MOTHERBOARD-/130713275248?pt=AU_Components&hash=item1e6f1e4b70
(Not advertising for the seller, or the website. Just posted for reference)
Motherboard Manual:
Intel Support > Intel D945GCL motherboard > Main Support page,
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d945gcl
Go down to the subheading - Documents and Guides. (And -> is an Ampersand)
In the list under this subheading click on - Product guides
On this page click on the blue -
Intel Desktop Board D945GCL Product Guide - English (PDF)
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
[Took 10 seconds just now, using a medium speed DSL connection ]
The PDF file page number box is in the Top header, and is to the right of the Down Arrow.
The Zoom In icon ( + ) increases the view size, when you click on it.
The Zoom Out icon ( - ) decreases the view size.
IF you know the page number you want, you can use the Down Arrow to go page, by page to it, Or;
1) Put your mouse cursor in the page number box. Left-click once.
Anything in the page number box is now highlighted in blue.
2) Type the page number you want.
3) Press the Enter key.
Go to Page 11.
Shows an illustration of the motherboard. The view shown is actually 90 degrees to the right, in comparison to how it actually sits in the computer case.
[In the computer case; the Processor is to the Top, Ram memory slots to the Right, and long white PCI slots are to the Bottom ]
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
It may have F_PANEL, or FP1, or the equivalent, silkscreened on the motherboard next to it.
In the illustration on Page 11 the letter V, points to the Front Panel header.
Motherboard mounted in your computer case, the Front Panel header is at the Bottom/Right corner.
Two rows of pins, and the area around them is color coded, for where the wires are supposed to attach to, from the Front Panel.
Go to Page 43.
Looking at the Front Panel header, there are two rows of pins. (Already stated, I know)
The TOP row is numbered ODD.
Starting at the RIGHT side of the header, (Or motherboard), and going towards the LEFT side;
Pins 1, 3, 5, 7, and 9.
The BOTTOM row is numbered EVEN.
Starting at the RIGHT side of the header, going towards the LEFT side;
Pins 2, 4, 6, and 8. There is NO pin 10. Just a blank spot.
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
IF the HDD activity LED light is dim when the Harddrive is active, switch the two wires around.
B) Pins 5 and 7 are for the Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It is/was used for the factory.
D) Pins 2 and 4 are for the Power On LED (Light)
E) Pins 6 and 8 are for the Power On switch.
There is no Pin 10.
For additional questions please post in a Comment.
Regards,
joecoolvette
eMachines T5224... | Answered on Jul 02, 2012
is the network adapter onboard or an add-on card. if it's an add-on you may have accidently unplugged either the card or the cord when installing. if it's onboard you should go to device manager and see what IRQ's the hard drives and the network adapter are using, they may be conflicting, if that's the case just change one of them to something different.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
eMachines T5224... | Answered on May 18, 2012
Depends on where the password is.
If its just after PC switch on then CMOS battery will have to be removed AND mobo CMOS clearing jumper used.
If its just before window starts, you will need to reboot into safe mode and click on control panel, passwords and sometimes gain Admin control from there.
eMachines T5224... | Answered on Mar 09, 2012
hard drive failure, possibly due to a virus, go buy a new harddrive and install windows on it and be careful, you can re-route your old harddrive by switching the pins to slave and then connecting it to the pc while off and unplugged after installing new hard drive and windows. then you can access your photos and such on the old drive before opening the old drive in windows scan the whole drive with a virus software.
eMachines T5224... | Answered on Dec 13, 2010
hello is this a power on password or a harddrive password?
eMachines T5224... | Answered on Dec 12, 2010
You stated that it loads that OS on the other computer. Is this by taking out the hard drive and putting into another PC? If it is, then I would have thought there is h/w issue elsewhere in your PC...
Usually if you have a message saying that it could not load windows properly, it is an OS issue which I would recommend you fix by using your emachines recovery disks.
Hope that helps
eMachines T5224... | Answered on Nov 12, 2010
if that is a windows error recovery screen and wont boot up, try perform safe mode with networking by repeatedly press F8 after restarting the pc Then click start > run > type msconfig. Then select general and select Selective start-up. Then check all the boxes under that. Hit apply and OK. Then restart the pc.
eMachines T5224... | Answered on Nov 01, 2010
hi, probabily the procesor fan does not works , other options is your opering sistem is bad, format and reinstall windows , other option is your hard drive is bad , try with another hard drive
eMachines T5224... | Answered on Aug 12, 2010
You can download an OEM version from bittorrent sites, and as long as you have the genuine certificate of authentication label on the pc case you can install and activate it legally. Just make sure you get the correct version to match the label, e.g Home or Professional.
eMachines T5224... | Answered on Oct 10, 2009
This can happen from an executable or other system files failing to load properly such as a video driver, etc. Try booting into safe mode by pressing F8 on start up. Also on rebooting enter system configuration and set the start up option to first boot from CD then USB, and finally Hard drive. This should then allow you to install from CD. Then put windows CD in drive and when you reboot you should see boot from CD press any key, located in the upper left of your screen be fast as this is only displayed for about 5 seconds. I have had similar problems and this has worked.
you have to have an antiviral program I would suggest CA as it is very efficient and not dear to buy.
eMachines T5224... | Answered on Sep 26, 2009
Power up your computer
start lightly tapping F8
It should bring up a menu, if not power down and try again
At the menu, choose SAFE MODE
Once the login screen displays, choose ADMINISTRATOR ( if that isn't an option, see below)
Hopefully, it logs you in, if it does;
click START
click RUN
In the box type CONTROL USERPASSWORDS2
Highlight your username and click RESET PASSWORD button.
Type in your new password twice, reboot and tada!
eMachines T5224... | Answered on Sep 25, 2009
if you have the disc that come with your computer get the drivers from there.
eMachines T... | Answered on Nov 18, 2016
Guessing, but it sounds like your hard drive has been damaged. You may need a new drive, or at least repairs. If you have a "rescue disk", give that a try.
eMachines T... | Answered on Sep 05, 2015
Here's a video on how I fixed my emachines boot problem. Almost anything can get in the way of your computer booting. Software, hard drive, RAM, motherboard, processor, etc. Below the video, I attached a link to a tip I made about computer crashes. Computer Crashes and Electrolytic Capacitors
eMachines T... | Answered on Jul 01, 2015
eMachines T5224 PC Desktop Logo
Popular Tags
21 questions posted
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
T eMachines
  • T eMachines
Most Popular Question
need speedypc pro license key
  • Computers & Internet
