20 Most Recent Sony VAIO VGC-LV180J 24-Inch All-in-One PC Questions & Answers
I have a Vaio all in one. I had a USB flash drive in a port, and when I removed it the screen on the computer went blank. I have put the system to sleep , the start up works fine, the screen works, bu
Try to start the system in safe mode and see if that works if so it is not the screen. To enter safe mode press F8 during boot up after the bios screen.
5/31/2019 3:46:06 PM • Sony VAIO... • Answered on May 31, 2019
Sony vgc lv1s date and time revert back to 2007 if power is unplugged
Your PC has a battery installed on the Mainboard that needs to be replaced. Its about the size of a watch battery. You can match the alpha-numeric model number to one at CVS or Wall-greens. Unfortunately though your model is an All-in-one model and you must disassemble the device to get to the battery. There are three options available to you at this time.
  1. Contact a PC service center to have the battery replaced. Shouldn't cost more than $50-75.
  2. Have faith in yourself and systematically disassemble the unit until you get to the battery. (NOTE: If you have 0 experience opening electronics this may not be the best option. If you are handy with a screwdriver however, this may turn out to be a rather intriguing experience. Remember, make sure you have plenty of open clean space, keep up with screws and where they came from (some are diff lengths and thread pitch.) and never work on anything until the power has been removed for a few minutes. Capacitors within the system can hold as much as 10K volts...enough to stop a mans heart. Although many will naturally drain power over the course seconds, some may take minutes)
  3. Download and install an application similar to BetaClock, which will re-sync your clock on startup.
Below is a photo of you Mainboard to help you with identification. bc06fce7-472a-477d-a509-a9c0f5ba7015.jpg Hope this helps, and please rate this post!!! KENNETH CALHOUN
2/18/2014 4:24:08 PM • Sony VAIO... • Answered on Feb 18, 2014
Cmos battery
It`s on the motherboard
2/18/2014 1:58:42 PM • Sony VAIO... • Answered on Feb 18, 2014
0answers
Computer keeps zooming in on its own
Replace your keyboard. My guess is something got spilt on the control key on your keyboard and now it is sticking.
12/5/2013 4:47:23 PM • Sony VAIO... • Answered on Dec 05, 2013
My computer won't turn on
If the logo comes try vaio recovery. Else service is the available option
11/23/2013 10:04:44 PM • Sony VAIO... • Answered on Nov 23, 2013
Operating system not found on sony all in one pc
could be a virus or a hard drive problem try repairing the o/s using repair disc if one came with the pc if not try to ask friends if they have one. Just make sure it is the same o/s originally installed
11/7/2013 6:52:59 PM • Sony VAIO... • Answered on Nov 07, 2013
Spillled soda on keyboard now frozen
FROZEN as in the Keys are sticking or FROZEN as in nothing is working?You need to take the Computer keyboard apart and clean it
4/12/2013 12:28:59 PM • Sony VAIO... • Answered on Apr 12, 2013
Sony vaio touch screen stopped working
XP and Vista Normal Mode Start your computer as you normally would. Click the "My Computer" icon on your desktop. Go to "C:\ Program Files\Sony\Setting Utility Series." Find and choose the "VCCPointingDevice" folder in the "Setting Utilities Series folder" to open the "Built-in Pointing Device" dialog box. Locate the "Enable" box on the "Built-in Pointing Device" dialog box. Check the box to enable the Vaio touchpad if you wish to use this device. Disable the touchpad if it is interfering with the external mouse. Uncheck the "Enable" box if you have a USB (PS/2) mouse connecting to your Vaio and wish to use that instead of the built-in touchpad. Pick "Yes, I'm Sure" when prompted to activate your choice, then close all the windows. Windows 7 Normal Mode Launch Windows as usual. Go to "Start" > "Control Panel" > "Mouse" > "Pointing Device" to open the Vaio touchpad control center. Uncheck the "Enable" box on the "Pointing Device" window when you wish to use your external mouse. Check the "Enable" box on the "Pointing Device" window when you want to use the Sony Vaio touchpad. Make sure the external mouse is not interfering with the touchpad if you have one connected. If so, unplug the mouse from your computer. Click the "OK" button at the bottom of the "Pointing Device" window. Close all other windows. XP and Vista Safe Mode Restart your computer. Press the F8 key before the Windows welcome screen appears to enter Safe Mode. Click "Start" > "Control Panel" > "Add/Remove Programs." Find and delete all software for mice and pointing devices. Restart your computer in normal Windows mode. Proceed to next step if the problem persists. Restart your computer in Safe Mode. Right click the "My Computer" icon on the desktop. Choose "Properties" on the drop-down list. Pick the "Device Manager" tab in the Properties window. Select the "Other Devices" folder and click on the "+" sign besides it. Delete all the devices under this "+" sign by clicking on the "Remove" button next to each of the items. Restart Windows in Normal Mode. Once Windows is operating, there will be a "New Hardware Wizard" pop-up that will load all the necessary drivers for the touchpad, mouse and other pointing devices. This should fix the corrupt driver for your Vaio touchpad. Windows 7 Safe Mode Reboot your computer and press the F8 key before the Windows welcome screen appears to enter Safe Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Click the touchpad icon. Choose the "Driver" tab and press the "Uninstall" button. Press the "OK" button to confirm. Restart Windows in Normal Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Choose the "Driver" tab and press the "Update" button. Press the "OK" button to fix the touchpad software. http://esupport.sony.com/perl/swu-list.pl?mdl=PCGFRV26
2/8/2013 8:45:02 PM • Sony VAIO... • Answered on Feb 08, 2013
Sony vaio vgc-lv1s keyboard and mouse not connecting
Disconnect all devices from your PC including usb mouse and power adaptor.
Press power button and hold it for 20 seconds.
This will statically discharge teh PC. THen take out batteries from the keyboard and pres connect button to discharge keyboard.
When this is done connect pc to the mains and turn it on
Put batteries into keyboard and try to connect.
Press connect button on the pc first and then within few seconds press connect button on the keyboard.
Please leave your feedback if issue is solved or you need futher assistance
3/27/2012 8:40:01 AM • Sony VAIO... • Answered on Mar 27, 2012
0answers
HOW DO I RESET MY PASSWORD ON MY SONY VAIO ALL IN
The best method is to use the Locksmith function on the ERD Commander 2005 toolkit download HERE unzip it then burn the ISO using Imageburn make sure that you import my AWS file prior to the burn as it contains the recommended write speeds for many brands of CD and DVD.
8/11/2011 9:20:32 AM • Sony VAIO... • Answered on Aug 11, 2011
I have the Sony Vaio VGC LV1S and have had the
I went to Sony and typed in your particular model and added mouse at the end and got some results.There are some refurbished ones but I would never recommend those.The one i do see is $30,probably plus shipping too.Do notebook mouses have a smaller plug attachment or something?You said you searched online.I would try office depot or staples if you already haven't and there is one near you.You can call and ask rather than drive there.Also,optical mouse is the best.So much better than the rubber roller,well worth it's weight in gold.Anyhow here is the link.Good luck! Greg
http://www.sonystyle.com/webapp/wcs/stores/servlet/SearchCatalog?storeId=10151&langId=-1&catalogId=10551&in_dim_search=&keyword=sony+vaio+vgc+lv1s+mouse&x=11&y=2
9/18/2010 7:28:14 AM • Sony VAIO... • Answered on Sep 18, 2010
2answers
Suddenly my Sony can't find my operating system
May i know the Operating system running on the computer? What is the error message that you get?
Try if you are able to login to safe mode via Windows advanced boot options by hitting F8 while booting.
Please update me as soon you can.
Regards
Riztech
8/31/2010 3:44:03 AM • Sony VAIO... • Answered on Aug 31, 2010
Loss of Wireless Keyboard/Mouse Connectivity Sony Vaio VGC-LV1S
check batteries
8/17/2010 3:33:58 AM • Sony VAIO... • Answered on Aug 17, 2010
A cd is jammed in the all-in=one drive it is in
there is a pin-hole switch in the wrong of the drive, that is designed to open the drive manually in case of loss of power, or if the drive door gets stuck. You can do the following to open it:
1. straighten out a paper clip, or small pin. you will use this to press the release.(note: make sure if you are using a pin, it isn't sharp! you want to open the drive- not puncture it)
2. locate the pinhole (usually below the drive door), and stick the pin/paper clip in there. keep pushing, and the drive door should pop open slightly.
3. using your hands, gently pull the door the rest of the way open, and retrieve your CD.
Hope this helps.
7/2/2010 1:15:35 PM • Sony VAIO... • Answered on Jul 02, 2010
Functions not working first time (but eventually does)
scan your computer with a good antivirus program. and try uninstalling unwanted programs
click on start- then click on run- then type prefetch, it will open a window for you delete all files.
click on start- then click on run- then type dllcache, it will open a window for you delete all files.
click on start- then click on run- then type %temp%, it will open a window for you delete all files.
6/2/2010 9:34:07 AM • Sony VAIO... • Answered on Jun 02, 2010
PC to Wireless mouse and keyboard connectivity issue
Hi!
Try checking your power management feature, there should be a tab there that enable/disables wireless capability to during power save mode...
Hope it helps!
2/19/2010 8:53:06 PM • Sony VAIO... • Answered on Feb 19, 2010
Stuck keys thanks to girlfriends Margarita.board
Not sure if this is different to a std keyboard but in cases like this I'd
Turn keyboard over, remove retaining screws noting position and order and take out the plastic membrane, wash thoroughly with mild detergent and dry thoroughly. Remove keys in turn, clean with warm water dry and replace. Any other stickiness an be removed with isopropyl alcohol or similar and a q tip or lintless cloth , gently clean. reassemble.
2/11/2010 10:47:33 PM • Sony VAIO... • Answered on Feb 11, 2010
Sony VAIO VGC-LV180J 24-Inch All-in-One PC  Logo
31 questions posted
Top Sony Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
pc wireless mouse keyboard connectivity
  • Computers & Internet
