20 Most Recent
Dell OptiPlex 740 PC Desktop Questions & Answers
How can I tell if my Dell 740 Desktop with cover release lever is locked.
Sounds like you are describing a binding issue with the latch.
From this video link, showing no physical lock in the latch handle hole, a good working case latch opens the cover easily.
https://m.youtube.com/watch?v=oKDzYhTfAXk#bottom-sheet
Tolerances changing on metal parts like slides can cause binding.
Sometimes a stuck case can be opened using gentle pressure, noting where you push, or tap on case around the mechanism as you put pressure on latch, trying to remember where you press in an organized way, so you don't repeat what doesn't work,
It's organized luck,
look in video how latch is constructed , turn case
To accommodate where gravity might help, small chance.
Why doesn't it boot?
You have to go back into the bios and make all the setting correctly match what you have for hardware.
How do i get the case to a dell optiplex 740 open
most dell pc,s have a button or a slide latch the button ore large on the top back edge some have one on top and one on the bottom . the slide latches are on the back looks like a on off slide switch usually near the the bottom about 4 or 5 inches from the bottom on the right side facing the back of the computer . But in your case i think it is screws holding on the side plate , find the finger slot and take the three srews off that side the plate should slide straight back and come off !
How to safe reboot a dell optiplex 740 to change password?
Restart your computer, and just before the Windows logo appear start tapping F8 on your keyboard. There should be a list of option appear on the black screen. Select the option "Safe Mode" by pressing Enter, wait till the loading. The screen should appear with two or more account including Administration account. login with its password and change the password from control panel
I forgot my password for my dell optiplex 740?
I think you are running on Windows vista or 7, in this case you have to remember the Administrative password. Reboot your PC and before Windows logo arrive press F8 couple of times, a list of option will arive, choose "Safe Mode" you should be able to login with an Administrative account. From there go to ccontrol panel> accounts .. delete the account and add a new one.
In case if you forgot the Administrative password you have to hack into the system and delete the account:
How To Reset Windows Vista Password
Key borad dont work on my 740
replace the keyboard with PS2 keyboard and try again! if that cannot do changes then your PS2 or USB port are dead!
5260 driver xp
try DriverBooster.com , it also come free with Advanced SystemCare7
Yellow light power button amber
Sounds like it may be in "sleep" mode. Try pressing the power button quickly (press and release). If that does not work just unplug the machine, wait 30 seconds and replug. Turn it on and see if that corrects the problem.
What is add-ingraphicscard
Your computer has an on-board graphics card, which is usually sufficient unless you're going to be playing Full HD games on your computer.
