20 Most Recent
Toshiba Satellite Laptop with AMD Athlon 64 X2 Dual-Core Processor QL-60 - Onyx Blue PC Notebook Questions & Answers
How to get bluetooth speaker to connect already apired and is showing but wont connect
Hello, I have already met this issue: after pairing a bluetooth speaker on a first host (computer or iPad), then pairing it on a second device (as another computer for example), when I try to pair it again to its original host device, it doesn't work.
The solution consist in
1) on the host computer, in the list of the Bluetooth devices, delete the line of the bluetooth speaker and forget this bluetooth device,
2) push on the Bluetooth detect button on Bluetooth speaker,
3) scan the bluetooth devices on your computer host, and when you see the bluetooth speaker in the list, select it.
11/21/2017 8:03:40 AM •
Toshiba...
Answered
on Nov 21, 2017
My toshiba amd x2 has
go to [computer]go to [system properties]go to [system protection]......
2/27/2011 2:56:22 PM •
Toshiba...
Answered
on Feb 27, 2011
I have a cracked window and would like to know how
You can go here to check out repair solutions for your laptop:
Toshiba Repair Center
You can also call their support center at:
1-800-457-7777
most likely you are going to have to ship it to them and they will have to replace the monitor for you (at a price). I don't think they will just sell you a replacement screen.
10/18/2010 11:16:57 PM •
Toshiba...
Answered
on Oct 18, 2010
Toshiba Laptop - Startup freeze 40% of the time.
its a common thing for a vista based system to freeze after some updates , and my good advice to you is you better dont place too many applications on the startup , and avoid unwanted updating , ie8 is one such thing . if u have an option better switch to windows 7 , its really fast on notebook computers . install only defender updates from windows.
7/5/2010 12:23:11 AM •
Toshiba...
Answered
on Jul 05, 2010
L355 Satellite Shows Toshiba Logo then goes to
You need your Vista disk to re-install Vista.
If you don't want to go to the expense, download and install Ubuntu, its a free opterating system and now on version 10.4, its pretty good.
5/5/2010 6:06:37 PM •
Toshiba...
Answered
on May 05, 2010
My laptop doesn,t have an audio after
Hello....
No Sound, No Volume Control, Mixer not Found…etc etc, This is a generic issue with Windows OS....many of the users are facing this issue....
1 - r u facing NO Audio/Sound issue...?
2 - is ur Volume Control not responding ?
3 - is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
if ur ans to any one of them is Yes...then u are being spammed by Microsoft....ur Sound Control IRQ is being frozen by a recent update from Microsoft....NOTE IMPORTANT...no file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it….
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service.
www+sureshayyar+110mb+com
Copy the above address in the browser, replace + with dots
all the best...
12/21/2009 2:57:28 PM •
Toshiba...
Answered
on Dec 21, 2009
Computer not taking fresh install of any operating system
The best method to follow is, First boot using the CD/DVD, format the partition. As soon as the OS is loaded for the first time, install AV and update it. The install some spyware tools like malwareantibytes. Then proceed installing other softwares. I suspect some of your back copy should have virus. This should help you
12/12/2009 3:47:06 AM •
Toshiba...
Answered
on Dec 12, 2009
Cant log in to Toshiba A300-1J1
What I would suggest is logging on in safe mode and trying to restore it to an earlier date using system restore. likely the profile is corrupted. By doing a restore back about 4 to 7 days , or before this started happening, will likely fix your issue. If not you will have to purchase the restore cd from toshiba or restoring it from a recovery partition if it has one.
7/4/2009 9:01:26 AM •
Toshiba...
Answered
on Jul 04, 2009
Toshiba screen press f2 for set up and f12 bios management
I guess a new software install could have caused the issue. The could be conflict between devices.
Remove all the USB devices connected to the laptop. Remove external mouse and keyboard also if any.
Try booting. If it still does not boot then restart system and keep pressing F8 to view the boot options. If you get the boot screen then choose Safe mode option and try booting in to the desktop. Once the desktop is available go to Start-> Accessories-> System Tools-> System Restore to restore your system to a previous date.
If F8 does not work then probably you can do a complete reinstall of the OS by pressing F11 or Ctrl+F11. You will lose all the data in the system using this option and the system will be restored back to its factory settings. (This option works only if the laptop has manufacturer provided OS in it)
else you need to contact Toshiba tech support for any hardware related issues
Hope it helps !
Good Luck !
7/2/2009 6:42:18 PM •
Toshiba...
Answered
on Jul 02, 2009
Lap top wont come up
then u shud contact your vendor and for more contact http://www.techbuddies.org
6/19/2009 7:11:30 PM •
Toshiba...
Answered
on Jun 19, 2009
Not starting up on turning on
If you have your operating system disk then you can put that in then turn your computer on and it should go to the drive and read the exe for the programs there.
6/3/2009 12:43:29 AM •
Toshiba...
Answered
on Jun 03, 2009
