20 Most Recent
Croton RC311065RGRG Wrist Watch Questions & Answers
Croton automatic watch, band problem
Unless you have the appropriate tools for the job, it is likely that you will mark or damage the links taking them out yourself - any reasonable jeweller will be able to perform this service, normally only costing a few dollars at most.
You could also return the watch to Croton to get this done if you prefer;
http://www.crotonwatch.com/contact_us.aspx
If you are still determined to do it yourself, then it is fundamentally just a matter of identifying the removable links (they will have a small screw head visible on the side), buy the correct size screwdriver(don't get a cheap one, it will do your watchstrap no favors) then it is simply a matter of unscrewing the link pins required, reassembling the pin where you wish to rejoin the strap - use loctite or similar to keep it from undoing, but be careful not to get this in the moving parts of the strap.
if you can post a close up picture of the removable links from all sides, then i could talk you through it in more detail.
Hope this helps :)
4/18/2007 4:32:19 PM •
Croton...
Answered
on Apr 18, 2007
I have a 2003 Croton Belagio watch How do I set correct date?
To set the date on your Croton Belagio watch, you will need to follow the steps for setting the date on your particular watch. Every watch is different, so the specific steps will depend on the make and model of your watch.
Here are some general steps that you can follow to set the date on your watch:
- Locate the stem (the button on the side of the watch) and press and hold it until the display begins to flash. This indicates that the watch is in time-setting mode.
- Use the stem to cycle through the different settings, such as the time, day, date, and year.
- When you reach the date setting, use the stem to adjust the value to the correct date.
- Once you have set the date to the correct value, press the stem to exit the setting mode.
If you are unsure of how to set the date on your watch or if you are having trouble, you may want to consult the manual that came with the watch for more detailed instructions. If you do not have the manual, you may be able to find a copy online or you can try contacting Croton customer service for assistance.
Changing battery in Croton silver dollar watch.
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
https://www.fixya.com/support/r27181038-changing_watch_batteries
