20 Most Recent Sony VAIO NS Series Notebook Questions & Answers
Depends on your operating system... go to Hardware Device Manager and click update driver or "Use this Device" etc
Another setting is in the Control Panel for Mouse
Please rate Fixya answers
Sony VAIO NS... | Answered on Nov 30, 2018
*You can download the driver here. Also includes drivers for windows Vista, Windows7 and preinstalled drivers.
*Chose which driver you want to install and download.Thanks for using Fixya.
What is the problem? Open the webcam software on your computer, CyberLink?, You can find a User Manual here: http://esupport.sony.com/US/p/model-home.pl?mdl=VGNNS190JS&template_id=1&region_id=1&tab=manuals#/manualsTab
Sony VAIO NS... | Answered on Jan 12, 2013
Is it list and enabled in Device Manager, Imaging Devices? What software are you trying to use with the webcam? Try reinstall driver for webcam found here: http://www.sony-europe.com/support/en/product/VGN-NS20S_S/updates
Sony VAIO NS... | Answered on Dec 12, 2012
I'm sorry to say that Sony does not make it easy to replace the hard drives in their laptops. you should probably consider getting it done professionally.
that being said if you are willing to chance it there are some good videos that can walk you through it:
http://www.youtube.com/watch?v=aKffewUFUnY&feature=related
Best of luck.
Nat
Sony VAIO NS... | Answered on Sep 20, 2011
For a New Hard Disk Recovery with the Sony Recovery DVD's, do a complete restore, and leave the SKIP button selected on the last screen when asked if you want to recover the C: Drive.
Sony are a bit wierd the way they work this step.
Try that anyway and failing this try entering the bios at boot up and making sure your time and date are right and try again.
Sony VAIO NS... | Answered on Jul 06, 2011
sounds as though there could be a stuck button perhaps on the keyboard? check all of the buttons for movement and operation. Sounds as though that may solve your problemif any of the buttons are stuck, you may be able to loosen it back or pry it up gently, if not then a replacement keyboard will be required
Sony VAIO NS... | Answered on May 05, 2011
The first issue sounds more like a microphone volume problem to me. In the control panel you should see an option to fix this under sounds, select your microphone and adjust the volume.
The second problem you might be able to fix it by looking for a white square icon(resembles the touchpad) on the taskbar, which is located next to the clock.
Sony VAIO NS... | Answered on Jan 19, 2011
If you remove the hard drive cover, underside of the case, the hard drive should slide out.
Sony VAIO NS... | Answered on Jan 01, 2011
Try the followings:
1. Make sure the wireless function is turned ON. It can be a small slide switch or it can be also be turned ON via built-in software utility. 2. Download and install the latest driver version for your particular system model
Sony VAIO NS... | Answered on Nov 26, 2010
HI, In that case I would suggest you enter the BIOS screen by either tapping Del or F2 as soon as you turn on the laptop and once you are in the BIOS screen do load the default settings by selecting the load optimized default settings option or tapping F9 key and then press F10 to save and exit.Now please try turning on the wireless switch you should be able to get the wireless to turn on.In case you still have issues please update the latest wireless drivers from the Sony website.
Thank you for your patience and best wishes for your effort.
Sony VAIO NS... | Answered on Nov 20, 2010
ONE: The 'tech' should have told you that the air intake port, and Fan/Heatsink assembly, needs to be clean inside that laptop.
TWO: The 'tech' should have recommended a laptop cooler, if it is known that the fan is too small in cooling capacity.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3486&name=Notebook%20Coolers
THREE: The laptop CANNOT be placed directly on a carpet floor, it must be on a hard flat surface. (Which means should not be placed on your lap)
Sony VAIO NS... | Answered on Oct 30, 2010
Reinstall the Memory Card Driver to resolve the issue.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNS190J&upd_id=3884&os_id=34
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNS190J&upd_id=3885&os_id=34
Sony VAIO NS... | Answered on Jun 24, 2010
Purchase either a USB or a PCMCIA wireless-adapter, install it, connect it, and use it, after "disabling" the built-in wireless-adapter.
Or, if your computer is still under "warranty", exercise the warranty to get SONY to fix it.
Sony VAIO NS... | Answered on May 29, 2010
the camera software that sony vaio vgn-ns190j/s uses is arcsoft webcam companion software..
1.uninstall the arcsoft webcam companion camera software from programs and feature
2.uninstall the camera driver from device manager
3.download and install the camera software from
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNS190JS&upd_id=3834&os_id=34
hope it works! goodluck ü
Sony VAIO NS... | Answered on Apr 10, 2010
are you using a messenger? because it depends on the settings of the messenger you are using (yahoo, msn, aol)
Sony VAIO NS... | Answered on Apr 09, 2010
Sony VAIO NS Series Notebook Logo
34 questions posted
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
describe sony vaio ns series notebook pc
  • Computers & Internet
