20 Most Recent Lenovo Elite ThinkPad R400 Notebook Questions & Answers
Contact Lenovo , proove ownership and they may be able to help with a code.
Lenovo Elite... | Answered on Dec 29, 2018
You need to type FN + F7
Lenovo Elite... | Answered on Jul 19, 2011
It could be that your computer has used up lots of memory. Try deleting some unessential files. It could also be your computer getting old. This happens when you don't update your computer everyday.
Lenovo Elite... | Answered on Jun 30, 2011
Hi techsyss,
I see that you are having issue with your taskbar flickering as you mentioned in the notes.
I would be more than glad to assist you regarding your concern.
>Try to reinstall your Video Drivers on the machine or poassibly update the Video drivers.
>Try chagning the resoltion on your system try setting it to a resolution that is lower than what you actually have and see if the flickering will still be occuring.
>Also try to boot into the BIOS of the machine to see if the Flickering occurs in BIOS as well, to boot into BIOS upon powering the machine keep on tapping F1 till you get a blue screen saying phoenix BIOS as long as the word BIOS is there you are in the right page. just check if the flickering happens there, if it does then the issue is not software but most likely hardware it can be the LCD itself or the Cable conenction of the LCD to the Video on the motherboard.
>if the flickering is present in BIOS most likely you will need to have the system serviced for proper repairs and diagnostics.
I hope this helps.
Have a nice day,
mvincentc
Lenovo Elite... | Answered on May 09, 2011
Laptops do not have a reset button, just a power button which you have to hold down until the laptop turns off and then press it one more time to turn it back on.
Lenovo Elite... | Answered on Dec 03, 2010
If your CMOS is in your Hand and you booted the machine then it should not ask for any password.
Please make sure that the CMOS battery is OUT.
Lenovo Elite... | Answered on Sep 28, 2010
There isn't any way to recover or reset the HDD password or the Hard drive data. To use your computer again, disable all passwords in the setup and replace the hard drive, you'll lose all data.
Lenovo Elite... | Answered on Jul 09, 2010
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
Lenovo Elite... | Answered on Mar 28, 2010
First of all it has preloaded OS. So no-one except the Administrator can install or uninstall any software. Log in as administrator and that is inaccessible then enter BIOS, change supervisor password by entering blanks(space bar) twice, reboot and then you will be be able to use the Administrative controls.....sodeep
Lenovo Elite... | Answered on Mar 19, 2009
Vista is obsolete!
  • whatsapp laptop free download - Softonic en.softonic.com > Software utilities > Operating Systems whatsapp laptop free download - WhatsappTime 5.1.14: Whatsapp for pc straight from your desktop, and much more programs.
  • Whatsapp For Laptop - Download.com download.cnet.com/s/whatsapp-for-laptop whatsapp for laptop free download - WhatsApp Messenger, WhatsApp Messenger, WhatsApp Pocket, and many more programs
  • Whatsapp On Laptop Windows 8 - Download.com download.cnet.com/s/whatsapp-on-laptop-windows-8 whatsapp on laptop windows 8 free download - Start Menu 8, Realtek High Definition Audio Codec (Windows Vista / Windows 7 / Windows 8 32-bit), DeskScapes 8, and ...
  • Download Whatsapp Messenger on PC, Computer or Laptop ... www.techtiptricks.com/download-whatsapp-messenger-on-pc-computer... Use Whatsapp Messenger on PC, Computer or Laptop Free, Learn How to Use Whatsapp Messenger on PC, Free download for windows xp, vista, 7, 8 or mac system
  • Lenovo ThinkPad... | Answered on May 09, 2020
    Error code 36 means a ley is stuck. Only you can find out which one. Press each key in turn to feel if there is a dodgy key.
    Lenovo ThinkPad... | Answered on Oct 09, 2019
    remove the battery large.
    then run on AC pack only
    #1 top failure of all mobile PC is that battery, so unplug it
    then test with AC pack only.
    work now.? and all vents must be clean, end to end. not just fan.
    there i no fuse it uses current regulator, imagine genius magic electronics fuses that never blow out, and bingo.
    OK big battery out, an RTC coin cell fresh.
    then fan blows.
    next is BIOS, do the BIOS screens work if not the mobo is dead.
    have 2 RAM stick on the 2 slots>? try one at a time
    run the PC with all modules removed, (options)
    remove hdd?
    remove, dvd drive.
    think like this. Get bios working first
    learn that modules can short, and when they do the power regs shut down.
    so we unplug all things to the mob,
    until only 1 ram and cpu remains.
    see? (this is called power overload fault isolation tactics)
    even the screen only can be dead, you never mention text showing
    you can test the mobo with external screen via that rear (?)_ VGA jack what if that worked, did you learn something here, sure.
    this pc has tons of modules to pull, even bluetooth. wifi, sound and more. if you look at all parts inside or sold by ebay, bingo. lots
    Lenovo ThinkPad... | Answered on Aug 14, 2018
    It helps to know what device model and OS you are using though the following steps for changing from pattern lock to slide are for Android OS 4.0 (Ice Cream Sandwich):
    1. Unlock your Android device
    2. Find the Applications menu and select "Settings"
    3. Under the "PERSONAL" group, select " Security"
    4. Under "SCREEN SECURITY" group, select "Screen Lock"
    This will ask for the security pattern first.
    5. The options for screen lock will appear, select "Slide" and you are done!
    Hope this helps.
    Lenovo ThinkPad... | Answered on Mar 14, 2017
    Lenovo Elite ThinkPad R400 Notebook Logo
    Popular Tags
    13 questions posted
    Top Lenovo Computers & Internet Experts
    Lee Hodgson
    Lee Hodgson
    Muntejaya Ginting
    Muntejaya Ginting
    Ekse
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    ThinkPad Lenovo
    • ThinkPad Lenovo
    Most Popular Question
    reset lenovo r400 bios password
    • Computers & Internet
