20 Most Recent Lenovo ThinkPad T43 Notebook PC Questions & Answers
Traditionally with ThinkPads:
1. The BIOS password can be reset with the CMOS.
2. The Supervisor password cannot.
3. The HD password cannot.
If it's the harddrive that's locked you will have to replace that. If it's the Supervisor password you need to replace the system board which kind of defeats your purpose.
Lenovo ThinkPad... | Answered on Oct 06, 2017
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
Watch the demo (1:00)
this should speed up your computer
hope this helps
Lenovo ThinkPad... | Answered on Oct 10, 2012
It could be overheating due to the CPU cooling fan not functioning.
Lenovo ThinkPad... | Answered on Sep 27, 2012
Hi
try to find out HDMI driver for yor device match with your OS (windows xp , 7 , etc)
Lenovo ThinkPad... | Answered on Sep 17, 2012
just check for sound you get sound from your laptop speaker if you get sound from speaker
1) Click on Start and Run
2) Type the following command and press Enter
services.msc
you see window audio service check is service enable if not set autometic and restart your computer and check
Lenovo ThinkPad... | Answered on May 22, 2012
Click Here to get the proper driver without a cd, you must know your operating system when going here in order to get the proper driver selection. I do although recommend the pcl 5 over the pcl6 as it has way less bugs... Hope this helps and if so please mark as FixYa!!
Lenovo ThinkPad... | Answered on Nov 07, 2010
There is no *LEGAL* way to remove that software.
You clicked "I agree" to allow that software to be installed.
If you have a "bootleg" version of Microsoft Windows, follow the hyperlinks offered by WGA to "get genuine Windows", i.e., pay some money to get a valid product-key for Windows.
Or, telephone Lenovo, and order a set of "System Recovery" CD disks. If your computer was originally shipped with Windows XP installed, those disks will re-install a *VALID* copy of Windows XP.
Lenovo ThinkPad... | Answered on Sep 23, 2010
Hello mitchellg353,
There may be a Microsoft hotfix available for the STOP: 0x000000F4... problem. This article on Microsoft support web site shows how to get the hotfix: http://support.microsoft.com/kb/935192/en-us
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Lenovo ThinkPad... | Answered on Jul 07, 2010
Sounds as if the sound card drivers are corrupt or not installed, here is the site for the audio drivers:
http://www-307.ibm.com/pc/support/site.wss/MIGR-58597.html
Go to the audio section and you can download the driver for windows xp, if you need drivers for something other then XP then the page will let you know what to do.
Lenovo ThinkPad... | Answered on May 27, 2010
Beep sound means your RAM is damaged. Change the RAM.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Lenovo ThinkPad... | Answered on Feb 01, 2010
Try to install the driver manually through device manager.
1. Right click the device you want to install and click update driver.
2. Select No Not This Time
3. Select Install From List Or Specific Location
4. Use the first option (Search for the best driver) and enable Include This Location In The Search click browse and locate the driver in the drop down box
click next to install.
Lenovo ThinkPad... | Answered on Jan 10, 2010
Hit F1 to open Bios settings try to boot from bootable CD
Lenovo ThinkPad... | Answered on Apr 23, 2009
Depends on the computer you are using.
If the computer you are using is low on resources, as the Pentium M in title, then one of the 'fastest' ptp fileshare software is Utorrent, as it needs little RAM and also does not need a big CPU.
If instead you have a powerful computer with 2GB RAM and pentium duo, or more, then I recommend Azureus-Vuze, that is one of the most complete torrent software.
See:
Download - µTorrent
Azureus, now called Vuze : Bittorrent Client
Lenovo ThinkPad... | Answered on Apr 12, 2009
Have you tried updating lenovo systemupdate, it might help, if not just reinstall the device driver directly from the lenovo webpage
Lenovo ThinkPad... | Answered on Mar 29, 2009
Lenovo ThinkPad T43 Notebook PC Logo
Popular Tags
29 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
no active mixer devices available t43
  • Computers & Internet
