20 Most Recent Toshiba Satellite L305-S5907 Laptop Questions & Answers
To burn cd/dvd you have to check :
1. Your laptop cd/dvd drive have what capability:
- cd writer = only burn cd
- cd writer/dvd reader(combo) = still only burn cd
- dvd writer = can burn cd, dvd single layer(4GB)
- dvd DL writer = can burn cd and dvd single 4GB and dual layer 8GB.
Other than those, is not possible.
2. Must have burn apps named:
- Nero
- Alcohol 120%
- other. search internet.
If you have them then using the apps to burn, just read the manual.
Koam114 is in Korean. I don't understand :)
But If you want songs from website, you should download it first.
Unless the site is giving you a step by step how to burn songs directly to your cd/dvd.
Once downloaded, would be easier to burn to cd/dvd.
Toshiba... • Answered on Mar 25, 2020
Wipe it down and re-install the OS. Oh, and stay away from Worst Buy!
Toshiba... • Answered on Jul 10, 2017
press the zero key while turning on the laptop.
Toshiba... • Answered on Sep 15, 2014
I will suspect the battery first. I make sure the battery I reseat the battery, make sure the charger is well plugged in and no damage to the cable. The next step is that I would test with a known good battery and if the problem still persist test with a known good AC charger. If the battery and AC charger and its cable/cord are determined to be good I will be thinking of big/expensive issue with main board which may not worth the trouble if the laptop is relatively old like 2 years
Toshiba... • Answered on Dec 30, 2013
I'mnot sure what you mean,"i am hearin anouice"? I don't know your OS, so this solution is a general idea. But if you open Control Panel, Sounds, Open sounds tab, change. respond to post for further assistance. If you are hearing a noise, what kind of noise and comming from where?
Toshiba... • Answered on Dec 13, 2012
If you are looking for freeware to Clean your system I use FILEHIPPO, you can find lots of freeware, and usefull tools to maintain your system. I suggest MALWAREBYTES and CCLEANER for starters. If you need a good Anti Virus, I suggest AVAST Free. REMEMBER to remove any Anti Virus you have on your machine with the PROPER removal tool found on the Manufacturer's website. Filehippo can be found here: http://www.filehippo.com/. Respond to post for further assistance.
Do a System Restore again but pick a restore point (date) before the troubles began.
Toshiba... • Answered on Oct 11, 2012
The best advice I feel that I can give you, is to contact Toshiba Support, and ask about how to obtain the Recovery Disk, for your Satellite L305-S5919.
Toshiba Support- Contact Us,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=su_contact
Generally, the Recovery Disk contents can be downloaded over the internet, or a Recovery Disk CD is mailed to you.
If it's feasible for you, I advise having the CD mailed to you.
This way you'll have a CD, accessible right at your fingertips, and can do a Fresh Install, or a Repair, whenever you like.
Would also like to offer the Drivers and Software download page, for your Toshiba laptop.
It's best to Refine your search, and go to the top heading -> Refine Search By: Operating System <- , and choose the Operating System you're using. (Examples: Windows XP or Windows Vista)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2241927&rpn=PSLB8U&modelFilter=L305-S5919&selCategory=3&selFamily=1073768663
Toshiba... • Answered on Sep 25, 2012
Have you installed the webcam driver already? If yes, just try restarting your laptop. Make sure also that nothing is blocking your webcam.
Just get back here for more help.
Hope it helps.
Thanks!
Toshiba... • Answered on Jun 16, 2012
Corrupted operating system. Start over with a restore disc and if you do not have one buy one you will need it from the factory. Re-install the whole system over again. Insert the disc in the slot and power it on select boot from DVD or CD-Rom which ever you have. Follow the onscreen instructions. John
Toshiba... • Answered on Apr 09, 2012
If you cannot find the replacement for the damaged ic, i will advice you get rid of the motherboard and get a new motherboard for system in other to keep you moving. though it may not what it but it will save you lot of time and stress.
Take care.
Toshiba... • Answered on Mar 01, 2012
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Toshiba... • Answered on May 28, 2011
With the Toshiba Satellite L305-S5907 Laptop, you can put a 500GB hard drive and up to 2 TB hard drive. The only requirements are to make sure it has a SATA connector and is 2.5" Size. These are very common and easily found online. For example, here a 500GB one that is compatible that I found: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
Toshiba... • Answered on May 24, 2011
You didn't mention if the dvd was working before or it's new.
Now, you have 2 options to try:
1) Try to open the same DVD on other DVD-Reader. If it was read, then the dvd is unreadable on your laptop, because it's bad, or the DVD-Reader have problems, OR
2) Try other DVD on your laptop, if it was read, then your DVD-Reader can't read all types of DVDs, if not, then the dvd is bad
Tell Us your results, please
Good Luck
Toshiba... • Answered on May 13, 2011
Try going through the control panel, Internet options, (Vista, Network and Internet ) And choose Connect to a Network. Go through the process.. walks you through.. Hopefully this will do it..
Good luck
Toshiba... • Answered on Apr 30, 2011
I am glad to HELP YOU!
When you start to create the RECOVERY MEDIA your machine is creating a virtual file [a temporary one...] that includes all parameters and drivers and system files of your operating system; once the temporary file is done the recovery files are written on the indicated media [a hard drive or a DVD/CD].
Because of the huge size of the file [the temporary one] you need enough room for the virtual file to be created.
So you got your error message just because you DON'T HAVE ENOUGH ROOM on your hard drive.
My suggestion is: find an external drive [a USB attached hard drive] and make the RECOVERY MEDIA there. Meanwhile try to clean up a little bit your hard drive by using that application in Windows called DISK CLEANER [START > ALL PROGRAMS > ACCESSORIES > DISK TOOLS > DISK CLEANER].
My best regards!
... and don't forget to RATE, please...
Toshiba... • Answered on Apr 20, 2011
1. Directly connect to the router with an ethernet cable from your PC.
2. On the browser, enter the router's IP address
3. Log into the router
4. Navigate to router's wireless setup
5. Change the SSID to something NEW and DISTINCTIVE - do not use a default SSID
6. Make sure SSID is being broadcast - click to set the check-box if it wasn't set before
7. Save and exit the router setup then disconnect the ethernet cable
8. On your PC, View Wireless Network Connections
9. Click Network Task to Refresh network list
10. Your router with new SSID should show on the refreshed network list
11. High light your router's new SSID and click the Connect button
12. On the pop-up requesting WEP or WPA key, enter the key you had set in the router before.
Toshiba... • Answered on Mar 30, 2011
Toshiba Satellite L305-S5907 Laptop Logo
Popular Tags
97 questions posted
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba satellite l305 s5907 15 4
  • Computers & Internet
