20 Most Recent Sanyo VPC-S670 Digital Camera Questions & Answers
The VPC-S670 works with MMC and SD cards, which max out at 2GB.
There are nonstandard SD cards up to 8GB in size, which may (or may not) work with the camera. But make sure it's an SD card, not an SDHC card. The camera will not work with SDHC cards.
Sanyo VPC-S670... | Answered on Apr 19, 2014
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Sanyo VPC-S670... | Answered on Sep 26, 2012
Consider NOT using a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
Sanyo VPC-S670... | Answered on Aug 30, 2011
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Sanyo VPC-S670... | Answered on May 07, 2011
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Sanyo VPC-S670... | Answered on Jan 31, 2011
Hi.
This is a common problem.
You can send camera for repair here: Repair.
See here an article: Sanyo digital camera is not starting and you get lens error
Sanyo VPC-S670... | Answered on Jan 20, 2011
The problem could be that you're not fully pressing the shutter button. Many people squeeze the button until something happens... that's the half press that causes the autofocus to operate etc. Because something happened, they don't continue to press hard enough to actually take the snap.
Of course it's also possible that the plunger on the shutter button is too short and isn't reaching the switch properly, but I've only seen that on a kids cheap camera where it was squeezed too hard with impatience because cheap cameras operate slowly.
Oh, and one more thing: are you squeezing the button for long enough? I don't know how slow this particular model is.
You must take pictures gently. Blur picture may occur if you move during capturing a picture. Or your hand move too fast after taking a picture. Try to stay still for two or three second after push the capture button.
Blur picture when shooting outdoor can be caused by too much light. Don't forget to set your camera in outdoor or panorama mode, and turn of the flash light if you think its too bright.
Hope this help and RATE please !
Sanyo VPC-S670... | Answered on Jan 16, 2011
What kind of batteries are you using? what is the milliamp rating on the batteries? Are they still the stock sanyo batteries? If you are using flash and the screen it can wear out batteries pretty quick specially if they have been recharged alot of times. If they are not new then you probably need to invest in a new pair of rechargeable batteries. If they are new batteries check to see if the MAH rating on the bat tery is higher or lower then the old ones. If you want to buy new ones click here
Let me know from there and i can assist you further. Thanks, Midwest-tek
Sanyo VPC-S670... | Answered on Aug 29, 2010
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Sanyo VPC-S670... | Answered on Aug 12, 2010
you can either empty the pictures in it by deleting or saving on your pc
Sanyo VPC-S670... | Answered on Jul 17, 2010
hi, the cheapest and quickest way to get one would be to go to the well known auction site and buy one from their, they cost next to nothing and you should get one within 2 days.
You could also go to a camera or computer hardware shop and buy one from their but you will pay extra for the same product.
You should also be able to buy one from any phone shop but these will cost a bit more.
The auction site is your best bet, so i would try their first, cant mention no names as we are not allowed to push sales to other sites but you can get them from their i have checked and they are cheaper than any where else
Sanyo VPC-S670... | Answered on Jul 06, 2010
Do what the pros do...use a card reader.
Sanyo VPC-S670... | Answered on Apr 09, 2010
c242c4e.jpg This is SANYO VPC-S670 User Manual
If you find this helpful pleasa vote with high rank.
Sanyo VPC-S670... | Answered on Feb 25, 2010
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Sanyo VPC-S670... | Answered on Feb 23, 2010
Turn it on by pressing the flash button
Sanyo VPC-S670... | Answered on Feb 03, 2010
Use a card reader instead of your camera.
Sanyo VPC-S670... | Answered on Dec 15, 2009
Blame Microsoft updates. Use a card reader.
Sanyo VPC-S670... | Answered on Dec 01, 2009
Sanyo VPC-S670 Digital Camera Logo
Popular Tags
26 questions posted
Top Sanyo Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
View Most Popular
VPC Sanyo
  • VPC Sanyo
Most Popular Question
lost software download pictures from
  • Cameras
