20 Most Recent
Samsung Digimax S600 / Kenox S600 / Cyber 630 Black Digital Camera Questions & Answers
Drivers d'installation compatible avec Windows 7
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
Samsung camera digamax x600 cyber
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
When turned on camera beeps 3 times & the zoom
Does it take standard disposable batteries or a rechargeable pack?
If the first, check they are inserted correctly as per the illustration in the battery compartment or instruction manual section on inserting batteries.
If the second type, recharge the pack.
If problem continues check Troubleshooting section of manual or online at Samsung's website.
Hi i have problem with
I have had this problem before as well. Your camera only accepts SD cards, not SDHC.
Be careful an look to make sure it does not say SDHC on your next purchase.
You camera manual can be found
here.
Computer cannot read sd from camera
Does anything happen on your computer when you plug in your camera? Make sure the camera is turned on if not. You may need to press OK on the camera also when it is plugged in.
How do I use the focus
be sure your lense and autofocus sensors are clean first thing.. then push the take picture button half way and it will autofocus. Pressing hte take picture button fully then will snap the picture.
Usb usb data transfer cable
Have you considered NOT connecting your camera to your computer?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
