20 Most Recent Pentax K20D 14 Megapixel SLR Digital Camera w/ 16-45mm lens, Shake Reduction, 2.7 High Resolution LC Questions & Answers
I have a Pentax K20d DLSR camera. I ordered a
If the lens has an "A" setting, be sure that's where you have it set. Clean the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol.
4/8/2011 9:39:00 PM • Pentax K20D 14... • Answered on Apr 08, 2011
Pentax K20D is not recognozed by my mac
Do what the pros do...use a card reader.
6/7/2010 12:02:35 AM • Pentax K20D 14... • Answered on Jun 07, 2010
Pentax K20D pink strip on photos
Go to the support section of the Pentax website and e-mail your question to their techs. I believe this is a known problem with a solution.
4/21/2010 11:18:17 PM • Pentax K20D 14... • Answered on Apr 21, 2010
Iso stuck on 400
Go into the menu and scroll to "reset"...follow the on-screen instructions.
11/22/2009 8:46:00 PM • Pentax K20D 14... • Answered on Nov 22, 2009
Why does it take so long to show to the photo after I press the shutter button?
The picture displays after the file has finished saving - if the speed of your SD card is slow, it can take quite a while before the picture is displayed. It also takes a while (up to a minute or more) if the shutter speed is low and the picture is mostly black (taking nighttime moon shots for instance). Try using a better quality (higher speed) SD card.
12/1/2015 4:04:21 AM • Pentax K Cameras • Answered on Dec 01, 2015
I want to use my old k 1000 lenses on one of Pentex's new camera body's.
Your old Pentax lenses uses the Pentax K mount. The current Pentax digital SLRs all use the same K mount so the lenses will fit on them. You obviously won't get all the features available on new lenses, such as autofocus, but they should all work fine.
12/31/2012 4:19:23 PM • Pentax K Cameras • Answered on Dec 31, 2012
Pentax Optio A10 camera turns on, the lens extends, the whistle sounds, and the screen displays battery level, & indicators. The problem is the screen itself is dark as if there is a lens cover on.
Normal people can't fix electronic cameras, you need to be an electronics engineer and an optical engineer. Take to a Camera Service Centre for evaluation and repair.
1/28/2024 6:21:51 AM • Pentax Cameras • Answered on Jan 28, 2024
Why isn't my K100D Flash not working?
Hi, please ensure that you've not used the camera for more than the advised amount of time by the manufacturer. Also, you can attempt to use the same brand/type of batteries as was including with your camera when you got it. Some manufacturers put internal fimware/software restrictions on their devices. For printers, this would be done for cartridges and in the case of your camera, it would be for batteries. Lastly, I would check that your sd card isn't full before calling Pentax to refer you to a repair shop. Thank you.
12/27/2022 1:20:26 AM • Pentax Cameras • Answered on Dec 27, 2022
Pentax Espio 60S "E2" error
Hi for anyone reading this! My 60s was just flashing with this but I fixed it. Took the batteries out, swapped them and that didn't work. Tried to put the old ones back in a few minutes later and then it was fine! Just fiddle around with it. Hope this helps.
12/12/2022 5:16:29 PM • Pentax Cameras • Answered on Dec 12, 2022
2answers
Hi...I won a Pentax digital camera K1100 but it came without instructions or a memory card. So I would really like to know how to use it and what memory card needs to go into it. I would really appreciate your help!
Download here. Section for discontinued models
http://www.ricoh-imaging.co.jp/english/support/download_manual.html
12/26/2019 3:28:50 AM • Pentax Cameras • Answered on Dec 26, 2019
My Pentax e30 will not record video files
http://www.ricoh-imaging.co.jp/english/support/man-pdf/optio-e30.pdf Instruction manual Does the SD card have enough room / is it fast enough for video? (the E30 records Standard def video so it should be OK) Do you get any error messages at all? Does it allow you to record video and then fail, or can you not activate recording in the first place?
11/5/2019 12:42:18 AM • Pentax Cameras • Answered on Nov 05, 2019
I have an old Pentax sv camera where can I get a users manual
Hi, Penny, I'm sure you will get a great deal of pleasure out of your new acquisition. To get a manual, try using Google 'Pentax SV camera manual'. You can get a great deal of help, advice and assistance from PentaxForums.com as well.
10/4/2019 10:00:47 PM • Pentax Cameras • Answered on Oct 04, 2019
My pentax smart head does not come on automatically...I have to press the red knob for it to come on
To what camera does this statement (it is not a query) apply ?
9/28/2019 4:53:17 PM • Pentax Cameras • Answered on Sep 28, 2019
I need a driver update for my pentax optio rx18. can download one from your website
Hello, Susan -Fixya.com does not have updated drivers for any computerized equipment. If you have not already done so, I suggest you contact Pentax directly regarding an updated driver for your Optio RX18.Pentax is owned by Richoh.You may be able to find assistance from another Optio RX18 owner through the PentaxForums.com :https://www.pentaxforums.com/forums/7-pentax-compact-cameras/194995-pentax-optio-rx18-rz18.htmlYou will need to register (free) to post a question on a forums.Best wishes.
9/4/2019 10:26:14 PM • Pentax Cameras • Answered on Sep 04, 2019
I have a Pentax Optio E60 - whether sd card is inserted or not, screen states built-in memory full + a peeping sound. Consequently, it drives me crazy. Please assist
First of all, I assume you are using an SD card (Max 2GB) as that appears to be the maximum the camera can use. That being so, all you need to do is either transfer the contents of the internal memory to the SD card, or to your computer, thus freeing the internal memory. Then set the camera up so that it writes straight to the SD card.
8/23/2019 6:08:07 PM • Pentax Cameras • Answered on Aug 23, 2019
Pentax K20D 14 Megapixel SLR Digital Camera w/ 16-45mm lens, Shake Reduction, 2.7 High Resolution LC Logo
4 questions posted
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
K Pentax
  • K Pentax
Most Popular Question
iso stuck 400
  • Cameras
