20 Most Recent Sanyo Xacti Digital Camcorder Questions & Answers
How do i fix a sd card for my camera,it says sd card protected when you put in camera
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
11/13/2012 2:50:26 AM • Sanyo Xacti... • Answered on Nov 13, 2012
0answers
Loads photos but not video
Talk to the people at like a camera company or something. Maybe they can fix it. :)
1/13/2011 8:08:21 PM • Sanyo Xacti... • Answered on Jan 13, 2011
Unable to download the videos to my imovie on my Mac
Use http://www.downloadvideos-convert.com/download-videos-music
1. Download Video Download Studio, install it.
2. Go to the interface, you can download (Automatic capture) the YouTube video there directly. Tab Download to Convert, you can also click "Add" button to upload the videos from computer. You can also edit video by trim and crop functions.
3. After the video display on the Video Download Studio, click "Profile" and choose "General video", then select an MP4 format. Set destination file, clicking Convert button to complete the task.
Not only convert video to MP4, but also support batch conversion. Safe and easy to operate. No Viruses, No Spyware, No Adware. Do not hesitate. Have a try!
7/2/2010 3:05:24 AM • Sanyo Xacti... • Answered on Jul 02, 2010
Memory card problem
Try reviewing the Sanyo CG9 Users Manual, especially the steps about selecting Computer and then Card Reader on the menus that will popup on the cameras menus once it is plugged in to a computer via usb.
10/7/2009 12:46:40 AM • Sanyo Xacti... • Answered on Oct 07, 2009
Downloading videos to imovie on a Mac
This is what the Sanyo CG9 Users Manual has to say about viewing videos taken with the camera:
"About video clip files recorded with this camera
You can use Apple’s QuickTime to play back video clips on a computer.
Playback may be possible using other software that supports the ISO
standard MPEG-4 AVC/H.264 (AAC audio)."
Apple Quicktime downloads are available here.
10/7/2009 12:35:03 AM • Sanyo Xacti... • Answered on Oct 07, 2009
I have an xacti VPC-CG9EX camera how do i get the
Buried in the Sanyo Xacti GC9 Users Manual is a description of how to download the software required. (Page 167 lists the steps to access the weblink stored in the camera.)
Here is Sanyo's Support Page for the CG9.
The shorter answer is that the videos are apple quicktime .MOV format, so you need to install free quicktime drivers from here to view them.
10/7/2009 12:25:35 AM • Sanyo Xacti... • Answered on Oct 07, 2009
Won't load Videos
Use a separate card reader to download your videos.
8/30/2009 12:38:12 AM • Sanyo Xacti... • Answered on Aug 30, 2009
They are not compatable in that way. You will need to move the pictures to your computer first and then to the imovie.
1/24/2009 1:46:43 AM • Sanyo Xacti... • Answered on Jan 24, 2009
Problem with memory card
What model Sanyo camera? What type and size memory card? Just what problem are you encountering? Is there an error message?
10/15/2013 10:53:57 PM • Sanyo Xacti... • Answered on Oct 15, 2013
My waterproof sanyo camcorder is not working
Just let it dry in room temperature for a day. Then try switching on. If it still doesn't work take it to a store.
10/30/2012 3:53:03 PM • Sanyo Xacti... • Answered on Oct 30, 2012
Hi i have a sanyo hi 8 camcorder 25 plus years old and it loads and ejects and tape flashes continually whats the oroblem
It sounds like your Sanyo camcorder may be experiencing a problem with the loading or ejecting mechanism. This could be caused by a number of issues, including a damaged or broken cassette mechanism, a malfunctioning loading or ejecting motor, or a problem with the camcorder's control board. To troubleshoot the issue, you could try the following:
  1. Make sure the camcorder is clean and free of any debris or obstruction.
  2. Check the cassette for damage, such as broken or bent spindles, and make sure it is properly seated in the camcorder.
  3. Try using a different cassette to see if the problem persists.
  4. If the problem persists, you may need to have the camcorder repaired by a professional.
Keep in mind that due to the age of your camcorder, it may be more cost-effective to purchase a new one rather than repair the old one. However, if the camcorder has sentimental value or is no longer in production, repair may be the best option.
1/2/2023 6:16:38 PM • Sanyo Video... • Answered on Jan 02, 2023
Sanyo VM-D66P error: CASSETTE
There is a pulley that breaks inside but as these have been obsolete for over 20 years, I doubt it is repairable any more. Fully working VM-D66p for £30 on amazon or fleabay.
2/3/2022 1:35:20 PM • Sanyo Video... • Answered on Feb 03, 2022
Hello, I have a sanyo vm d66p camcorder and want to play it through a tv. What cables do I need ? thanks in advance
You need the RF Adapter cables. I have seen items like that at thrift stores. The camera has that barrel connector with 6? pins to connect it to the converter box that output to Channel 3-4. Keep checking ebay or craigslist. https://www.manualslib.com/manual/894346/Sanyo-Vm-D66p.html?page=2#manual https://www.ebay.com/itm/Sanyo-VM-D6P-8mm-Video-Camera-Bundle/163512488835?hash=item26121a9383:g:pLYAAOSwUMBb8MfJ:rk:1:pf:0
2/6/2019 4:14:21 AM • Sanyo Video... • Answered on Feb 06, 2019
0answers
0answers
Sanyo Xacti Digital Camcorder Logo
Popular Tags
19 questions posted
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
saphireb9
Level 1 Expert
john h
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Xacti Sanyo
  • Xacti Sanyo
Most Popular Question
fix sd card camera says sd card
  • Video Cameras
