20 Most Recent Canon EOS 50D 15.1MP Digital SLR Camera Digital Camera with EF-S 18-200mm f/3.5-5.6 IS Standard Zoom Lens Questions & Answers
5answers
I love taking wedding photos. do you think the
Yes, I'm sure that camera will be fine, the 20D some years back was considered OK for wedding images
BUT its more about the quality of the LENS you are using and will it wok in all situations
I used to do a lot of Film work for weddings and used various canon camera bodies, but the lenses where the important factor for speed, composition - I also used a top quality flash unit, that could be used OFF camera. I used a 28mm lens, 50mm 1.8 lens - very high quality and cheaply available, 135mm portrait lens, and various zoom lens
I also always used a tripod, so i could compose the groups and then leave, the camera and go and work with setting up the group, and using a remote take the picture. I also used a flash frame on the flash, so I could turn the camera between portrait and landscape with out worrying about the flash gun
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
7/18/2019 6:20:36 AM • Canon EOS 50D... • Answered on Jul 18, 2019
It appears that the mirror on my canon 50d is sticking in the up position, how can i fix it?
50D's Have a common problem with loose screw inside, If you keep useing it the screw or screw's will short out the power board or Main board, It Needs to be takin apart and find that or many loose screws and resealed. (Come's from Camera being dropped or something like that!) tccamerarepair.com
2/1/2018 3:33:52 PM • Canon EOS 50D... • Answered on Feb 01, 2018
Canon 50d error 50
Go to the Canon web site and look at the list of error codes for an explanation. Or Google Canon Error Codes
9/23/2017 7:07:48 PM • Canon EOS 50D... • Answered on Sep 23, 2017
D50 camera will not turn on. I charged the battery pack and reinstalled. Nothing. What do I try?
The camera is over 5 years old, so the battery is now weak. Go to the store, like Best Buy, try with their battery. If it comes on then buy that battery. If you have DVM (digital volt meter), you can check out the battery voltage. But you can not check current safely. [email protected]
8/21/2014 3:17:14 PM • Canon EOS 50D... • Answered on Aug 21, 2014
2answers
I have a Canon EOS 50D Digital Camera and use 3
You can read here
3/21/2014 7:02:03 AM • Canon EOS 50D... • Answered on Mar 21, 2014
2answers
I keep getting err 30 on my cannon 50d. I think I
Hi, Unfortunately having a shutter replaced, when sending the camera off to Canon takes 8-12 weeks in my experience.
3/21/2014 6:49:14 AM • Canon EOS 50D... • Answered on Mar 21, 2014
2answers
How do I set dpi on canon 50d digital slr to the
You'll need to shoot RAW. Then in the conversion from RAW to TIFF or JPEG you can specify the DPI. You can do this in Photoshop or in Digital Photo Professional that probably came with your camera.
DPI and Pixel Resolutions are in two different realms, though somewhat related, they are independant. Your camera produces files at the maximum resolution of 4272 x 2848. At 72 dpi, your print will roughly be 60"x40". At 300 dpi, 14.25"x9.493". At 600dpi, 7.12"x4.747", at 1200dpi 3.56"x2.373". Think of cameras in terms of pixel resolution and printers in terms of dpi. When files are inserted into layouts, the embedded dpi value is used. You just need to change the embedded value to match up with the print size you desire. Obviously, if you want a 120"x80" print at 300dpi... you've got the wrong camera. :) Source(s): This is a good site for those interested in more technical details:
http://www.scantips.com/
3/21/2014 6:42:48 AM • Canon EOS 50D... • Answered on Mar 21, 2014
EOS Utility will not allow images to download from
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/12/2011 5:37:44 PM • Canon EOS 50D... • Answered on Apr 12, 2011
My Canon D50 is used only for astro imaging.The
You could experiment with setting the ISO to 1600 or 800 and use corresponding longer shutter speeds.
3/1/2011 2:03:36 PM • Canon EOS 50D... • Answered on Mar 01, 2011
I am shooting on Manual (M) on the dial. My
No I doubt your crippled it but you might have neglected to turn the "Quick Control Dial" on here is a diagram of the little mark to set the switch to.
Diagram
2/9/2011 1:08:05 AM • Canon EOS 50D... • Answered on Feb 09, 2011
How do i set the
manual mode (M) > set the camera to "high speed continuous" shooting> exposure compensation / AEB setting> turn dial on top (used for shutter speed setting in manual mode) for desired setting.
12/9/2010 5:50:13 PM • Canon EOS 50D... • Answered on Dec 09, 2010
2answers
I need a Canon EOS 50D English User Guide Manual
Uh.. actually it would be the manual for 50D in English not Powershot A51 that he wants to get. You may download it here:
Canon 50D Manual in English
11/28/2010 5:01:56 PM • Canon EOS 50D... • Answered on Nov 28, 2010
I have a Canon EOS
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/eos_50d#ServiceAndSupport
The above is the support page for your 50d camera.
I could not find a 'black' or 'blank' screen problem and solution in the FAQ's.
So, I think that it should be serviced by CanonUSA.com:
http://www.usa.canon.com/cusa/online_repair_tracking/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/eos_50d?pageKeyCode=requestRepair
11/26/2010 7:32:14 AM • Canon EOS 50D... • Answered on Nov 26, 2010
Error message communication between camera and lens is faulty
Your flex cable to the Iris is broken. Have a look at my gallery at http://www.pbase.com/barry_2718/efs1785mm I have the same symptoms. At 28 or 35mm it make work ok. try Av mode and f8 aperture to see if you get an err01 because the aperture does not move either. Sound like you may have been sold a dead lens I am afraid to say. There are lots of reports about this lens failing after 2 to 3 years of use.
6/24/2010 1:04:47 PM • Canon EOS 50D... • Answered on Jun 24, 2010
It is brand new I charged the battery all day and
Try to use non-rechargeable LR6 batteries.
If it still does not work the camera needs a repair.
Thank you for choosing Fixya
6/23/2010 3:00:03 AM • Canon EOS 50D... • Answered on Jun 23, 2010
Live view shooting/print/share button stuck on
Until you figure it out, pop out the battery until you use it next time. I have not used this feature. Do your recall how you turned it on?
6/9/2010 3:36:23 AM • Canon EOS 50D... • Answered on Jun 09, 2010
Does the Eos 50d support wireless multi-flash
I have a Metz and a 50d and it does support E-ttl. The Metz is a bit less and it is more versatile than the Cannon and it does support slaves as well. I hope this helps you a bit. I got my Metz from Calumet Photographic. I am sure if you call them, they can tell you the answer.
6/9/2010 3:30:46 AM • Canon EOS 50D... • Answered on Jun 09, 2010
I can't change some of the settings on my Canon
they are preset by camera in modes.ie sport.fast shutter,wide app.switch to apperture priority etc.
5/27/2010 12:13:05 PM • Canon EOS 50D... • Answered on May 27, 2010
Canon 50d AF assist beam doesn't fire
  • See page 87 of the manual to see which settings the AF-Assist does NOT work
4/7/2010 1:47:32 PM • Canon EOS 50D... • Answered on Apr 07, 2010
My Canon 50D will NOT turn on!!
Try to clean the battery compartment. If it dont work try to use other batteries. If still the camera wont turn on the battery compartment is either defective or the board has a defect
9/23/2009 1:42:54 PM • Canon EOS 50D... • Answered on Sep 23, 2009
Canon EOS 50D 15.1MP Digital SLR Camera Digital Camera with EF-S 18-200mm f/3.5-5.6 IS Standard Zoom Lens Logo
25 questions posted
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Eos Canon
  • Eos Canon
Most Popular Question
need canon eos 50d english user guide
  • Cameras
