20 Most Recent
Numatic HHR-200 Henry Hound Bagged Canister Vacuum Questions & Answers
My hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Turbo brush cutting out
I had the same problem, I solved it by unscrewing all the attachment parts of the tubes and taking off the connecting covers, cleaning out the fluff and wiping off any dirt from the copper connectors, replacing the covers and screwing it all back together and it is now working well again.
Hope this works for you.
Ann.
I have a Henry 200 and the red on/off switch is
Well... It probably can't be fixed, but it can easily be replaced. Depending where you are, spares are usually readily available.
If you need more guidance, please post here again, and I'll see what I can do to help.
Numatic George Wet/dry vacuum won't spray - Only a very very very faint buzzing sound can be heard putting my ear right next to the machine.
There are a few potential causes for why your Numatic George wet/dry vacuum is not spraying and only producing a faint buzzing sound. Here are some troubleshooting steps you can try:
- Check the water level: Make sure that the water level in the tank is sufficient and not too low. If the water level is too low, it can cause the spray function to malfunction.
- Check the water supply hose: Make sure that the water supply hose is properly connected and not kinked or damaged.
- Check the spray nozzle: Make sure that the spray nozzle is not clogged and is able to rotate freely. If the nozzle is clogged, it can prevent the spray function from working properly.
- Check the motor: If the motor is not functioning properly, it can cause the spray function to malfunction. To check the motor, you can try running the vacuum without the hose or attachments to see if it is functioning properly. If the motor is not functioning properly, it may need to be repaired or replaced.
If these troubleshooting steps do not resolve the issue, it may be necessary to take the vacuum to a professional for repair.
My numatic nvh 370, when I turn it on to use the air at it blow out smells, Why is that? Please thanks
If any moisture has entered the vacuum at any time then this will cause a musty smell. Does the primary filter have discoloration or a yellowy stain on it? this usually indicates moisture has been present at some stage. Replacing the filter may help or you can place a small sachet of air freshener beads (glade) in the bottom of the canister under the bag. This will give a pleasant smell whether vacuuming or blowing.
LOUD NOISE NUMATIC NV200 .What can it be?
Hi Elizabeth.It depends how old the machine is and how much work it has done.It could be the motor needs replacing and most good vac repair shops can do this for you.Hope you get it sorted.
You could contact Numatic technical on 01460 68600
How do i pull the poles apart?
If you have a bath, I suggest that you run a couple of inches of hot soapy water and leave them to soak for half an hour.When you take them out twist and pull the tubes at the same time.
If they still do not come apart hold at 45% to the floor and tap one end lightly on the floor (not so hard that you damage anything) turn a little after each tap, then try again to twist an pull them apart.
When you do part them clean the joint where the tubes touch and then rub will a little cooking oil on a piece of kitchen roll, makes them easier to part next time.
