20 Most Recent
Trekstor i.Beat move MP3 Player Questions & Answers
How can i download music in my mp3?
You can download music to your MP3 by connecting it to your pc using the usb cord that goes along with your MP3 player. You can either get songs from the internet or from a music cd. If you have songs that are already in your my music folder you can download it to your MP3 by clicking the music file then right click the mouse. In the drop down command select send to and choose your MP3 to be the storage drive that will receive the file.
Not able to use it crashed
if you still have a warranty, you can send it in for repair. I had the same problem and used the extended warranty to have it repaired. or you can go to the website and download the updated firmware to try and solve the problem. Hopefully the operating system doesn't have to be replaced.
Software missing or software update
You can list out many things that play around you, having software in it. Without software, there would have been no such thing called 'Google' or maybe, we wouldn't have known 'Any better way to exchange knowledge through the internet as a medium. The software can be written by anyone, who wants to see something that can work for every other person in this world. 'Look around! Its software running behind at Vilmate
https://vilmate.com/service/software-development/
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
