20 Most Recent
Samsung F490 BLACK @GIFTS & BRAND @ Cell Phone Questions & Answers
I cant make outcalls i
reading the user instructions you will see that the phone has to be charged for 6 hours before use
How do u unlock my phone
Do you mean the network unlock?You can approach
Prounlocking.com and specify the country,locked network of your Samsung F490.Based on the availability you can get the unlock code along with free unlock instructions.
Service not allowed samsung...
On samsung wave go
Settings->Call->All Calls->Show my number-> "By network" has to be set for making calls If HIDE is set it will throw "service not allowed" when making calls!!
My samsung SGH-F490 Does not
i made videos from my samsung f490v and when i want to run these videos from my computer they does not show these videos. what i do now???????????
My samsung f490 cell has a problem that audio is
JUST RESTORE YOUR MOBILE AND SWITCH OFF THE MOBILE FOR SOME TIME .WHEN YOU WILL BE ON YOUR MOBILE HOPE THIS WILL BE WORK FINE .OTHERWISE GO TO THE SERVICE CENTER.BECAUSE OFF MORE EXPERIMENT MAY HARM YOUR DEVICE .
I HOPE THIS WILL BE HELPFULL TO YOU.
PLEASE RATES ME .
GOODLUCK........
How to connnect to pc
Hi there USE USB data cable for connection. Connect the phone with this USB cable and other end should be in PC. Then go in phone setting and select the connectivity mode as USB. once you done the PC detect the phone. Thanks
PAWHEN I MAKE A CALL
your best bet is to use another phone to call and ask them about it
the might just refresh your service and it would be fine
Puk code
UK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the PUK code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
Samsung S9 turning Samsung Music app on by itself
This seems to be a known issue where the Samsung Music app starts randomly1. Here are a few steps you can try to resolve this issue:
Check if an app you downloaded is causing the problem: Start the phone in Safe Mode. If the problem does not occur in this mode, then you need to find out what app this is and uninstall it.
Wipe the cache partition of the phone from the recovery mode: This can often resolve issues with apps misbehaving.
Perform a factory reset: Please remember to backup your phone data before doing this. Once the reset is complete, do not install any apps in your phone yet. Try to check first if the issue still occurs.
Check Power Saving Mode: The power saving mode could interfere and block your music-streaming app if turned on.
If none of these steps work, it might be a good idea to contact Samsung's customer service for further assistance.
