20 Most Recent Haier HPAC99ER Portable Air Conditioner Questions & Answers
Water leek
Where is your AC leaking at, can you tell? This is common, but the leak of water should not end up in your house--but outside; this occurs as a result of the failure of your AC tubing or pump. The accumulation of water is a part of the normal process of condensation. Here's a really good diagnostic article that talks about water accumulation and leaking AC systems:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Creates_Water_Puddle.htm
Read the article, and, actually, your best bet may be to take advantage--towards the end of the above-linked article--of the text-link for Free four (4) quotes from local AC contractors in your area (click the link that sasy"Find A/C Contracts. Get Up to 4 Quotes"), and "pick the brain"--seek the advice--of these local technicians who offer you a free quote to discern whether your AC tubing or pump is the problem for your water accumulation.
8/9/2009 6:58:29 AM • Haier HPAC99ER... • Answered on Aug 09, 2009
Haier CWH24A. It isn't heating now that it's back on Heat mode
Question edited for clarity and add maker. Try a reset. Disconnect mains power for at least 2 hours. Reconnect and wait 5 minutes before turning on. This resets the mainboard and initiates a self test procedure. https://www.google.com/search?q=+Haier+CWH24A+not+heating+up ..
11/5/2023 9:53:52 PM • Haier Heating &... • Answered on Nov 05, 2023
Please my Haier Thermocool Ac automatically sets to 26c when I set it to 16 or any other number. It decreases slowly to 24 and stays there. Please what can be the cause of this? I need answers.
You will be able to get the answers from Haier support in your country. We are Fixya, not them. It sounds like a control board fault. You can try a reset. Turn it off at the breaker for 2 hours. Switch it back on and wait 5 minutes before turning the unit back on with the remote. https://www.google.com/search?q=Haier+Thermocool+AC ..
9/18/2023 6:30:27 PM • Haier Heating &... • Answered on Sep 18, 2023
Haier mini split E7 and exterior fan not working
On a Haier Split system a E7 error is a failure of the outdoor inverter PCB and the outdoor power supply PCB. Both will need replacing. Looking around $600 for those parts. Plus fitting. The indoor PCB is very unlikely to be needed.
11/8/2022 6:04:59 AM • Haier Heating &... • Answered on Nov 08, 2022
2answers
Remote for haier split- ac hsu-18dx"?
Window ac
9/20/2022 5:13:07 AM • Haier Heating &... • Answered on Sep 20, 2022
2answers
How do you add freon to haier window unit air conditioner
Window units do not come with service ports. You can buy them at local parts houses, but unless you have the freon, not gonna do you any good. Window ac use either r22 our 410a, and that cannot be bout without being certified.
8/7/2022 5:21:47 AM • Haier Heating &... • Answered on Aug 07, 2022
Haier air conditioner fan turns off when compressor is off
switch fro auto to cool function.
7/21/2022 6:20:08 AM • Haier Heating &... • Answered on Jul 21, 2022
2answers
Haier portable AC keeps displaying FL error code, even after i empty the water bucket, WHY?
Having the same issue, it's a shame the only answer is telling you to do what you clearly said you had already tried.
6/23/2022 11:48:02 PM • Haier Heating &... • Answered on Jun 23, 2022
2answers
Brand new portable AC. AC compressor comes on but doesn't seem to be cooling for long
Take it back and get another one. Once you try to work on it, void the warranty.
6/9/2022 12:17:02 PM • Haier Heating &... • Answered on Jun 09, 2022
We have a wall mounted Hair air conditioning unit
This is a communication error between the indoor and out door units.
2/21/2022 5:21:30 AM • Haier Heating &... • Answered on Feb 21, 2022
3answers
Where is the drain hole
Hello, some window units do not have a drain hole for the condensate, instead the use the fan blade to sling the water on the condenser, since the condenser is warm/hot it will evaporate the condensate.
7/9/2021 1:05:48 AM • Haier Heating &... • Answered on Jul 09, 2021
How do you disassemble a Haier portable air conditioner
The screws are hidden behind plastic plugs. Remove them and undo the side panels. Once they are off you can get to everything else. https://www.google.com/search?q=disassemble+a+Haier+portable+air+conditioner ..
7/3/2021 5:35:29 PM • Haier Heating &... • Answered on Jul 03, 2021
I have a small Haier window A/C unit and lost the remote. The temperature is on Celsius for some reason. How do I change it back to Fahrenheit?
It is likely a Haier, not a 'Haiser'.. It is a AC Unit, so shouldn't be in the Category Cars and Trucks. I can change those. Your answer is twofold; You need a remote, Google make model replacement remote You pressed a button combination set, Google make model manual
6/29/2021 4:19:34 AM • Haier Heating &... • Answered on Jun 29, 2021
What size gas pipe is used on haier air conditioner 4u30hs1era
Please follow the Haier 4U30HS1ERA manual (manualscat.com) here. Hope it helps. Good Luck!
6/21/2021 7:25:18 AM • Haier Heating &... • Answered on Jun 21, 2021
Have floor portable Haier air conditioner (not window) model CPF12CLLB & need to know how to remove front cover
Haier offers window and portable AC units to fit your space and keep the temps ... Haier window air conditioner ultra quiet serenity model. ... Coming in at 43 dBA, it's the quietest window AC on the market*. ... Get AC When & Where You Need It ... excess moisture is removed from the air without you having to empty the unit. For more click here
4/23/2021 4:51:09 AM • Haier Heating &... • Answered on Apr 23, 2021
E1 on haier thermocool side by side refrigerator
That error is a freezer fan motor error, Check to see if the unit is defrosting like it is supposed to be. IF it is defrosted, check to see if the motor spins and if you have a meter for measuring resistance, check the motor windings. If they show no conductivity, Replace the fan.
2/23/2021 4:00:15 PM • Haier Heating &... • Answered on Feb 23, 2021
Heating & Cooling Logo
3 questions posted
Top Haier Heating & Cooling Experts
Paul Carew
Arnie Burke
Arnie Burke
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Heating & Cooling
Most Popular Question
water leek
  • Heating & Cooling
