20 Most Recent Casio GA-110-1B GA110 G-Shock Alarm World Time Analog Digital Watch Questions & Answers
I cant get the arms to automatically set themselves
About Self-Winding Automatic Watches - Self-Defense Armory
www.selfdefensearmory.com/aboutautomatics.html
about mechanical watches, self-winding, automatic watches. ... Secondly, and this is where it gets a little hazier, people buy automatics for reasons that cannot be clearly ... Self-winding automatic watches depend on the movement of the arm to ... Avoidsetting the day and/or date (if your watch has these functions) at night.
About watch movements: technical details
12/26/2015 11:10:55 PM • Casio GA-110-1B... • Answered on Dec 26, 2015
I need a detailed description of how to set the date on my casio g- shock watch
Setting the date on a Casio G-Shock watch can vary depending on the specific model you have. However, in general, you can follow these steps:
  1. Make sure the watch is in timekeeping mode. Press the button at the 2 o'clock position to enter the timekeeping mode.
  2. Press and hold down the button at the 4 o'clock position. This will activate the settings mode.
  3. Use the button at the 2 o'clock position to navigate to the "Timekeeping" or "Time" setting. Press the button at the 4 o'clock position to select it.
  4. Use the button at the 2 o'clock position to navigate to the "Adjust" or "Setting" option. Press the button at the 4 o'clock position to select it.
  5. Use the button at the 2 o'clock position to navigate to the "Date" option. Press the button at the 4 o'clock position to select it.
  6. Use the button at the 2 o'clock position to adjust the date. Press the button at the 4 o'clock position to confirm the date.
  7. Press the button at the 4 o'clock position again to exit the settings mode. Your watch's date should now be set.
Note: If your watch model has different button configuration, please refer to the user manual for the specific instructions.
1/29/2023 2:34:08 AM • Casio Watches • Answered Yesterday
Casio module 4722 issues.
The issue you are describing with your Casio module 4722 watch in the HM (hand setting) mode sounds like a mechanical problem with the watch movement. It is possible that the gears or other internal components that control the movement of the hour and minute hands have become damaged or jammed. This problem could be caused by a variety of factors such as impact, moisture, or wear and tear. In order to fix this issue, it is best to take the watch to a qualified watch repair professional who can diagnose and repair the problem. They can determine if the problem is a minor one that can be fixed quickly or if a more extensive repair is needed. It's also a good idea to refer to the manufacturer's manual for troubleshooting steps and warranty information, as some issues may be covered under the warranty.
1/22/2023 7:20:39 AM • Casio Watches • Answered on Jan 22, 2023
My casio 5177 558d stop watch second hand is not working from one week.before a week its work works properly
It sounds like there may be an issue with the movement of the second hand on your stopwatch. There are a few possible causes for this problem. One possibility is that the battery in your stopwatch may be running low and needs to be replaced. Another possibility is that there may be a problem with the mechanical movement of the stopwatch. This could be due to a loose or broken part, or it could be a result of wear and tear over time. To troubleshoot the issue, you could try replacing the battery in the stopwatch to see if that resolves the problem. If the problem persists, you may need to have the stopwatch serviced by a professional watch repair technician. They will be able to diagnose the problem and repair or replace any faulty parts.
1/7/2023 10:57:13 PM • Casio Watches • Answered on Jan 07, 2023
How to make my Casio watch band smaller ?
To adjust the dual time on your Tommy Hilfiger watch model 1791709, follow these steps:
  1. Press the "Mode" button to enter the dual time mode. The dual time mode is indicated by the small "D" at the top of the display.
  2. Hold down the "Adjust" button for a few seconds until the hours digit starts flashing.
  3. Press the "Adjust" button repeatedly to adjust the hours of the second time zone.
  4. Press the "Mode" button to move to the minutes digit, which will start flashing.
  5. Press the "Adjust" button repeatedly to adjust the minutes of the second time zone.
1/6/2023 10:48:24 AM • Casio Watches • Answered on Jan 06, 2023
Hoe kan ik een handleiding vragen van Casio. No.3464. Heb een Casio horloge gekocht maar is geen Nederlandse handleiding bij?
Question edited for clarity 'casino' to 'Casio'. Only English on Fixya please. We are in North America. Question moved to Casio Watch category. https://www.google.com/search?q=casio+watch+netherlands ..
12/25/2022 10:37:15 PM • Casio Watches • Answered on Dec 25, 2022
G-shock GA 2100 - New batteries drain in couple of hours
The battery compartment may not be making proper contact with the batteries. This can cause the batteries to drain quickly or not work at all. Make sure the batteries are properly seated in the compartment and that the terminals are making good contact with the batteries.
The watch may have a faulty component that is draining the batteries. This could include the display, processor, or other electronics in the watch. If the watch is under warranty, you can try contacting G-shock customer service for assistance.
The watch may have been damaged during the repair process. If the watch was mishandled or damaged during the repair, it could have caused a problem with the battery compartment or other components of the watch.
To troubleshoot the problem, you can try the following steps:
Check the battery compartment: Make sure the batteries are properly seated and making good contact with the terminals. Clean the terminals and the inside of the compartment with a soft cloth if necessary.
Check for faulty components: If the watch is under warranty, you can try contacting G-shock customer service for assistance. They may be able to help you diagnose and repair any faulty components.
Check for damage: Inspect the watch for any visible damage that may have occurred during the repair process. If you find any damage, you may need to take the watch to a different repair shop for further evaluation and repair.
12/24/2022 4:29:25 PM • Casio Watches • Answered on Dec 24, 2022
2answers
Casio C-801 batteries.....?
You need two SR1120 or type 391s.
12/24/2022 11:32:35 AM • Casio Watches • Answered on Dec 24, 2022
Casio G-Shock 3344 701d. How to fix time hands please?
Question edited for clarity. You just read the manual, page 1 bottom right :>D
Casio 3344 user manual (English - 3 pages)
https://www.manuals.ca > Watches > Casio View the manual for the Casio 3344 here, for free. This manual comes under the category Watches and has been rated by 1 people with an average of a 5.8.
Operation Guide 2759/3344 - Support
https://support.casio.com > manual PDF About This Manual. • The operational procedures for Modules 2759 and 3344 are identical. All of the illustrations in this manual show Module 2759.
12/1/2022 5:26:23 PM • Casio Watches • Answered on Dec 01, 2022
Manual for Casio 4309 watch please?
Question edited for clarity. It is here https://www.manualslib.com/manual/890753/Casio-3770.html ..
12/1/2022 5:21:24 PM • Casio Watches • Answered on Dec 01, 2022
How can I disable the hourly beep of Casio AE-1200whb-3bvdf watch please?
Question edited for a little more clarity. This is one of those watched with multiple dials and dozens of functions. It sounds like there is an hourly repeating alarm at 10 minutes to the hour. All time zones are synchronised to the top of the hour. The best thing to do is remove the batteries for 2 minutes and replace them. Then set the time again. https://www.google.com/search?q=Casio+AE-1200whb-3bvdf+watch+manual ..
12/1/2022 5:13:41 PM • Casio Watches • Answered on Dec 01, 2022
2answers
Wv-59 battery change
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi3ubnCjK76AhUYBDQIHdsDAbwQwqsBegQIBRAB&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DeRy0JlsjfqQ&usg=AOvVaw3hOvdMy7BXU6XfkxuFHigB
9/24/2022 8:25:41 PM • Casio Watches • Answered on Sep 24, 2022
Casio GA-110-1B GA110 G-Shock Alarm World Time Analog Digital Watch Logo
1 questions posted
Top Casio Watches Experts
David Shaub
Jaime Hernandez
Marvin
Marvin
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
get arms automatically set themselves
  • Watches
