20 Most Recent
Haier HSU12XCA Cooling Only Mini Split Air Conditioner Questions & Answers
F7 error
f7 is is the: Compressor temp. sensor error
I i`ve got a haier
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
My HSU12XCA is icing up
The icing problem is caused from either low airflow across the evaporator coil (inside coil) or a low charge of refrigerant. Make sure your inside coil and air filter are clean and the fan is running at normal speed, if those are OK then call a service tech to check the refrigerant charge and adjust as needed.
My HSU12Xca Haier Ac shouting some ice inside my
Hi!!
It is the drain tube clogged or the unit is not leveled.
The drain tube is on the right side of the air handler, if the unit is leveled, lift front grill and remove the screw fastening the small cover on the bottom right corner, remove cover, you should be able to see the drain hole, use a piece of wire to unplugged, if that does not work, go outside and blow on the drain hose to clear the obstruccion.
Good Luck!! Don't forget to rate this post!!
Haier mini split E7 and exterior fan not working
On a Haier Split system a E7 error is a failure of the outdoor inverter PCB and the outdoor power supply PCB. Both will need replacing. Looking around $600 for those parts. Plus fitting. The indoor PCB is very unlikely to be needed.
Where is the drain hole
Hello, some window units do not have a drain hole for the condensate, instead the use the fan blade to sling the water on the condenser, since the condenser is warm/hot it will evaporate the condensate.
