20 Most Recent Haier 5 cu. ft. / 142 liter Chest Freezer HCM050PA Questions & Answers
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Haier 5 cu. ft.... | Answered on Feb 02, 2011
hi there.....sounds as you need a new defrost heater unit fitted.....if your unsure how to do this contact beko service.....
regards Sir Galahad
Haier 5 cu. ft.... | Answered on Feb 05, 2010
bin it. it is cheaper to replace than repair.other than the fuse that is.
air/water volume in cavity
orange is fast freeze,green is on,
Bypass the cold control and see if it comes on. If it does then change the cold control if it dont then examine the compressor relay and see if it is burned up. If the compressor relay ain't it then you have a bad compressor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Haier 5 cu. ft.... | Answered on Mar 07, 2009
Sounds like the unit has quit, or check the wall outlet to insure there is power there.
Haier 5 cu. ft.... | Answered on Nov 29, 2008
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
Haier 5 cu. ft.... | Answered on Nov 08, 2008
you search on net.
Haier Freezers | Answered on Dec 13, 2019
You can try resetting it by unplugging it for 10 minutes.
The Ed error code is referring to the defrost heating system.
Haier Freezers | Answered on Oct 28, 2019
Haier 5 cu. ft. / 142 liter Chest Freezer HCM050PA Logo
15 questions posted
Top Haier Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
jdthefixer
Marvin
Marvin
Are you a Haier Freezer Expert? Answer questions, earn points and help others
View Most Popular
Haier Freezers
  • Haier Freezers
Most Popular Question
wondering switchs
  • Freezers
