20 Most Recent
Haier 17 in. HDT18PA Built-In Dishwasher Questions & Answers
Haier dishwasher did not pump out
I had problem like this...one day the washer stopped, still half-full of water. Then, we tried to run again and we could hear the little engine working but it wouldn't let water in OR out, just error beaps.
Then my boyfriend took off the back and gently tapped the water inlet valve solenoid with his screwdriver, and now it works! Starting FILLING actually, not draining, but completed a full cycle finally!
Must have shaken loose a blockage in the mechanics in that solenoid, probably have to replace before long. But for now, success!
Here is a website that helps:
http://www.searspartsdirect.com/Haier/dishwasher/model-Esd301-repair/categories/dishwasher-repair/symptom/dish004.html
(See "REPLACE WATER INLET VALVE", half-way down page)
Drain pump not working.
i use rapid program 30 M it is work suddenly 12 MINUTES ITS STOPwater cannot go out side after they make sound10s E4
Dishwasher will not empty
the control board could be bad and not sending the signal to pump it out or if its not electrical then there could be air in the lines. take the unit out and completely drain the drain line completely to get all air gaps out.
check to make sure nothing is binding the impeller, ie: broken glass, coins, twist ties, plastic bag.
Lots of water under dishwasher
I use the tablets too. A simple change of soap won't create or cure a leaking dishwasher. I own the same HDT18PA dishwasher, also known as a POS.
Where is the leak coming from? You will need to remove both the shell and the lower pan from the dishwasher to be able to find this part. It is a water guide from the pump body that connects to both the lower spray head and the upper spray head. This is the MAIN water plumbing, once the water is within the dishwasher.
The part is manufactured from TWO pieces of plastic, and not melted together very well. The pressure from the pump is considerable, and these pieces of plastic have a large amount of flex applied from the INSIDE to them. They WILL FAIL, it is only a matter of time.
But in a statement to the build quality of this Haier, not even the BRICK that you will find zip-tied to the inside of the casing will be damaged by this leak... Only your counter, cabinets, kitchen... Those will all suffer from the Noah-esque floods that will be visited upon you when it fails without warning.
I've already taken this thing apart and rebuilt it once, using a heat welder to REALLY seal this plumbing together. It lasted 2.5 years of 1-2 times per week usage, and has now failed again.
I will not be replacing this in it's built-in location that I designed in my RV until it is either fixed with a METAL part that I will have to fabricate, or I find a new dishwasher.
Feel free to contact me at geordi [at] spamcop [dot] net if you would like more information. Please note that this address leads DIRECTLY to a spam filter, so make your subject line look like anything other than spam if you would like me to read it. --Jim the RV Doctor
Leaks from bottom
Pull service panel at base of dish washer and tell me if water is underneath. Should read owners manuel if you have it. most likely leaking from where it connects to kitchen sink or a loose drain hose under the unit. Easy fix if this us the true problem
Haier countertop dishwasher will not
There is a filter at the bottom of the tub that has to be cleaned out once in a while. Then it will drain. This should help. It is a plastic looking mesh filter most can be removed and hand washed. Hope this helps.
Hose sizes
compactappliance.com has stats on the models they sell. I think this one's hoses were 4 feet long.
Haier dishwasher CDW300SS beeping 10 times and 4
I put to much soap in resulting in bubbles coming out every where I tipped it back and then back forward and bam it's back to normal again been running it for over an hour now
3/19/2022 12:52:31 PM •
Haier...
Answered
on Mar 19, 2022
