20 Most Recent Haier HRF08 Top Freezer Refrigerator Questions & Answers
this happens of voltage fluctuation...so u should bring a good electrician and he will check all the wiring is it proper...then this wont happen again...cheers!!!
Haier HRF08 Top... | Answered on Jul 25, 2009
first off all the cold air comes from the freezer. you need to remove the freezer floor and then the back to make sure the evaporator is not all frozen up with ice. If it is you have a defrost problem. You would need to check the heater the terminator and the defrost timer. If the coils on the evaporator are not iced over and there is only a little frost at the top or none at all either the compressor is not working or there is a leak and the unit is out of gas. You need to check the thigs I just described and go from there.
Haier HRF08 Top... | Answered on Jul 26, 2007
https://www.youtube.com/watch?v=O2WbsdfQU3k
Haier... | Answered on Apr 19, 2020
Do you have a 4" gap at sides, top and back?
when was the last time you pulled it out and vacuumed the condensor coils?
Haier... | Answered on Jul 22, 2019
In most cases hair tend to grow in a course of 4 - 6 months after hair transplant is done. In some cases it may take 6 - 12 months. There after hair growth tends to improve over time. According to the quality of the grafts implanted and perfection you may get better results in hair growth. I did my transplant from hair transplant Toronto and my hair started to grow within a span of 4 - 5 months.
Haier... | Answered on Jun 30, 2019
Hi Brett,
When the Haier refrigerator shows an error code, try this before replacing any parts or taking the refrigerator apart...
- Power the Haier refrigerator OFF for 10 minutes, then power back ON. (Unplug the refrigerator for 10 minutes) -
The error code may disappear after a reset is completed.
- If after removing power to the refrigerator in an attempt to reset, the error code comes back,the freezer fan is bad and need to be replaced.
Here is a link to Haier Parts.
Also make sure there is No Recall on your particular model or serial.
Best of luck,
JP
https://www.haierappliances.com/parts
Haier... | Answered on Jun 18, 2019
Broken compressor isolation mounts maybe.
Haier... | Answered on May 31, 2019
Not sure what all could be wrong but sounds like your freon gas is low. That is a good place to start.
Haier... | Answered on Mar 13, 2019
Look for the condenser grills and make sure they are clean of fluff. Sometimes they are on the rear, sometimes behind a kick plate at the front, or behind a cover at the rear.
Haier... | Answered on Mar 05, 2019
Unplug and leave for 4 hours . then plug back in . turn temp up and reach in the back of fridge and see if you feel cold coming in from the vent. If not replace fan motor in freezer side .
Haier... | Answered on Mar 04, 2019
No, it probably has low gas or the thermostat is faulty.
The only thing do can do is make sure the condenser fins are clear of fluff.
Haier... | Answered on Jan 04, 2019
use a hair dryer for a minute or so on it
Haier... | Answered on Dec 21, 2018
Haier HRF08 Top Freezer Refrigerator Logo
5 questions posted
Top Haier Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Haier Refrigerators
  • Haier Refrigerators
Most Popular Question
water accumulates bottom refrigerator
  • Refrigerators
