20 Most Recent Nintendo Wii Sports for Wii Questions & Answers
Try cleaning off the disc with a cotton swab and some alcohol. Let it dry before inserting the disc back into the WiiYou could also be getting that error because the disc is insert in the wrong direction. Try turning it around,
Nintendo Wii... • Answered on Jul 28, 2012
My guess is that she changed the character before putting it in mii parade. The same situation happened to me, however if you simply put them in mii parade without changing it should be fine. It does note too when you put someone into mii parade that it has the potential to lose data, so it seems unfixable as of yet.
Best of luck,
-Aaron C.
Nintendo Wii... • Answered on Dec 30, 2011
Hello there
From what you have said it sounds like you have the DISK DRIVE READ ERROR
The main causes are Hardware failure, overheating or wear & tear.
You may need to perform simple maintenance, clean or in some cases adjust settings.
To get the best advice on where to start I recommend a Wii REPAIR GUIDE, From this you can fix the problem at home and avoid any large repair bills. Its easier than it sounds when you have help from the guide.
Me and my friends use this very good Console Repair Website.
The other solution would be to send the console off to Nintendo, This is free if your still in warranty. If your console is out of warranty then the usual price of repair is $100
I am Glad I could help and You can help others by rating this Post or leaving a comment.
Many thanks
Peter Fix
Nintendo Wii... • Answered on Jan 13, 2011
The disk needs to be in the wii
Nintendo Wii... • Answered on Nov 07, 2010
From what I can understand, this has nothing to do with the controllers. Check your AV wiring. It sounds like you just didn't plug them into the right port in your television. Hope this helped, and tell me how it worked out!
Nintendo Wii... • Answered on Oct 12, 2010
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
http://store.richspsxparts.com/wiiredvddr.html
Nintendo Wii... • Answered on Sep 21, 2010
Everytime you win a tennis match, your skill level will go up. The higher the skill/the strength of your wins will determine what skill level you face next. Bowling skill ranks are determined on how well you do in each game. Once you reach PRO, you get a sparkling ball. Keep trying at both Tennis and Bowling and you should see your skill rating start to rise. Good Luck!
Nintendo Wii... • Answered on Jul 07, 2010
You have to hold "A". If you release before hit you swing at nithing.
Nintendo Wii... • Answered on May 11, 2010
No, You have formated the system. Format means erase!!
Nintendo Wii... • Answered on Apr 29, 2010
this will happen if your sensor cant see your wii remote or the way your holding the remote
Nintendo Wii... • Answered on Feb 18, 2010
Greetings,
Please go through the Website link mentioned below.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/gameDiscs.jsp#wont_play
Please let me know if you have any issues.
Regards,
Nintendo Wii... • Answered on Feb 16, 2010
the name cant be facing going into the wii it faces the other way
Nintendo Wii... • Answered on Feb 07, 2010
i thnk you just need to do a system update and that should rectify this.....it happened me too and this solved it
Nintendo Wii... • Answered on Jan 01, 2010
I have had a problem of this manner before, Does this problem occur with the same controller (wii remote) with each game requiring Movement of some sort. If so, then your Controller's bluetooth is damaged. It's a possiblity someone dropped it or the solder piece became loose in someway. I recommend sending it to nintendo for a replacement or buying another Wiimote (wii remote)
Nintendo Wii... • Answered on Nov 17, 2009
Nintendo Wii Sports for  Wii Logo
30 questions posted
Popular Products
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Aron
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Nintendo Video Game Consoles & Games
Most Popular Question
its not working says
  • Video Game Consoles & Games
