20 Most Recent
SVP Black Dual SIM Quadband I5180 with QWERTY Keyboard Unlocked - Bluetooth, Camera, FM/MP3/MP4/AVI, GPRS, WAP Questions & Answers
Power button
how do I get my SVP mobile phone alarm to work in the custom mode? It works in the once mode and everyday mode but it won;t work in the custom mode
Cant turn on, where is power button
There are 5 buttons on the phone. A center button and two to the right and two to the left. Press and hold the hang up button, the bottom right button, for a few seconds until it comes on. If that does not work then the battery needs to be charged. When it is connect to the charger it will display a battery icon on the screen filling with green blocks to indicate it is charging. If you do not see this try holding down the start/hang up button as discribed above. If you still do not see the charging icon on the screen then remove the battery, make sure the connection on the battery and phone are clean and not bent. Then put the battery back in and connect to the charger. It gets reset when the battery is removed and should now work. If it still does not charge then you have a bad phone.
Hard of hearing
check it by using head phone then same prob change the speaker
I bought an MW09 Cell
You need to contact your service provider (AT&T). They are the only one that can help you out with this. The internet and multimedia (MMS) message settings needs to be configured on your phone. This settings comprises of Username, password, IP Address, APN, etc. All these can only be gotten from AT&T and it cannot be gotten from anywhere else.
So, I urge you to contact AT&T and request for the settings from them. They will send it to your phone automatically or ask you to come over so that they can configure it for you manually.
By so doing, you will be able to browse with your phone after your phone has been configured.
I hope you understand the above directions......
Good luck.
I had a paper jam in this model: DM72C and I cleaned all the paper out but it won't start shredding again even though all the power lights are on and ready. What am I missing?
You were asked questions? I have been campaigning for this for 3 months. I told them you need a pop-up
All questions need 'make model (what it is)' as first 3 words.
You are missing the
maker, but you do mention 'shredding'.
Then I also said
'There are 40,000 categories to choose from'.
You chose
'Cell Phones'.
and it's not a 'memo', it's a question. :>)
So, first of all, disconnect it from the mains for 30 minutes. If you jammed it, you were working it hard, and when it jams, heat builds up in the motor and trips the thermal protection device. They have a thermal cut out, some have a thermal fuse what need physically replacing, but most reset when they cool.
Does it work in reverse? A jam can sometimes damage the switch in the throat of the shredder, some are a mechanical switch, some are an infra-red sensor.
https://www.google.com/search?q=DM72C
4/24/2024 12:12:23 AM •
Cell Phones
Answered
Yesterday
What is the difference between CEH V8 and CEH V9?
The difference between EC-Council's Certified Ethical Hacker v8 and the new Certified Ethical Hacker v9 is not the exam format, but the content itself. People seem to assume that since EC-Council updated the certification, the exam must be brand new. This isn't the case. In order to obtain the new CEH v9 certification, you do not need to study for and pass a brand new exam with new objectives and format. The test has the same format, is identical in size, and has the same amount of questions. There are only two things that changed. CEH V9 EXAM FORMAT AND BREAKDOWN The aforementioned v9 exam follows the same format and percentage breakdown of questions as v8. For example, the section on security will still take up 25% of the exam, while the section on tools, systems and programs will take up 32% of the exam. The full breakdown of the exam is visible on our . The Exam Details are as follows:125 questionsTo pass you need a score of 70%Maximum of a 4 hour durationMultiple choice formatHOW TO PASS YOUR CEH EXAM If you are studying v8 exam materials, you are not automatically going to fail the v9 exam. The test is updated, not revamped. This means there might be a handful of questions you may not necessarily have studied in depth for, but if you studied at all, you will have some familiarity with the new questions. The new questions are not on brand new material, they are more in-depth questions on topics that have become more relevant in the cyber security world over the last eighteen months. So you can still pass v9 studying v8 material.Should I still take CEH v8 Exam? However, if you study v8 materials you can still take the v8 exam. EC-Council has not retired the exam yet. So if you are not comfortable with the idea of taking an exam that you may not know 10-15 "new" questions, then don't. The only problem with this is that once the v8 certification does retire you will eventually need to take v9. Why prolong the inevitable then?Will I need to take the CEH v9 exam? If yes, then when? The test is updated on a rolling basis. This means that occasionally EC-Council adds new questions to the exam without updating the entire certification. The fact that v9 is now available means that there are new and updated CEHv9 study materials with a new focal point to deal with the always progressing world of IT.THE DIFFERENCE BETWEEN CEH V8 AND V9 With the update to the courseware, the exam covers certain questions differently. These questions focus on topics that are becoming more prevalent in the world of cyber security and IT. The key differences are:V9 focuses on cloud computing more than v8 did and dives into best security practices for dealing with cloud computing attacks.V9 covers mobile security and tablet computers and you must understand how to perform hacking techniques on these devices.v9 addresses new vulnerabilities in cyber security such as, Heartbleed, Shellshock, and POODLE.
CEH v9 vs v8 What New on the Certification Exam TechRoots
4/22/2024 6:43:13 AM •
Cell Phones
Answered
3 days ago
I'd like to update my stereo in my Citreon C3 (2007) to a double din header unit.
Let's explore your options:
Double DIN Stereo Upgrade Kits:
There are aftermarket double DIN stereo upgrade kits available specifically for Citroen C3 (2010-2016) and Citroen DS3 (2010-2019) models. These kits include everything you need for a seamless installation, including a fascia kit, plastic brackets, screws, blanking buttons, steering wheel control interface, antenna adapter, USB and AUX retention leads, and a universal patch lead.
The installation process involves removing the original single DIN radio, fitting the new plastic frame and fascia around the double DIN radio, and connecting the wiring harness and other components. These kits are designed to retain steering wheel audio controls and other features.
Keep in mind that dashboard modifications are required, so professional installation is recommended.
Connects2 Adapters:
If you choose an aftermarket stereo that isn't specifically designed for your Citroen C3, you can use a Connects2-style adapter to convert a compatible aftermarket stereo to control the screen above the radio (date/time, etc.) 3. This way, you can still access essential information.
For example, a Double DIN Android Auto-compatible stereo like the JVC KW-M560BT could fit in the space after removing the cubby and factory radio.
Some C3 models have a dash-mounted CD autochanger or other features that need careful handling during the upgrade.
Citroen C3 2009 Aftermarket radio upgrade - Double DIN (citroenc3owners.com)
Professional Installation:
Consult with a car audio installer or technician to choose the best solution for your specific Citroen C3 model. Regardless of the approach you take, professional installation is highly recommended.
4/20/2024 10:12:16 PM •
Cell Phones
Answered
on Apr 20, 2024
