20 Most Recent
Datel Gaming Headset for PlayStation 3 Questions & Answers
Lost my pass key for datel headset
The key for this headset should always be just "0000" without the quotes of course.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Playstation 3
Very odd that it will play Bluray DVDs but not games. It could be an issue with the harddrive since many games store important information the harddrive and then read it off of there. I suppose the issue could be cropping up because the PS3 cannot access that information on your harddrive thus causing it to fail to play those titles.
What you could try is backing up all the information you have on your harddrive and then formatting it etc. This should clear any corruption. To test if it is indeed any corrupted data then you can test a newly formatted harddrive and see if that allows you to play games just fine. If you have a spare 2.5" SATA HDD lying around, then go ahead and use that as your test drive (keep in mind it will have to be formatted by the PS3 etc).
Hope this helps.
Help! I need a user manual for a TR130 Headset. It
Are you sure it's the TR130? Because I'm seeing people reference the actual model to be RS130. (Well, went from SR130 with little results, then found several results for the RS130.) I also saw mention in one manual of a TR130, but it was in reference to the transmitter on another model.
The RS130 is a Bluetooth Headset from Sennheiser: http://safemanuals.com/user-guide-instructions-owner-manual/SENNHEISER/RS%20130-_E
If this isn't what you're looking for then apologies. Best of luck.
I got a datel headset that is supposed to be
I have one too...
It is very cheap. Cheap quality. Too expensive.
Anyway, it IS a USB plug, it just doesn't have the metal protecting thing like on regular USBs. It should fit in the bottom half of one of your USB ports near the bottom of you PS3. Make sure the side with the 4 bronze lines is facing up. Plug it in, follow the rest of the instructions, and then you're good to go.
