20 Most Recent Mitutoyo 0 150mm X .02mm Dial Caliper Questions & Answers
How do you rezero a 505-637 mitutoyo dial caliper
Fully close the caliper. The pointer should be pointing about straight up or close to it. Losen the knurled screw which is located on the circumference near the bottom. Now grab the dial and turn until the zero lines up with the needle. Re-tighten the knurled screw.
12/3/2010 3:35:16 AM • Mitutoyo 0 150mm... • Answered on Dec 03, 2010
I have an error on my mitutoyo CMM showing E650 on Joy stick
Verifica la presi?n de aire en la v?lvula de presi?n en la parte frontal de la cmm
12/27/2023 12:38:50 PM • Mitutoyo... • Answered on Dec 27, 2023
Assembly of Mitutoyo 6" micrometer
Repair, Calibrate or Request Field Service
Mitutoyo https://www.mitutoyo.com > Contact Us Whether you need immediate repair service or A2LA Accredited, NIST-traceable calibration of your measuring instruments, our highly skilled technicians ...
12/10/2023 5:31:06 PM • Mitutoyo... • Answered on Dec 10, 2023
Mitutoyo micrometer/caliper. How do I install new glass/plastic dial cover on 6 Mitutoyo micromonitor / calipher.
Mitutoyo https://www.mitutoyo.com > Contact Us Whether you need immediate repair service or A2LA Accredited, NIST-traceable calibration of your measuring instruments, our highly skilled technicians provide ...
Mitutoyo Repair and Calibration
Indicator Repair https://www.indicatorrepair.com > manufacturers > mit... Indicator Repair repairs, restores, refurbishes and calibrates all makes and models of Mitutoyo indicators, micrometers, gages, calipers and levels. ..
12/10/2023 5:23:26 PM • Mitutoyo... • Answered on Dec 10, 2023
Mitutoyo HDS-H24"C the NUMBERS JUMPING aROUND.
Send it in for repair and calibration
Mitutoyo https://www.mitutoyo.com > Contact Us Our highly skilled technicians provide fast, accurate and dependable service to keep your production operation running smoothly.
7/11/2023 11:10:26 PM • Mitutoyo... • Answered on Jul 11, 2023
No file error on PC after downloading readings taken from mitutoyo sj-210 surface tester? It used to come up with all readings taken any ideas?
There could be several reasons why the file error is occurring on the PC after downloading readings taken from the Mitutoyo SJ-210 surface tester. One possible reason could be that the file format of the downloaded readings is not compatible with the software installed on the PC. The Mitutoyo SJ-210 surface tester typically saves data in a proprietary format, which may require specific software to open and read the files. If the software is not installed or is outdated, it may result in a file error. Another possible reason could be that there is a problem with the USB cable or port used to transfer the data from the surface tester to the PC. A faulty cable or port can cause data corruption during transfer, resulting in file errors when attempting to open or read the files. It is also possible that there is an issue with the surface tester itself, such as a malfunctioning sensor or memory card. In such cases, it may be necessary to troubleshoot or repair the device before attempting to download any further readings. To resolve this issue, it is recommended to check if the software used to open and read the files is up-to-date and compatible with the file format used by Mitutoyo SJ-210 surface tester. It is also advisable to use a high-quality USB cable and ensure that both ends are securely connected. If these steps do not resolve the issue, it may be necessary to seek technical support from Mitutoyo or a qualified technician.
6/21/2023 8:30:41 PM • Mitutoyo... • Answered on Jun 21, 2023
Mitutoyo SJ-210 keeps resetting the PC communications settings to the default.
Might replace the battery?
5/13/2023 6:29:45 PM • Mitutoyo... • Answered on May 13, 2023
2answers
MItutoyo sj-210 surf tester keeps saying limit error. What do I do to fix this issue?
probably needs to be recalibrated
4/22/2023 11:52:59 AM • Mitutoyo... • Answered on Apr 22, 2023
Mitutoyo Bn706 E661 Error?
The E661 error can occur on the Mitutoyo BN706 machine due to a variety of reasons, including a misalignment of components or an issue with the machine's software. To fix the issue, it is recommended to check the components for any misalignment, inspect the machine for any hardware or software issues, and clean the machine of any debris or dirt buildup. Additionally, it is important to make sure all the software is up-to-date and that the machine is powered off and on again to reset it. If you are still unable to resolve the issue, it is recommended to contact the manufacturer for assistance. WETENSCHAPPELIJK VERSLAG 1990 VAN DE TECHNISCHE ... https://adoc.pub/wetenschappelijk-verslag-1990-van-de-technische-universiteit.htmlWETENSCHAPPELIJK VERSLAG 1990 VAN DE TECHNISCHE ... https://adoc.pub/download/wetenschappelijk-verslag-1990-van-de-technische-universiteit.htmlWETENSCHAPPELIJK VERSLAG 1991 VAN DE TECHNISCHE ... https://adoc.pub/wetenschappelijk-verslag-1991-van-de-technische-universiteit.html
2/15/2023 8:06:31 AM • Mitutoyo... • Answered on Feb 15, 2023
Mitutoyo error code E552?
Error code E552 is usually caused by a communication issue between the CMM and the computer. You can try restarting the CMM and the computer, and ensuring that all cables are properly connected. If the issue persists, you may need to take your CMM to a certified Mitutoyo service center for further diagnosis and repair.
2/15/2023 6:41:53 AM • Mitutoyo... • Answered on Feb 15, 2023
Mitutoyo SJ-210 displaying RETURNING constantly
Check link for use, calibration and manual. Or contact Mitutoyo direct for repair. https://www.google.com/search?q=RESET+A+SJ-210+SURFACE+TESTER ..
2/8/2023 4:46:03 PM • Mitutoyo... • Answered on Feb 08, 2023
What is E952 on mitutoyo Euro-c776?
Maybe this site would help...... http://www.cmmguys.com/forum/
1/16/2023 3:35:16 PM • Mitutoyo... • Answered on Jan 16, 2023
Mitutoyo error code E940?
Mitutoyo is a brand that produces precision measuring instruments such as micrometers, calipers, and height gauges. An error code E940 on a Mitutoyo instrument typically indicates a problem with the instrument's communication interface. This can be caused by a variety of issues, such as a problem with the instrument's cable or software, or a problem with the computer or device to which the instrument is connected. To troubleshoot the issue, you should first check the connections between the instrument and the computer or device to ensure that they are properly connected and secure. If the connections appear to be fine, you may need to update the software on the instrument and computer or device to resolve the issue.
1/12/2023 8:21:54 PM • Mitutoyo... • Answered on Jan 12, 2023
QM-Data 200 Mitutoyo with Optoeye-200. How to change or replace battery please?
Apparently the battery is Circuit Board mounted and is a backup memory battery. Li (lithium) battery • The Li battery is mounted on the printed circuit board in the data processing unit "QM-Data". Do not dispose of the data processing unit by burning it. If the data processing unit is thrown into fire, the battery may leak chemicals, burst, or burn violently. Comply with government regulations regarding the disposal method. and • This error message indicates that the memory backup battery is low, and that if you continue to use the data processing unit "QM-Data", backup will not be performed. Save the part programs and measured data stored in the internal memory of the data processing unit to the floppy disk or to a personal computer. • Contact your supplier to replace the battery. It also says changing the battery removes any saved data. So if you are looking to do it yourself, look for screws to get inside. https://www.mitutoyo.com/webfoo/wp-content/uploads/QM-DATA200_2222.pdf ..
1/29/2022 11:25:16 PM • Mitutoyo... • Answered on Jan 29, 2022
How do I reset a Mitutoyo SJ-210 surface tester. I get a returning error.
Question edited to add maker. Question moved from Office Equipment to Mitutoyo. See the link https://www.google.com/search?q=RESET+SJ-210+SURFACE+TESTER
1/29/2022 2:32:33 AM • Mitutoyo... • Answered on Jan 29, 2022
What mean error E812 on Mitutoyo BHN 305
I think you may have to contact their technical support for this answer. Such a link is on the following page: https://www.mitutoyo.com/products-and-solutions/software/mcosmos/
1/14/2022 1:07:10 AM • Mitutoyo... • Answered on Jan 14, 2022
2answers
How to correct an e671 error message
I realise this question is old, but you never know, might help someone in the future. This particular error is that the probe is not correctly seated, usually the magnets have become slightly loose. The solution is to take the probe head off the cmm, and push the magnets against your surface table or suitable flat surface, this should push the magnets into their correct position. If this doesn't help, it may be that you've managed to break that particular part, if you have a probe rack, try a different probe. Lastly, if you crashed the CMM by hitting something, ensure you didn't bend your probe in the process (and the ruby is still there!), this doesn't help the error code fix, but worth checking as the cmm crashing into something at speed is the most likely cause of this E671 error.
11/24/2021 3:25:06 PM • Mitutoyo... • Answered on Nov 24, 2021
MITUTOYO SJ 201 SETTINGS REQUIRED
Contact Mitutoyo directly to request the settings.
4/1/2021 4:21:26 AM • Mitutoyo... • Answered on Apr 01, 2021
Mitutoyo cmm error code e826
https://www.mitutoyo.com/wp-content/uploads/2016/09/L-section-CMM.pdf https://www.cmmmanager.com/forum/viewtopic.php?t=1377
4/7/2020 2:08:50 PM • Mitutoyo... • Answered on Apr 07, 2020
Mitutoyo 0 150mm X .02mm  Dial Caliper Logo
1 questions posted
Top Mitutoyo Measuring Tools & Sensors Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Mitutoyo Measuring Tools & Sensors
Most Popular Question
rezero 505 637 mitutoyo dial caliper
  • Measuring Tools & Sensors
