20 Most Recent Stanley 30-305 HI VIS MEASURING TAPE Questions & Answers
Yes, but it is a royal pain. The tape has a slot (some are "T" shape and some are tear-drop) in the end, and this fits on to a tension coil inside the unit. What you have to do is re-coil the spring and reattach the tape to it... that is assuming that the tape did not come out because it broke at the slot. There is no way to find out haw many times the spring must be wound, so it is all trial and error.
personally - I suggest waiting untill they go on sale and picking up a new one. I know that's not the answer you want, but it may be a lot easier.
Good luck.
Stanley 30-305... | Answered on Mar 24, 2011
you can try to pull the tape all the way out and then with a rag lightly oiled let the tape rewind back into the housing if that does not work then you probably need to purchase a new tape. for whatever reasona the spring inside has gotten weak. i use a tape daily and have had this same problem when a tape gets old or abused
Stanley 30-305... | Answered on Feb 22, 2011
Take the four corner screws out and the last center (short screw out). Split the shells in two pieces. Seperate the yellow or measureing tape from the black spindle tape. The spindle tape holds or attaches the measurement tap to the spindle. I have only seen a plastic spindle and this tutorial only applies to the plastic one. Take the spindle out and set the half casings on their backs, so you can see the cavity of the shells. The black spindle tape will be preformed to only wrap one way. Go ahead and attach the yello measuring tape to the black spindle tape. Pay close attention which side of the yellow tape is facing up or in our intended direction which is towards the center of the spindle. This way when you pull the tape out it is facing up for the person can see the measure marks. Wrap the tape tightly. If the tabs are broke and there's no way to secure the Yellow to the black, use two strips of Duct Tape and adhere the sections together. Do not use too much tape, since the clearance inside the spindle is tight. Once you wrap the tape inside, put a temporary piece of tape to secure the yellow and keep it from unraveling again. Next take a 1" wood screw and a battery powered drill and insert the screw into the center of the plastic spindle. Slowly tap the screw until it catches, do not drill the screw all the way in, only enough to catch in the plastic. Once the screw is partly into the plastic place the spindle into one of the half shells. The reason for the drill and screw is to return the tension back to the internal spring. Whichever side you placed the screw into you need to be sure to apply a clockwise turn. Keep the hex head of the drill so to not release the tension. At the same time place the spindle in the half shell and lock its square center piece into the shell. Now you can remove the screw from the center, then remove the tape holding the yellow meauring tape down, Still holding the measuring tape so it wont unravel, begin placing the last half shell on. Obviously you need to line everything up so the tape slides freely through its opening. Align the tape slide stop, which rests between the two shell halves. Replace the screws and remember the short one goes in the middle and holds down the belt clip.
Frank
Stanley 30-305... | Answered on Oct 17, 2009
stanley fatmax jumpstarter 1000A light wont turn off?
Stanley... | Answered on Sep 09, 2019
Most stud finders have a sensitivity adjustment that should be carefully adjusted per instruction manual before use.
Failure to do this results in erroneous indications.
If you have adjusted exactly per the instructions with the same result the unit is probably faulty.
Stanley... | Answered on Apr 04, 2019
here is the website:
https://www.stanleytools.com/products/hand-tools/flashlights-lighting/spotlight/waterproof-led-rechargeable-spotlight/fl5w10
and they say the warranty is 1 year:
Warranty
1 Year Limited Warranty
The manufacturer, Baccus Global warrants products against defects in materials and workmanship for a period of ONE (1) YEAR from the date of retail purchase by the original end-user purchaser ("Warranty Period").
If there is a defect and a valid claim is received within the Warranty Period, the defective product can be replaced or repaired in the following ways: (1) Return the product to the manufacturer for repair or replacement at manufacturer's option. Proof of purchase may be required by manufacturer. (2) Return the product to the retailer where product was purchased for an exchange (provided that the store is a participating retailer). Returns to retailer should be made within the time period of the retailer's return policy for exchanges only (usually 30 to 90 days after the sale). Proof of purchase may be required. Please check with the retailer for their specific return policy regarding returns that are beyond the time set for exchanges. Please call 1-877-571-2391 for more information or return instructions.
This warranty does not apply to accessories, bulbs, fuses and batteries; defects resulting from normal wear and tear, accidents; damages sustained during shipping; alterations; unauthorized use or repair; neglect, misuse, abuse; and failure to follow instructions for care and maintenance for the product.
O
Otherwise, check with the seller who sold it to your wife - If they are unwilling, and more companies seem to be going this route, go to the Manufacturer
Stanley... | Answered on Mar 04, 2019
Yes. Unless one was provided the standard is to just use an extension cord.
Stanley... | Answered on Feb 11, 2019
I have just read the device instructions and although the device offers usb charging or power up to half an amp it does not and cannot communicate digitally...
Stanley... | Answered on Feb 09, 2019
Stanley 30-305 HI VIS MEASURING TAPE  Logo
5 questions posted
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Stanley Measuring Tools & Sensors
Most Popular Question
stanley power
  • Measuring Tools & Sensors
