20 Most Recent
Black & Decker Auto Tape Measure Questions & Answers
How to rewind a tape measure
You'll need to take the tape casing apart but need special security torx bits to do that (a T-8 and T-9). Once apart (careful, two small springs inside) you can take the tape spool apart and rewind the tape to re-establish tension. Then re-assemble!
I have a BDS 300 sensor and have lost instructions
I just bought one too and instructions need deciphering. Select wood or metal with selector switch. Put unit flat against wall. Press and hold on/off button on left. (It looks like it must be kept pressed in at all times to be 'on' and when released it's 'off). The unit with calibrate and give a beep back and lower red LED will stay on. Move unit slowly left/right and more red LEDs light up until green is on. This is 1st edge. Mark it with pencil. Move unit along until Green is off and down to single LED. Then move it back in opp. direction until Green is on again. This is 2nd edge. Attached is a scan of page from Instruction Manual. Quality is lowish as attachment limit here is 150kb.
