20 Most Recent Black & Decker 8 Inch 12 Volt Cordless String Trimmer And Edger #CST800 Questions & Answers
How can I fix the feed mechanism for the trimmer line
is it new??? If yes, return it o the store and exchange it, if not new, mechanism is probably worn out
8/8/2014 4:38:13 PM • Black & Decker 8... • Answered on Aug 08, 2014
I have a Ryobi 700r
Remove the large spool bolt on the bottom. Remove the spool. Inside you will find a friction nut. Carefully pry it up around each side with a small flat screwdriver. If it gets damaged then it will need to be replaced (hardware stores will have this). Once it's off, you should be able to slide the remainder of the plastic spool off.
9/25/2010 1:29:57 AM • Black & Decker 8... • Answered on Sep 25, 2010
I've owned this great little Black and Decker
never charge batteries that long usually only 3to5 hours if ni-cd . most batteries last 3 or 4 years . totally discharge pack and try to charge again . if nothing buy new battery pack
6/17/2010 12:47:12 PM • Black & Decker 8... • Answered on Jun 17, 2010
How long to charge battery?
bateries have their own specifications.You can read it on the label.But,most of all it must be charge from 12-15 hrs. on its very first charging ( for a new battery) and later on or for the second time and so on, you may charge it 2 to 4 hrs.,sometimes 8 hrs..Leting you know,a battery can be charge even a short span of time,for example is 30 minutes only.In that 30 minutes try to measure its stored volt using a volt meter or a multi-tester,and the result is laready 12 volts (if your batery is 12 volts.)do you believe that? YES.! because a battery is so easy to store power.But,the problem is that its so easy to drain its stored power.You know why?because the current or amper of the baterry is still weak that the given specification.,.So,for short explanation,the longer time you charge your batery equals the longer time to drain the power.For example: when you charge the batery within 4 hours,thus the batery will be drained after 4 hours.
10/31/2009 8:54:23 AM • Black & Decker 8... • Answered on Oct 31, 2009
Does not automatically feed out line
I am a bit upset. I purchase a Black and Decker Trimmer and you guys want to charge me almost 10$ to give me a little bit of advise on a problem. Than I find in that email that if I have fixed the problem you want me to email you and tell you how I did it. FOR FREE. Well I did fix it. If you would like to know how mail me 10$. Only fair. [email protected]
1/29/2009 2:48:32 PM • Black & Decker 8... • Answered on Jan 29, 2009
How do i calibrate a black & decker BDL220S laser level
Rotate the laser to center horizontal (H) or vertical (G) bubble vials
9/11/2022 3:59:12 PM • Black & Decker... • Answered on Sep 11, 2022
2answers
I have a BDS 300 sensor and have lost instructions
I just bought one too and instructions need deciphering. Select wood or metal with selector switch. Put unit flat against wall. Press and hold on/off button on left. (It looks like it must be kept pressed in at all times to be 'on' and when released it's 'off). The unit with calibrate and give a beep back and lower red LED will stay on. Move unit slowly left/right and more red LEDs light up until green is on. This is 1st edge. Mark it with pencil. Move unit along until Green is off and down to single LED. Then move it back in opp. direction until Green is on again. This is 2nd edge. Attached is a scan of page from Instruction Manual. Quality is lowish as attachment limit here is 150kb.e4edea4.jpg
1/29/2013 10:11:15 PM • Black & Decker... • Answered on Jan 29, 2013
Black & Decker 8 Inch 12 Volt Cordless String Trimmer And Edger #CST800 Logo
16 questions posted
Top Black & Decker Measuring Tools & Sensors Experts
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Measuring Tools & Sensors
Most Popular Question
ve owned great little black decker
  • Measuring Tools & Sensors
