20 Most Recent
Dewalt D55154 Heavy-Duty Continuous 4 Gallon Electric Air Compressor with Panel, 1.1 HP, 3400 RPM Questions & Answers
D55154 compressor - chugs very slow upon initial
If the unloader valve doesn't release the pressure from the compressor it will be hard to start. This is because there will will be pressure inside the compresser. When the tank is full and the compressor shuts off, you should hear a rush of air which is the unloader valve releasing pressure. The unloader is like a one way valve.
How do I replace the electric motor brushes?
if you have to ask this question, you may be better off taking your air compressor to a service agent recommended by the manufacturer and ask them to do this for you. If you try this yourself and make a mistake, you could end up with a more expenseive repair bill.
(NEW D55154 COMPRESSOR ) I HAVE TO FLIP THE
Bad capacitor (or close to going) when you look on the motor is there a cap on top of it that looks like a dome? if it is still under warranty then call Dewalt and see if they will fix it for you.
Dewalt D55168 225 PSI Air compressor: What are the preset pressure limits for this model? Is it actually 225 - 180?
https://www.manualslib.com/manual/494085/Dewalt-D55168.htmlSpecifncationsMODEL D55168WEIGHT 88 Ibs. (39.92 kg)HEIGHT 41.75" (1060.5mm)WIDTH 19.0" (4826 mm)LENGTH 21.25 (539.8 ram)AIRTANK CAPACITY (GALLONS) 15 Gallon (56.8 fiters)APPROX CUT-_N PRESSURE 160 PSI (1103.2 kPa)APPROX. CUT-OUT PRESSURE 200 PSI (1379.0 kPa)SCFM @ 90 PSI (620.5 kPa_ 5._cant get fixya comment to work so will edit here...The 200/160 are the typical DS55168 settings from factory and meet the 90 psi @ 5.4 cfm rating.Pressures can be adjusted to a MAXIMUM 225/185 with a resulting lower cfm rate.I'm not familiar with "type 9". Likely nothing special just different setting from factory?
