20 Most Recent Honda Mmd 5000 Watt Generator W/ Engine Ngk 6000H Questions & Answers
I have a reading of 120 volts accross red and black leads but I am also getting 23 volts from either red or black to ground terminal. when I plug in a wiring tester it shows voltage on ground. What co
you need to tie into the 220 voltage at you breaker panel... 5000 watts will barely power your heater. you will not be able to power it direct as it needs low voltage for the control... but I am not an expert
12/28/2013 2:06:38 AM • Honda Mmd 5000... • Answered on Dec 28, 2013
Where can I find a pdf manual for a EB5000X Honda generator with a GX340 motor?
try ebay or amazon theyre quite good
11/29/2011 12:36:48 PM • Honda Mmd 5000... • Answered on Nov 29, 2011
No spark
Hi, Check the on/off switch is set to on. replace sparkplug check magnedo. Good luck.
8/4/2011 6:24:57 PM • Honda Mmd 5000... • Answered on Aug 04, 2011
Can my eb5000 generator run an electric 7hp
7 horsepower is approx 5150 Watts so the compressor would be taking this power while running. On startup however the compressor can take a surge of upto 3 or 4 times this power so the generator wouldn't be able to supply this demand . In any case it's not advisable to run a compressor off a generator unless the generator is high powered, 20KVA or greater for 7hp.
3/31/2011 11:09:20 PM • Honda Mmd 5000... • Answered on Mar 31, 2011
My engine is overheating seriously, what is
Plugged air filter, plugged exhaust or oil is old or not light enough wait.
9/2/2010 11:30:36 PM • Honda Mmd 5000... • Answered on Sep 02, 2010
Will not get the gas,and it is getting fire 9hp
try spraying starting fluid in to carb and crank away,itf it woirks then youi need carb work,if it does nothing then check the spark, then the comprussion, should be over one hundred
12/19/2009 1:41:52 AM • Honda Mmd 5000... • Answered on Dec 19, 2009
We are getting 155v on the 120 v receptacles
it may be running far to fast, just slow it down a little
how did you get this reading,,,on load or off load???
if off load hook up a light bulb and take another reading,,if its pulled the volts back down thats fine,,,if not plug in to the geny some thing thats close to its full load,,,"not more than this" now take the reading,,,
if still high lower the reves till its just 120v on full load
mind you,,,5000watts? thats a big un!!!!
11/19/2009 12:25:41 AM • Honda Mmd 5000... • Answered on Nov 19, 2009
Engine runs on choke
The Choke's function is to limit air intake till engine reaches opperating temperature.It should decrease to nill if auto.If not then try increasing the idle.Good Luck.
9/17/2009 1:45:44 AM • Honda Mmd 5000... • Answered on Sep 17, 2009
NGK-6000H Generator Field Coil Diode
If the doides have a number on them, goto www.nteinc.com and cross reference them to a good number. Then you can find a dealer on the web site also.
5/11/2009 4:59:33 PM • Honda Mmd 5000... • Answered on May 11, 2009
What e 21 fault code mean on a Honda generator eu6500is
I have a brand new Honda EU6500 flashing starts but then quits and gives error code E-21. Turns out the rubber batter hold down was undone and blocks air intake so engine quits. Put strap back in place and now runs fine.
8/21/2021 4:54:13 AM • Honda Electrical... • Answered on Aug 21, 2021
Have no output power on my pramac s5000 . Motor starts fine, flip CBS on, and motor surges a second.
Disconnect all loads before turning on breaker. Add one load at a time. Do not exceed generator capacity.
Comment below for further assistance.
6/18/2021 3:48:57 PM • Honda Electrical... • Answered on Jun 18, 2021
Honda generator EU65is. The overload indicator light will not shut off. Why?
It would normally show that you are drawing more power than the generator can supply. Videos in the link https://www.google.com/search?q=Honda+generator+EU65is+overload+indicator ..
4/18/2021 9:49:42 PM • Honda Electrical... • Answered on Apr 18, 2021
3answers
I have a gas generator a Honda and someone put 2cycle feul in it now it starts and runs for 20 to 30 minutes and. Stops it displays trouble code E-0A
The error code is for incorrect air/fuel ratio. The first thing to try and most common cause is a bad fuel filter. Try replacing the fuel filter. It is possible that the 2 cycle mix, since it contains oil, had gummed up the filter. I would also run some carburetor cleaner through it.
11/27/2020 10:56:34 AM • Honda Electrical... • Answered on Nov 27, 2020
2answers
Why wont my governor pull in when my Honda ex1000 is under load?
you may have a faulty actuator that governs it for you need to check if coil of actuator is excited with power when you draw current
8/23/2020 12:40:18 PM • Honda Electrical... • Answered on Aug 23, 2020
Honda Mmd 5000 Watt Generator W/  Engine Ngk 6000H Logo
21 questions posted
Top Honda Electrical Supplies Experts
Mike
john h
rostit
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Electrical Supplies
Most Popular Question
reading 120 volts accross red black
  • Electrical Supplies
