20 Most Recent Velodyne DD-15 Subwoofer Questions & Answers
One of the bottom aluminum
Unless you contact the parent company its close to impossible to get that feet. But you can buy a set of four rubber feet at any hardware store and replace them all.
The feet come off when one tries to push a heavy sub like Velodyne instead of lifting it off the floor and placing them . The rubber grip is so good on the floor and when we push the top part of the Sub the feet rip off.
7/29/2011 3:08:13 AM • Velodyne DD-15... • Answered on Jul 29, 2011
Need the Velodyne VX-11 fuse location & type ¿?
Already answered for DPS-12 in 2011 which suggests a fuse where the power enters, However, your manual mentions no fuse, but 'protection circuitry'. If there is a fuse, it will be inside and on a circuit board. All fuses have the rating on the end cap of glass fuses and on the side of ceramic fuses, which as also colour coded. https://velodyneacoustics.com/pdf/vx-11/VX-11Manual.pdf
Where to find fuse on velodyne vx-10b - Fixya
www.fixya.com > ... > Velodyne > VX-10 Subwoofer
Sep. 11, 2011 - where to find fuse on velodyne vx-10b - Velodyne VX-10 Subwoofer. ... in the manual shows a fuse rating of 2 amps where the power cord enters the box. ... here's a link to the owner's manual: http://velodyne.com/vx-11.html.
3/20/2021 5:10:02 PM • Velodyne Audio... • Answered on Mar 20, 2021
We have a 2.5 year old Velodyne EQ-Max8 Subwoofer. It has suddenly started making loud pulsing sounds. Are you able to give us any advice as to what may be wrong with it? Thanks
It sounds like you may have ripped the passive (the rubber material around the speaker that stretches when the speaker hits. If the passive is not ripped then it may be picking up static, or it could be blown. You can purchase a noise filter fairly cheap and try that.
9/30/2019 10:33:15 AM • Velodyne Audio... • Answered on Sep 30, 2019
0answers
How to open Velodyne CHT-8Q. I unscrewed 12 pcs of big screws on back side , but can't pull out
You need to remove 12 outer screws, then remove the amp it might be held in with gasket.
There is a repair shop Edwards Electronics they are master's at repair. They are on web and eBay.
8/12/2017 8:49:09 PM • Velodyne Audio... • Answered on Aug 12, 2017
I have a velodyne spl-800 it has stopped working when i go to use it it will turn on but won't work it makes a sound but not a bass sound it sounds kinda like a burping noise and has no bass.
Sounds like you will need a new amp. Please send your serial number and the complete model number if it is different and I will quote a repair. [email protected]
12/5/2016 3:46:35 PM • Velodyne Audio... • Answered on Dec 05, 2016
Velodyne CT-100 when switched on connected to nothing else makes a very loud humming sound & the speaker is pushed outwards
Replace all the greatest sized capacitors inside are deformed or leaking. can be a 6 pieces because some of them are used parrallell to get double capacity.
5/22/2016 8:37:56 AM • Velodyne Audio... • Answered on May 22, 2016
Velodyne ct100 loud humming +speaker drown backwards.Can I fix at home
The loud humming could be caused by a cable on the input that is not grounded. It could also be caused by some sort of power supply failure. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
5/15/2016 9:30:00 PM • Velodyne Audio... • Answered on May 15, 2016
Has low volume and clicking noise.
I'd contact Velodyne directly. Check their website, velodyne.com/contacts/
9/3/2015 1:56:27 AM • Velodyne Audio... • Answered on Sep 03, 2015
0answers
Hooked up speaker wires backwards what could make it not work or what could go out?
It could hurt the speakers and the amp, depends on level of internal protection they were made with.
5/10/2014 5:32:27 PM • Velodyne Audio... • Answered on May 10, 2014
Velodyne DD-15 Subwoofer Logo
4 questions posted
Top Velodyne Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Velodyne Audio Players & Recorders
Most Popular Question
one bottom aluminum
  • Audio Players & Recorders
