20 Most Recent Makita 10" Compound Miter Saw LS1040 Questions & Answers
Compound miter saw model 2124014 sold by Ace Hardware
Not much available for that vintage saw. The switch might be a possibility from a similar saw. Send images to one of the spares companies. Epoxy resin could fix the handle. https://www.google.com/search?q=Compound+miter+saw+model+2124014 ..
5/9/2021 12:20:52 AM • Makita 10"... • Answered on May 09, 2021
0answers
0answers
0answers
0answers
Motor growls when switched on.
The armature is hitting on the field shoes from misalignment of the end caps and or bearings.. When the power is applied the armature instead of spinning is attracted to the metal shoes of the fields and is touching and shorting out.
8/14/2013 11:51:37 AM • Makita 10"... • Answered on Aug 14, 2013
I can not remove armature caseing from makita miter saw
The casing at the saw end will have an inside case that is bolted either from behind the gears or from the armature side by screws. This has to be undone to allow the bearing to separate from the case
8/4/2013 6:18:17 AM • Makita 10"... • Answered on Aug 04, 2013
Guard spring replace
springs are available from the manufacture spares places or from a hardware store. Any spring of the same size and length will do the job.
8/4/2013 6:09:55 AM • Makita 10"... • Answered on Aug 04, 2013
Saw growling
the problem is poling and that means the armature is touching the field shoes and is shorting out. If you have replace d the field coils then may be the shoes have not been fitted in tightly enough and the clearance is not as it should be. Worn bushes or bearings will give the same effect as when the current is on the armature is pulled to the shoe.. Ensure that the end caps are fitted correctly to ensure alignment and tighten the screws evenly around the case.
8/4/2013 5:56:00 AM • Makita 10"... • Answered on Aug 04, 2013
0answers
Brushes
Be the first to answer 6/11/2013 4:01:02 AM • Makita 10"... • Posted on Jun 11, 2013Be the first to answer
0answers
0answers
How do u unlock a
slightly push down on the handle, then look directly over the top at where swivel spring is either on the left or right side , there is going to be a pull pin, it will only pull out far enough for the handle to go up and down, its not suppose to come all the way out
1/12/2011 6:55:37 PM • Makita 10"... • Answered on Jan 12, 2011
I have a Makita 10 inch compond mitre saw. My
You can get it at Makita.com, type in yr modal number in the search bar, download a parts breakdown or a manual, if not u can order a new sticker from makita.
8/18/2010 8:29:46 PM • Makita 10"... • Answered on Aug 18, 2010
Makita 10" Compound Miter Saw LS1040 Logo
Popular Tags
33 questions posted
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
View Most Popular
Makita Saws
  • Makita Saws
Most Popular Question
  • Saws
