20 Most Recent Nordica Beast 10 Ski Boot Men's Questions & Answers
You can order them from amazon, click here and take a look: Amazon com nordica. Wish you best of luck. Smith
Nordica Beast 10... | Answered on Jan 10, 2015
Hi.
The heel plates I have seen in Nordica boots are all held by four screws. If heel plates are of the same size they should fit. If you do not want to risk try purchasing the heel plates at the Nordica online store. Here the link.
Regards.
Ginko.
Nordica Beast 10... | Answered on Feb 11, 2011
Try to spray the commercial available mist to lower surface tension in order to avoid build-up of condensed water
Scuba Diving &... | Answered on Nov 02, 2018
get that from <a> here </a>masskarafestivals.com/masks/
Scuba Diving &... | Answered on Nov 11, 2017
Hey Candy,
I am sorry to tell you that NO ONE on fixya can help you,, we have NO WAY to find out any information of that type,, PLEASE contact the carrier AND the company that sent you the package... and your credit card company..(if that's how you paid for it!) ..and from now on - ALWAYS get something sent with SIGNATURE REQUIRED!!
Scuba Diving &... | Answered on Sep 17, 2017
the law of buoyancy is the principle that describes why some objects float over water and some others sink: when you put something in water, it receives an upword force equal to the weight of the water it displaces.
this is important in diving in many ways.. and in particular, in diving, you always want to have a neutral buoyancy: this means that if you are standing still in water and you have a neutral buyoancy, you don't sink nor come back to surface
you have a neutral buoyancy if you "displace" always the correct volume of water.. in other words, you always need to occupy about the same volume: if you go in deep water, the water pressure will "reduce" your volume, so to mantain a neutral buoyancy you have to inflate air in your buoyancy compensator jacket to expand its volume.
otherway, if you're coming back to surface, pressure reduces and your body occupies more volume, so you have to deflate your jacket.
Scuba Diving &... | Answered on Jul 30, 2017
it depends on the quality of the mask and it depends on how you stored it (if you leaved it at sunlight, if you washed it thoroughly after using it in the sea...)
i have a mid quality mask Mares mask, i have been using about 20 times for snorkeling, then i used it to take diving certifications in pool, then i used it for about other 20 dives in the sea... i always stored it in a dark bag (the mask is now about 8 years old)
you can check if you mask is still in good shape, and the silicone has not worn out, in this simple way: just put the mask on your face without straps.. remove all the air inside the mask by inhaling with your nose.. then look at your feet (keep inhaling): if the mask remains on your face you can keep using it
Scuba Diving &... | Answered on Jul 29, 2017
The two main types of dive computers are wrist dive computers and console dive computers. Wrist dive computers are actually just like wrist-watches (a little bigger) and are worn on the diver's wrist. Right now, they are smallest dive computers available.
Console dive computers are attached to the diver's equipment by a hose. Main difference between console dive and wrist dive computers is that console dive computers include pressure devices in them.
Scuba Diving &... | Answered on Nov 29, 2016
how to make schools project's jaws of life
Scuba Diving &... | Answered on Mar 03, 2016
You need to consult with a factory technician. Your life depends on these devices. I am certified in USD Survivair and no one can set those after a rebuild kit without special tools and measuring devices.
Scuba Diving &... | Answered on Jul 26, 2015
Yes...the octopus does exist.
Scuba Diving &... | Answered on Mar 02, 2015
I would say no. The water in the pipe that is above sea level will drop back in the pipe until it reaches sea level. Provided neither end of the pipe whether above or below the sea is blocked the level in the pipe will always find natural sea level so it wont be higher or lower than sea level. So in answer to your question No it wont pour out.
Scuba Diving &... | Answered on Jun 18, 2014
Most scuba stores can provide you with the glue.
Scuba Diving &... | Answered on Jan 10, 2014
I noticed another FixYa guru here answered a question on another strand that applies to yours:
Also, please note this person on FB claims to be the Lemax fix-all guru. You can ask them more specific questions:http://webcache.googleusercontent.com/search?q=cache:0YBPB3sM28kJ:https://www.facebook.com/eHobbyTools%3Ffilter%3D2+&cd=10&hl=en&ct=clnk&gl=us
The Knex website has building help for this problem. There answer is as follows:
Make sure all rods and connectors are fully hooked together, especially the blue and gray connectors. Even one peice not fully hooked together can twist the model just enough to jam the gears. (You may have it hooked together correctly prior to jam problems so it is good to check since I found a loose on holding the motor.) The chain links need to all be attached in the same direction, and fully hooked. The chain also needs to be on the tower with the hooks facing down and in as the chain runs on the outside of the tower. (Chain should be outside on the front and inside in the back with the 5 yellow bar side in the front.) Check that all gears are positioned correctly according to the instructions and the teeth facing the correct way. If you are still unable to get the seat to drop, you may remove the top yellow cross rod that the chain runs over - the model will also work with this piece removed.
I did all of these steps with my son and his still had trouble dropping all the time. It still seems light so the seat didn't have enough weight to drop with gravity during the non-moving cycle of the orange half gear. We decided to tape on 2 marble passengers to see if that helped. It did!!! When searching for other solutions, I noticed a UTube video that added people also so this seems to be a common solution. Try it or some other light weight added and see if it solves your problem.
Scuba Diving &... | Answered on Nov 20, 2013
You're talking ancient history here. You might find a manual, but critical parts were unobtanium many years ago. Display it on a wall and call that good.
Scuba Diving &... | Answered on Nov 07, 2013
Hello, There is one thing on some computers that will restart it like the day you bought it, see if there is a very small symbol that looks like a shooting star taking off from the ground and making a U turn and back down that\'s the best I can do for what it looks like, it will be only about 1/8 th in. tall and 1/16 th in. wide very small, it should be close to the power on button on your comp. this is a Rescue System to start all over from day one, I have a Lenovo G570 Laptop and it has one of these, thank god as my comp. got a very sick and would not even let Windows start up I pushed this button and I was able to clear all the stuff that was stopping it from opening, if your lucy you will have something like this on yours, Look it over real close to find this symbol, sorry I don\'t have a pic. for you, you could also check if there is a Tech. help line for your brand of comp. Well I hope this may help in some way, and get you back on line.
Scuba Diving &... | Answered on Aug 22, 2013
What I think will solve your problem is dynamite????
Scuba Diving &... | Answered on Mar 30, 2013
Nordica Beast 10 Ski Boot Men's Logo
15 questions posted
Top Nordica Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Nordica Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
View Most Popular
  • Nordica Scuba Diving & Snorkeling
Most Popular Question
need toe heels nordica syntech f8 ski
  • Scuba Diving & Snorkeling
