20 Most Recent Yardworks Broadcast Spreader 50 Questions & Answers
See the videos. No one knows who makes a 'T 1200' except you.
https://www.google.com/search?q=drive+belt+on+my+lawn+tractor+broke%2C+a+T+1200
The correct search queries would be
make model drive belt diagram
then look at the images tab.
or
make model replace drive belt
and look at the Video tab.
Garden | Answered 4 hours ago
Probably the internal wires have been cut and damaged. You should contact your cable guy, or someone who knows about cable wiring.
Garden | Answered 16 hours ago
Make sure that the deck parts move freely. That the blades and/or bearings or pulleys anr not siezed or blocked. Also you might adjust your carb just a little in air/fuel mixture and idle rpm.
Garden | Answered 2 days ago
Not sure about the fuel/oil ratio. Modern 2-stroke engines are designed to run with less oil due to concerns about pollution and 50:1 isn't unusual. That was the recommendation for my strimmer but I added a little extra oil to maybe 30 or 40:1 and it gave good service for 30 seasons.
The fashion for anti-pollution measures also spread to the fuelling of small engines especially in some areas. In this case the fuel/air adjustments are either hidden behind plastic or metal plugs or deleted from the carb altogether.
If there are no screws it is a preset type and if dismantling and a thorough clean doesn't restore performance it is reasonable to make one of two assumptions (or maybe both) - either the carb is faulty in some way (diaphragm perhaps) or the crankshaft seals are failing and allowing air into the crankcase preventing a good induction.
It isn't unknown for a small 2-strokes to perform well all season and then be next to useless after standing idle all winter. If this is the case it is worth suspecting those seals have lost flexibility...
Garden | Answered 3 days ago
I don't think so. Adjusting the high and low on carburetor is a thing in the past.
I would look on u tube
Garden | Answered on May 26, 2020
Most towns and cities contain a number of businesses with the primary purpose of solving problems for other businesses by supplying or servicing everything from industrial cleaners to replacing hydraulic pipes and many things in between.
Ask around to discover where the users of hydraulic plant such as Case and JCB go for their bits and pieces.
Perhaps the local Yellow Pages or Thompson Directory can help...
Quick check. Spray some starting fluis into the carb. If it starts then you will probably need to work on the carb of fuel lines.
Yardworks Broadcast Spreader 50 Logo
1 questions posted
Top Yardworks Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Yardworks Garden Expert? Answer questions, earn points and help others
View Most Popular
Yardworks Garden
  • Yardworks Garden
Most Popular Question
setting lawm fertilizer yardworks
  • Garden
