20 Most Recent Yardworks Tow Behind Broadcast Spreader Questions & Answers
www.sears.com/yardworks...spreader.../p-S...
(866-523-5218) Yardworks support
Yardworks Tow... | Answered on Jul 06, 2014
Hi try a new plug you're old one could b breaking down under load also give the carby a clean:::::: blow out the Jets inside Especially THE MAIN JET ::::; IF A MOTOR STARTS & WONT KEEP RUNNING ITS A GOOD SIGN THE MAIN JET IS BLOCKED.,,,.. Cheers
Garden | Answered 4 hours ago
Few 2-stroke engines produced in these modern times aren't exhaust tuned which means it is difficult to test the compression pressure with any accuracy at cranking or starting speed - most are exhaust tuned so a much greater power output can be produced from a small and lightweight engine. Peak compression happens at the engine speed when the reflected exhaust pressure wave effectively blocks the exhaust port. At this point the engine capacity grows, the compression ratio increases and the power output increases.
I don't know what the compression pressure should be but I would be slightly worried if it was less than about 90 psi and expect to find a reading of 100/120 psi. As it is a twin, the real test will be the difference between the cylinder pressures which theoretically should be identical though for practical purposes a variation of about 10/20 psi would be acceptable.
The best test of engine condition is how it starts, runs and sounds. When considering a 2-stroke engine it is important not to forget there is also compression under the piston. Sometimes after wintering unused a previously good machine will be down on power and difficult to start. It should not be ignored how if the crankshaft oil seals have lost flexibility, air could be drawn past them into the crankcase reducing the quality of the induction through the carb.
Garden | Answered 11 hours ago
See the videos. No one knows who makes a 'T 1200' except you.
https://www.google.com/search?q=drive+belt+on+my+lawn+tractor+broke%2C+a+T+1200
The correct search queries would be
make model drive belt diagram
then look at the images tab.
or
make model replace drive belt
and look at the Video tab.
Garden | Answered 23 hours ago
Make sure that the deck parts move freely. That the blades and/or bearings or pulleys anr not siezed or blocked. Also you might adjust your carb just a little in air/fuel mixture and idle rpm.
Garden | Answered 2 days ago
Not sure about the fuel/oil ratio. Modern 2-stroke engines are designed to run with less oil due to concerns about pollution and 50:1 isn't unusual. That was the recommendation for my strimmer but I added a little extra oil to maybe 30 or 40:1 and it gave good service for 30 seasons.
The fashion for anti-pollution measures also spread to the fuelling of small engines especially in some areas. In this case the fuel/air adjustments are either hidden behind plastic or metal plugs or deleted from the carb altogether.
If there are no screws it is a preset type and if dismantling and a thorough clean doesn't restore performance it is reasonable to make one of two assumptions (or maybe both) - either the carb is faulty in some way (diaphragm perhaps) or the crankshaft seals are failing and allowing air into the crankcase preventing a good induction.
It isn't unknown for a small 2-strokes to perform well all season and then be next to useless after standing idle all winter. If this is the case it is worth suspecting those seals have lost flexibility...
Garden | Answered on May 27, 2020
I don't think so. Adjusting the high and low on carburetor is a thing in the past.
Garden | Answered on May 26, 2020
Yardworks Tow Behind Broadcast Spreader Logo
3 questions posted
Top Yardworks Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Yardworks Garden Expert? Answer questions, earn points and help others
View Most Popular
Yardworks Garden
  • Yardworks Garden
Most Popular Question
get drive wheel turn transmission
  • Garden
