20 Most Recent Whirlpool Whirpool 26 cu. ft. French Door Refrigerator w/ MicroEdge Shelves - Questions & Answers
Need more information. Model number would help.
Whirlpool... | Answered on Mar 25, 2016
Is the cold water dispenser working? If not, does the filter need to be changed? Do you actually have water supply to the fridge?
Is the Ice bin empty? Is this your fridge, or are you renting and this was in place? If yours, do you have an Owner's manual with the troubleshooting tips? No manual, try manualslib.com Make model possibly year and serial number. If not yours, there should be a switch that turns the Icemaker on or off. A green light on the front of the drive mechanism near this switch should mean it does have power. No light, no power. There should be a mechanical switch that stops the Ice maker. If the bin is empty, the ice detection arm should be down If it is not down, It is stuck in the "bin is full" position. If these are not the problem, It may be the electrical valve for the Icemaker water supply is not operating, or has been disconnected, or is bad. I have found that one of the online "appliance parts store or sites" have been quite helpful in diagnosing problems and recommending parts and how to fix.
Whirlpool... | Answered on Apr 01, 2015
some ice makers have an arm on them that stops producing when the box is full and sometimes it sticks in the ff postion
Whirlpool... | Answered on Mar 13, 2015
Generally, if you unplug the refrigerator and set the freezer and refrigerator temperature controls to off then plug it back it, this will put the refrigerator in forced defrost mode. Keep the doors closed and allow defrosting to last for about 20 minutes. Then unplug again and reset the temperature controls to mid-range or a little above, and plug it back in. If this does not reset the defrost cycle, you probably need service.
Whirlpool... | Answered on Mar 03, 2015
Normally on the back bottom near the compressor area.
Whirlpool... | Answered on Dec 06, 2014
Your drain hose in the bottom back of the freezer is clogged and Iced up and all the defrost water is staying in the freezer and building up. You need to take the freezer back panel off, remove all the ice, defrost the drain, clean, flush with hot water and test the drain line to reach the drain pan under the fridge.
Whirlpool... | Answered on Aug 19, 2014
water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
Whirlpool... | Answered on Aug 07, 2013
Hi Lucille,
NO This model does not have a water filter.You will need to complete disconnect the ice maker and clean it out. Then remove and flush the fill tube. If ice still appear dirty, you may to replace the water valve,the water tube and the ice maker too. I will link the parts needed and see the repair video on how to access them. https://www.appliancepartspros.com/whirlpool-whirlpool-icemaker-kit-4317943-ap2984633.html
https://www.appliancepartspros.com/whirlpool-tube-water-w10823511-ap5989588.html
/whirlpool-water-valve-4318046-ap3103466.html
Whirlpool... | Answered 4 hours ago
The main control board in the back of the fridge is most likely what is wrong.
Whirlpool... | Answered 17 hours ago
I think the model number is ED2KVEXVB00. Most Whirlpool appliance model numbers end in digits, not letters. SearsPartsDirect has the parts lists here: https://www.searspartsdirect.com/model/50z7if8ddb-001198/whirlpool-ed2kvexvb00-side-by-side-refrigerator-parts . Another source for the parts is https://www.partselect.com/Models/ED2KVEXVB00/ . There are probably others.
I hope this helps.
Whirlpool... | Answered on Sep 14, 2020
The styrofoam is the insulation between the inner plastic surface and the outer metal surface.
Airflow is created by the internal fan. The cold air drops down from the freezer above. The foam surrounded channel is usually in the rear wall.
https://www.google.com/search?q=Whirlpool+wrt104tfdwoo+has+no+air+flow
Whirlpool... | Answered on Sep 11, 2020
Bulb cover or some other cover?
Manual not particularly helpful
https://www.manualslib.com/manual/421205/Whirlpool-Wsf5574-APlusn.html?term=bulb&selected=2#manual
From the maker. It shows clips on the side, squeeze and pul.
https://producthelp.whirlpool.com/Refrigeration/Freezers/Product_Info/Product_Assistance/Replacing_the_Light_Bulb_-_Freezer
Video help as well
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01g4um2Kdd9zQ4P97VWjRRTT7B5qA%3A1599754470793&ei=5lBaX-X5L6uEytMPjOKC6AY&q=whirlpool+wsf5574A%2BN+replace+bulb
Whirlpool... | Answered on Sep 10, 2020
I realize this question was posted on 11-17-2015 if you still need help please answer the question so I may help you. Look into the freezer on the back wall to see if there is a layer of ice forming. Can you tell me what you see?
APPLIANCE 911
Whirlpool... | Answered on Sep 01, 2020
well like all the rest of us you pay to have it fixed mine right now the fridge is over 70 but the freezer is still frozen solid i can not access the defrost timer .so they will be here tomorrow we hope
Whirlpool... | Answered on Aug 27, 2020
call the owner or manager and ask them to get it fixed
Whirlpool... | Answered on Aug 05, 2020
Contact Whirlpool or a Whirlpool retailer to inquire.
Whirlpool Whirpool 26 cu. ft. French Door Refrigerator w/ MicroEdge Shelves - Logo
10 questions posted
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
remove bottom drawer rack
  • Refrigerators
