20 Most Recent Nor-Lake NLGR48S 48 cu/ft Refrigerated Merchandiser w/ 2 Sliding Doors Questions & Answers
Unfortunately, this model has had quite a few problems, because it is such a complicated refrigerator. Many times a shorted component that is connected to the Iceland main control board will affect completely unrelated items making it easy to chase your tail for hours. I would suspect the freezer thermostor - only because we have had to replace it many times in the past.
Suggest you go to the www.searspartsdirect.com and copy the electrical diagram and then verify electrical reading on the main PCB, to try to isolate the problem.
Nor-Lake... | Answered on Jan 26, 2012
There are a few companys that make temp chart recorders that are battery controled and you could get one of these and just put it inside the refrigerator, problem solved. Check at United Refrigeration, and Johnstone Supply they both have manufacturers that will allow you to keep charts. The 2 things to keep in mind 1 How often are you going to change charts, 2 what temperature range are you looking for.
Oh yes and Im sure there is a company that makes a remote sensed temp recorder that can tie into a computer and print out charts as needed. This is a little more specialized but I know the technology is asvailable. Probably Johnson or Penn Controls would know about this.
If this helps you in any way please rate me as high as you can. If you need to contact me and I can do the searching for you post back.
Nor-Lake... | Answered on May 29, 2009
First unplug the fridge and plug it back in. Make sure that an ice cube is not interfering with the control bar. Then check to see if the water line is getting water to the ice maker.
Refrigerators | Answered 3 days ago
It doesn't work posting followup, or adding information as a new post. Fixya does not thread or nest posts by poster, so very shortly this one will be miles away from the other one and have no context or relevance to the this. Also, you have forgotten the most important piece of information
Full make and model
Delete both, and make one correct post.
Andrew - Fixya Moderator
Refrigerators | Answered on Jul 31, 2020
Contact the manufacturer/distributor to request
Refrigerators | Answered on Jul 27, 2020
Contact the manufacturer/distributor to inquire.
Refrigerators | Answered on Jul 25, 2020
YOU MIGHT TRY TO UNCLIP THE COMPRESSOR AND MOVE IT OUT SLOWLY AS HOT TO KINK THE COPPER TUBING,ALSO MAKE SURE YOU USE CLAUK UNDER THE DRAIN PAN SO IT DOES NOT LEAK,HOPE THIS HELP,THANKS-MIKE
Refrigerators | Answered on Jul 18, 2020
Nor-Lake NLGR48S 48 cu/ft Refrigerated Merchandiser w/ 2 Sliding Doors Logo
0 questions posted
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Nor-Lake Refrigerators
Most Popular Question
type refrigerant
  • Refrigerators
