20 Most Recent Nor-Lake Advantedge Reach-in Refrigerator One-section NLR23-S Questions & Answers
Unfortunately, this model has had quite a few problems, because it is such a complicated refrigerator. Many times a shorted component that is connected to the Iceland main control board will affect completely unrelated items making it easy to chase your tail for hours. I would suspect the freezer thermostor - only because we have had to replace it many times in the past.
Suggest you go to the www.searspartsdirect.com and copy the electrical diagram and then verify electrical reading on the main PCB, to try to isolate the problem.
Nor-Lake... | Answered on Jan 26, 2012
There are a few companys that make temp chart recorders that are battery controled and you could get one of these and just put it inside the refrigerator, problem solved. Check at United Refrigeration, and Johnstone Supply they both have manufacturers that will allow you to keep charts. The 2 things to keep in mind 1 How often are you going to change charts, 2 what temperature range are you looking for.
Oh yes and Im sure there is a company that makes a remote sensed temp recorder that can tie into a computer and print out charts as needed. This is a little more specialized but I know the technology is asvailable. Probably Johnson or Penn Controls would know about this.
If this helps you in any way please rate me as high as you can. If you need to contact me and I can do the searching for you post back.
Nor-Lake... | Answered on May 29, 2009
Make sure that the cooling coils are free from dust bunnies and other debris. Plastic bags are a big problem.
Refrigerators | Answered Yesterday
It is best not to cut the fan blades if it can be avoided - best to cure the original fault if you can.
If you need to trim the blades it is very important to remove exactly the same amount from each blade to maintain the balance. The weight might seem insignificant but over time even a tiny imbalance can cause an increased noise level.
Refrigerators | Answered 2 days ago
First, I'm not a Dynacool Tech,
* I remember having one as a kid. You need to fill it with water for the circulator (pump) to work and drip water over a filter that has a fan blowing through it. The water evaporates and cools the air as it flows through (It also increases the humidity).
* here is a Honewell manual. Check out page 12. There should be enough information to get you started.
https://www.sylvane.com/media/documents/products/honeywell-cs071ae-evaporative-cooler-owner%27s-manual.pdf
* Final, Check your warranty and call for service. (though I can't seem to locate a current phone # or web site. May have gone under or bought out.)
* about upgrading to a newer model. There have been many changes to Air conditioning and heating. Many are more efficient and built with newer technology as this evaporative cooling method was used in the 1940's and popular in the 1970's. Check out your local stores and show rooms. Also check Home Depot and Lowe's for home air conditioners
Aloha, ukeboy57
Refrigerators | Answered 3 days ago
Igloo would be a possible source.
Refrigerators | Answered on Jul 09, 2020
You will have to defrost the freezer and sponge the water out. Not a fun job by any means.
There is no drain because the manufacturer did not want to have water leaking onto the floor.
Refrigerators | Answered on Jul 08, 2020
Nor-Lake Advantedge Reach-in Refrigerator One-section NLR23-S Logo
0 questions posted
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Nor-Lake Refrigerators
Most Popular Question
type refrigerant
  • Refrigerators
