20 Most Recent
Advanced Elements Advancedframe Convertible Inflatable Kayak Questions & Answers
Small hole
You need a patch of at least the same quality as the item to be patched. If the patch is of the same material it's compatability with the cement isn't a problem. The cement or the adhesive needs to be the best you can get as the quality of any repair is only as good as the materials used.
Regards Rod
5/11/2017 8:41:43 PM •
Advanced...
Answered
on May 11, 2017
Torn bow
Repair any cracks or damage to the hull with fiberglass repair kits, available at most hardware stores. Use an overlay prior to the fiberglass if the area is bigger than a quarter so you don't develop a soft spot.
8/15/2010 3:17:40 PM •
Advanced...
Answered
on Aug 15, 2010
Engine turn over but will not start
Check- Do You Have Spark At The Spark Plugs?If Not Then It Could Be Stator Or CDI Unit Or Trigger, If Yes Good!Have Carburetor ('s)Got Fuel In Them? ,If Not Clean Carb's. If Both Are Correct It Should At Least FireGood Luck
3/30/2013 12:24:28 PM •
Boating
Answered
on Mar 30, 2013
Motor runs fine if not in gear or at low rpms wont
This Could Be Many Things But If You want To Try A Few Yourself,Fit New Spark Plugs,Clean The Carburetor,If It Does Not Show any Signs Of Improvement ,Nothing Lost Take It In For Diagnostic Check
3/30/2013 12:18:11 PM •
Boating
Answered
on Mar 30, 2013
Can I shorten the shaft on my trolling motor it
Yes You Can Strip Top Of Motor Remove Upper Bearing Cup, Cut Pipe To Required Length, Cut All Electrical Wires (shorten) By The Same Amount,Re Do All Cable Ends As Before and Re Assemble You Are done. Note Take Photo Before Removing Wires For Reference.
3/30/2013 8:14:18 AM •
Boating
Answered
on Mar 30, 2013
My tilt on a yamaha ox66 200 motor quit working,what
Step 1:
Operate Trim Switch Do You Hear Clicking Sound In Engine Yes ,NoStep 2:
If Yes Check Wiring To Power Trim Motor are All Cables TightIf No Then The Trim Relay And Or Trim Switch Is Probably At FaultStep 3:
,Remove Three Large Color Wires Going To Power Trim Motor Black, Blue And GreenConnect Black Direct To Negative Battery And Blue To Positive Battery Motor Should Trim Up ,Remove Blue Then Try Green To Positive Battery, Motor Should Trim Down ,If Nothing Then Trim Motor Is At Fault If Works Then Trim Relay/s Are At Fault
3/30/2013 8:07:59 AM •
Boating
Answered
on Mar 30, 2013
My mercury 175 v6 keeps burning up power pack for
Make Sure All The Earths Are Clean And Connected There Should Be An Earth On Each Power Pack,You Should Have The Out Put From The Stator Checked If It Is High On That Left Bank It Would Cause That Power Pack To Fail, This Would Require A New Stator Hope This Helps
3/30/2013 7:30:10 AM •
Boating
Answered
on Mar 30, 2013
My 100hp yamaha 4 stroke is stuck in the trailer
On The Side Of The Transom Bracket There Is A Manual Release Screw Turn Counter Clockwise About 5 Turns The Motor Will Go Down Close It Again and It Will Lock it In That Position.You Will then Have To Repair Your Trim motor!
3/30/2013 7:23:05 AM •
Boating
Answered
on Mar 30, 2013
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM •
Boating
Answered
on Dec 05, 2023
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin
Cruisers are 20-40 feet. There are of course larger Yachts that can get to over
100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM •
Boating
Answered
on Nov 15, 2023
