20 Most Recent
Wilderness Systems Pungo 140 Kayak Questions & Answers
When can I paddle with kayak?
You can, but it's all about compromise ? and safety. Generally, the shorter the boat the easier it will turn (great for rivers and white water), but the slower you'll be getting from point A to point B. The longer the boat (most sea kayaks) the better it generally tracks and the faster and safer it travels through water.
Essential equiptment
You will need to wear a PFD, personal flotation device. This is designed to keep you afloat if you end up in the water.
Here are 10 essentials that will make you look and feel like a pro.
1. Paddling Gloves
2. Polarized Sunglasses
3 Water Shoes
4 Small Cooler
5 Waterproof Case for Keys
6. Waterproof Phone Case
7 Dry Bag
8 Kayak Carrier Shoulder Strap
9 Water Resistant Sunscreen
10 Bow and Stern Safety Tie-downs
Safe touring kayak
A boat designed for greater touring distances and a higher degree of safety would have a smaller cockpit, hatches and bulkheads. The smaller cockpit allows for contact with your knees for control. The hatches and bulkheads are designed to be, for the most part, air- and watertight. You can store gear (in dry bags) in these as well as have hundreds of pounds of positive buoyancy should your cockpit fill with water.
New Pungo 140, rear bulhead
Brand new boat? Let them replace it, it's a manufacturing defect! The bulkhead probably was slightly too large or the sealant was poorly applied, either way you don't want the headache yourself. Wilderness systems and their dealers tend to be VERY reasonable with this type of problem. If it were an older boat or one you had used extensively, I would recommend removing the old sealant and then laying down thick beads of a high quality silicone sealant such as Lexel on both sides of the bulkhead.
10/28/2013 12:27:21 AM •
Wilderness...
Answered
on Oct 28, 2013
I have a very old
Plastic? Cheap and quick way would be to try to fill the hole -- small you said -- with good caulking and then stuff the inside of that end with a plug of something to support the seal. Duct tape on the outside to protect the seal.Not sure what you mean about the bow covering.
10/28/2013 12:22:40 AM •
Wilderness...
Answered
on Oct 28, 2013
Stern hatch cover of my Wilderness Pungo 140 (2005
You can try your local dealer, or order direct from:
http://www.wildernesssystems.com/pages/index/resources/customer_service/replacement_parts
You do not say where you are, so I gave you the link for parts in the USA.
Water is entering into the stern hatch. The foam
If it is dry, and you don't need to access it, about the best thing to use to seal it is silicone caulk. I paddle whitewater and that stuff is the bomb. There are some other glues (like the ones they use for foam pads), but they are extremely expensive. Tube of silicone 5 bucks. Also, in a pinch on the water, duct tape it.
Essential equipment
The essentials are: 1. boat. 2. paddle. 3. sprayskirt. PFD - personal floating device (life jacket).
Length og a kayak
The longer the boat the faster the hull speed. So if your friends are paddling kayaks that are seventeen feet long and you are in a twelve-foot kayak, you'll be paddling much harder just to keep up. If you intend to paddle on smaller bodies of water, say ponds or small lakes where distance is not a factor, length is not so important. But if you live (or plan to paddle) on a bay, then you should consider more of a touring boat which will track straighter and move through the water with greater stability as well as speed.
Need to sell my Kayak plus associated equipment.
The usual places to advertise are local online markets such as Kijiji or Used(city).com or similar sites. Better places are often run by major clubs or associations, MEC in Canada, or major websites about kayaking and canoeing. paddling.net is one example.
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM •
Boating
Answered
on Dec 05, 2023
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin
Cruisers are 20-40 feet. There are of course larger Yachts that can get to over
100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM •
Boating
Answered
on Nov 15, 2023
