20 Most Recent Xterra Fitness Xterra Treadmill Questions & Answers
E5 on XTERRA treadmill
i have the same problem
1/15/2017 5:16:54 PM • Xterra Fitness... • Answered on Jan 15, 2017
Error 6 message on xterra 3.0 treadmill
I have the same problem... It doesnt work.
1/22/2015 4:39:14 PM • Xterra Fitness... • Answered on Jan 22, 2015
Xterra tr3.0
New xterra trendmill will not start says error 5 help
12/29/2014 12:59:56 PM • Xterra Fitness... • Answered on Dec 29, 2014
0answers
Machine not running but lights coming on ok. There was a noise before this happened. Would it be the motor
All question need full 'make model (what it is)', Margaret, first 3 words or this happens.
Fluke BT5300 Series Battery Tester
Fluke https://www.fluke.com > product > battery-analyzers Specifications: Fluke BT5300 Series Battery Tester ; BT5310/BT5311, BT5320/BT5321 ; Digit, 6.5 digits, 7.5 digits ; Range, 10 V ; Max. Display value, ±11.00000V · ± ...
(BT) Air Baltic 5310 Flight Tracker
FlightStats https://www.flightstats.com > flight-tracker BT5310 Flight Tracker - Track the real-time flight status of Air Baltic BT 5310 live using the FlightStats Global Flight Tracker.
Airbaltic BT5310 Flight Status
Trip.com Official Site‎‎ ' Travel Deals and Promotions https://us.trip.com > ... > Flights from Munich to Lisbon Track real-time flight status of BT5310 from Munich to Lisbon on Trip.com. Get live updates on flight arrival & departure times and other travel information ...
QC620 Skid Digger Thumb
GLC Equipment https://www.glcequipment.ca > product > qc620-skid-dig... SKU: BT5310 - 48 Category: Back Trenchers. MPN: BT5310. Manufacturer: Wallenstein. Brand: Wallenstein. Description; Additional information; Reviews (0) ... $910.00 · ‎ In stock
BT 5310 - Aluminum Komatsu WA450-6 Wheel Loader ...
C, G, & J Inc https://cgj.com > product > bt-5310-aluminum-komatsu... BT 5310 - Aluminum Komatsu WA450-6 Wheel Loader Radiator. $1,404.75. The BT 5310 all aluminum radiator is an exact fit, OEM replacement for Komatsu WA450-6 ... US$1,404.75 ..
4/23/2024 5:25:43 AM • Exercise &... • Answered 2 days ago
Olympus Sport exercise bike, model OS-11202. Resistance braking (gear/level change) is not working.
If the resistance braking system on your Olympus Sport exercise bike model OS-11202 is not working, there could be a few potential issues causing the problem. Here are some steps you can take to troubleshoot and possibly fix the issue:
  1. Check Power Source: Ensure that the exercise bike is properly plugged into a power source if it requires electricity. Some models may have electronic resistance systems that need power to function.
  2. Inspect Resistance Mechanism: Examine the resistance mechanism to see if there are any visible signs of damage or wear. Look for loose cables, broken parts, or anything that appears out of place.
  3. Test Resistance Levels: Try adjusting the resistance levels on the bike to see if there is any response. If the resistance levels do not change when you adjust them, it could indicate a problem with the resistance mechanism or the control panel.
  4. Reset the Bike: Turn off the exercise bike, unplug it from the power source (if applicable), and wait for a few minutes. Then, plug it back in and turn it on again. Sometimes, resetting the bike can resolve minor issues.
  5. Check User Manual: Refer to the user manual for troubleshooting tips specific to your model of exercise bike. The manual may have information on common problems and how to fix them.
  6. Contact Manufacturer or Support: If you're unable to resolve the issue on your own, consider contacting the manufacturer or customer support for assistance. They may be able to provide further troubleshooting steps or advise you on repair options.
  7. Professional Repair: If the resistance braking system is still not working after attempting these steps, it may be necessary to take the exercise bike to a professional repair technician. They can diagnose the problem more accurately and perform any necessary repairs or replacements.
By following these steps, you should be able to identify the cause of the resistance braking issue on your Olympus Sport exercise bike and take appropriate action to resolve it.
4/21/2024 7:18:29 AM • Exercise &... • Answered on Apr 21, 2024
Screws of fitbit charge HR not coming out using a replacement band screwdiver kit
It sounds like you're having trouble removing the screws from your Fitbit Charge HR using a replacement band screwdriver kit. Here are a few things you can try:
  1. Apply Pressure: Sometimes, screws can be quite tight. Make sure you're applying enough pressure while turning the screwdriver to loosen the screws.
  2. Use Lubricant: If the screws are stuck due to rust or debris, a small amount of lubricant (such as WD-40) applied to the screws might help loosen them.
  3. Different Angle: Try turning the screwdriver at a slightly different angle. Sometimes this can make it easier to grip and turn the screw.
  4. Use a Different Screwdriver: If the screwdriver provided in the kit isn't working well, you might try using a different one. Sometimes, the quality of the screwdriver can make a big difference.
  5. Seek Professional Help: If you're still having trouble, it might be best to seek assistance from a professional, such as a watchmaker or jeweler, who has experience working with small screws and delicate electronics.
If none of these solutions work, it's possible that the screws are damaged or defective. In that case, you might need to contact the manufacturer for further assistance or consider replacing the device altogether.
4/21/2024 6:19:07 AM • Exercise &... • Answered on Apr 21, 2024
I have inspire hr Fitbit. Can I swim with it
Yes, absolutely! You can swim with your Inspire HR. In fact, it is designed to detect your swim activity if you like to swim laps and turn that activity on (you can do it in the app under "exercise goals").
4/21/2024 6:00:05 AM • Exercise &... • Answered on Apr 21, 2024
Nordic Track 1300 commercial elliptical. Why can't I level up the resistance?
Check the Generator Tension Bolt : Loosen the cap screws and tighten the generator tension bolt with an Allen wrench. Adjust it until the drive belt inside the pedals is no longer loose. If it's too tight, loosen the generator tension bolt as needed. Retighten the cap screws and replace the side shields. Unplug your elliptical from the power outlet and examine the wire harness connections between the console and the resistance motor. Check continuity using the multimeter and replace any non-working wires. Inspect the Resistance Motor Voltage: There is a small motor under the shroud that operates the resistance motor. It's about the size of a roll of half dollars. Use a multimeter to check if the console is sending power to the resistance motor when you manually adjust the resistance. If there's no voltage, your elliptical console may need replacement. If this doesn't resolve the issue, you might contact Nordic support.
4/21/2024 5:54:40 AM • Exercise &... • Answered on Apr 21, 2024
2answers
How to fix error E6 on a trojan evelotion platinum seriestreadmill
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
4/18/2024 10:08:37 PM • Exercise &... • Answered on Apr 18, 2024
I need assembly instructions for wynne home gym.
Please check this link:https://www.google.com/search?sxsrf=ALeKk02D68ibDlpmqPFTdJFsPUAG8G7Hqg%3A1609823462652&source=hp&ei=5vTzX9vmJfG4mAXst4l4&q=assembly+instructions+for+wynne+home+gym&oq=assembly+instructions+for+wynne+home+gym&gs_lcp=ChFtb2JpbGUtZ3dzLXdpei1ocBADMgQIIxAnOgcIIxDqAhAnUIwSWIwSYPUXaAFwAHgAgAHwAYgB8AGSAQMyLTGYAQCgAQGwAQ8&sclient=mobile-gws-wiz-hp
4/5/2024 4:00:16 PM • Exercise &... • Answered on Apr 05, 2024
2answers
Where can I find a great treadmill deal on Black Friday 2023
The website TreadmillReviews.net has a black Friday page that you can see to find the best Black Friday deals https://www.treadmillreviews.net/sales/black-friday/. They have all the vendors and are featuring some of the best deals.
3/26/2024 8:02:23 AM • Exercise &... • Answered on Mar 26, 2024
Xterra Fitness Xterra Treadmill Logo
Popular Tags
8 questions posted
Top Xterra Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Xterra Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Xterra Fitness Exercise & Fitness
Most Popular Question
error 6 message xterra 3 0 treadmill
  • Exercise & Fitness
