20 Most Recent Jura Capresso Impressa X7 Espresso Machine Questions & Answers
Have you descaled it regularly? Do you have hard water?
Sounds like it's clogged with scale. Try running white vinegar and water through, see if that unclogs it.
Jura Capresso... | Answered on Jun 03, 2019
Either there is issue with the Sensor or the Thermoblock. you'll have to replace either of these.
Jura Capresso... | Answered on May 20, 2019
Hi Error 4 is the following fault :STEAM: Temperature sensor notify “value above tolerance” I think only a trained engineer could fix this unfortunately. Hope it helps though. Alison
Jura Capresso... | Answered on Apr 01, 2018
small black rectangular float is stuck in the water tanks . take off tank and empty. then shake you will see it on the side wall (machine side) if it does not rise when water is filled the machine still thinks its empty
Jura Capresso... | Answered on Jun 28, 2016
Try the following link we are sure they will be more than happy to help you find what you are looking for
http://www.partsguru.com/JuraEspresso.html
Jura Capresso... | Answered on Jan 30, 2016
kitchen.manualsonline.com
Jura Capresso... | Answered on Sep 15, 2014
remove tank clean with hot water, rinse and shake you should hear a rattle in the bottom of the tank. if you dont the the small black float built into the tank side wall is stuck. once free it will work fine.
Jura Capresso... | Answered on Mar 04, 2014
The milk tubes should be submersed into water with a milk cleaning agent. sounds like you've left the milk tubes drawing from the fridge with milk in it.
Bean to cup cleaning
Jura Capresso... | Answered on Sep 29, 2013
Jura Capresso Impressa X7 Espresso Machine Logo
48 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Impressa Jura Capresso
  • Impressa Jura Capresso
Most Popular Question
our jura x7 showing malfunction 4
  • Coffee Makers & Espresso Machines
