20 Most Recent Jura Capresso Impressa F7 Espresso Machine Questions & Answers
There are two possible causes. One is easy the other is hard. So try the easy one first. Remove the grinds tray completely, and place you hand in the cavity that it normally takes up. moving you hand slowly in, feel towards the top. you will find a little flap, past that flap there is the tamper and coffee filter at a slight angle. This may be blocked, so clean with a cloth.
If that does not solve the problem (and 90% of the time it does) then you may have a small spec of dust that is stuck in the water system, this needs to be flushed and cleaned. The best place to do that is with a Jura approved center. Unless you are technically minded. Your local Jura chaps sound like they need a k!$k up their behind
Jura Capresso... | Answered on Oct 11, 2019
Check to see if there is a lever that may need pushed in as you put the tray bad in...not sure as many of the machines are different...but it's worth a try! :)
Jura Capresso... | Answered on Oct 23, 2016
I have 3 different coffee machines and all 3 are descaling like you said using only the froter so that is normal .... Unless you misstyped the question
Jura Capresso... | Answered on Dec 27, 2015
If you want us to localize the cleaning lady, I suggest to ask for her at the nearest employment office. Probably she is looking for a new job. As an option, you can get a new cleaning lady.
Now, if you want to find a site to get parts for your coffee maker, look for it at
Jura Parts Jura Capresso Parts and Repairs
Jura Capresso... | Answered on Jul 30, 2015
Hi, I made a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Jura Capresso... | Answered on Mar 23, 2015
According to the Jura Coffee Machine Error List, you machine needs a service, have you made 5,000 cups since your last service?
The message 'FAULT 5' on the Jura Impressa F7, appears when there is a problem with the heating sensor. Normally it needs service or replacement. You can try to unplug it from the power supply for an hour and then open it again. See if it works.
Jura Capresso... | Answered on Jan 21, 2015
Open the whole machine and you'll find the spout. Tighten up the nut there, the washer is like a tap thats dripping
Jura Capresso... | Answered on Dec 10, 2014
yeah, you have to find out why...here is the manual to assist you: http://www.partsguru.com/SaecoViennaPlus.html
Jura Capresso... | Answered on Jun 16, 2014
Jura Capresso Impressa F7 Espresso Machine Logo
51 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Impressa Jura Capresso
  • Impressa Jura Capresso
Most Popular Question
error message fault 5
  • Coffee Makers & Espresso Machines
